Hello, i am new to coding and arduino
I am making nitrox analyzer for scuba diving and have problem with battery voltage readings, i have code that read battery correctly and have code that work for nitrox correctly, but when i combine them i get false readings
This is code that gives me 0.9v battery voltage
#include <Arduino.h>
#include <ADS1115.h>
#include <ClickEncoder.h>
#include <EEPROM.h>
#include <RollingAverage.h>
#include <U8g2lib.h>
#include <TimerOne.h>
#include <Wire.h>
#include "config.h"
#include "nitrox.h"
#include "state.h"
// LCD
// U8G2_SH1106_128X64_NONAME_1_HW_I2C u8g2(U8G2_R0); // 128 bytes framebuffer
U8G2_SH1106_128X64_NONAME_2_HW_I2C u8g2(U8G2_R0); // 256 bytes framebuffer
// ADC
ADS1115 ads;
// ROLLING AVERAGE
int16_t readingsBuffer[SAMPLE_SIZE];
RollingAverage readings(SAMPLE_SIZE, readingsBuffer);
// ENCODER
ClickEncoder encoder(ENC_PIN_A, ENC_PIN_B, ENC_PIN_SW, ENC_STEPS);
int16_t encPosPrev, encPos;
int8_t encDelta;
uint8_t buttonState;
void timerIsr()
encoder.service();
// STATE MACHINE
state_t state;
state_dialog_t stateCalibMenu;
state_ppo2_t stateModDisplay;
uint32_t displayTimer = 0;
uint32_t analyzeTimer = 0;
uint32_t calibrateTimer = 0;
uint32_t batteryTimer = 0;
// OTHER
int16_t batteryVoltage = 0;
int16_t calibrationFactor = 0; // unit is [1e-1 µV / %], value should be ~5000
int16_t oxygenConcentration = 0;
int32_t sensorMicroVolts;
char displayFooterBuffer[24];
bool batteryWarning = false;
// Main render function
void renderDisplay()
u8g2.firstPage();
do {
if (batteryWarning) {
u8g2.setFont(u8g2_font_6x13_tr);
u8g2.drawBox(118,0,10,12);
u8g2.setFontMode(1); // transparent background
u8g2.setDrawColor(2); // XOR
u8g2.setCursor(120,10);
u8g2.print(F("B"));
// reset drawing modes
u8g2.setFontMode(0);
u8g2.setDrawColor(1);
switch(state) {
case STATE_START_SCREEN:
// TODO: Add Graphics ?
u8g2.setCursor(0,10);
u8g2.print(F("Nitrox Analyzer"));
u8g2.setCursor(0,20);
u8g2.print(F("Starting..."));
u8g2.setCursor(0,63);
u8g2.print(F("Battery: "));
u8g2.print(batteryVoltage/1000);
u8g2.print(".");
u8g2.print((batteryVoltage % 1000) / 10);
u8g2.print("V");
case STATE_ANALYZE:
case STATE_HOLD:
if (state == STATE_HOLD) {
u8g2.print(F(">>> HOLD <<<"));
else {
u8g2.print(F("Analyzing"));
//u8g2.setFont(u8g2_font_inb30_mn);
u8g2.setFont(u8g2_font_logisoso30_tn);
u8g2.setCursor(20,48);
// print O2 as a decimal percentage
if ((oxygenConcentration / 100) < 10) {
u8g2.print("0");
u8g2.print(oxygenConcentration / 100);
u8g2.print(".");
if ((oxygenConcentration % 100) < 10) {
u8g2.print("0");
u8g2.println(oxygenConcentration % 100);
// print MOD
u8g2.drawStr(0,63,displayFooterBuffer);
case STATE_CALIBRATE_MENU:
u8g2.print(F("Calibrate ?"));
u8g2.drawStr(20,48,"20.95");
if (stateCalibMenu == YES) {
u8g2.drawBox(0,53,64,10);
else {
u8g2.drawBox(63,53,64,10);
u8g2.setCursor(24,63);
u8g2.print(F("YES"));
u8g2.setCursor(90,63);
u8g2.print(F("NO"));
case STATE_CALIBRATE:
u8g2.setCursor(30,10);
u8g2.print(F("Calibration"));
u8g2.setCursor(30,20);
u8g2.print(F("in progress"));
u8g2.setCursor(21,40);
u8g2.print(F("Please wait..."));
default:
} while ( u8g2.nextPage() );
#ifdef DEBUG
Serial.begin(19200);
Serial.println(F("*\n* Nitrox Analyser - DEBUG\n*"));
#endif
Wire.begin();
u8g2.begin();
ads.begin();
ads.setGain(GAIN_SIXTEEN); // +/- 256mV FSR = 7.812µV resolution
ads.setDataRate(DR_16SPS); // 16 sps
ads.setMux(MUX_DIFF_0_1); // sensor is connected between AIN0 (P) and AIN1 (N)
ads.writeConfig();
#ifdef DEBUG
Serial.print(F("ADS config: "));
Serial.println(ads.readConfig());
#endif
ads.startContinuousConversion();
// Rolling average
readings.begin();
// Input processing and debouncing
Timer1.initialize(1000); // 1ms
Timer1.attachInterrupt(timerIsr);
// initialize variables
encPosPrev = encPos;
state = STATE_START_SCREEN;
stateCalibMenu = NO;
stateModDisplay = PPO2_1_6;
displayTimer = millis(); // initialize for splash screen
batteryTimer = -BATTERY_INTERVAL; // force initial reading
#ifdef EEPROM_ENABLE
// Load last calibration factor
EEPROM.get(EEPROM_CALIBRATION_ADDRESS, calibrationFactor);
#ifdef DEBUG
Serial.print(F("EEPROM load: ")); Serial.println(calibrationFactor);
#endif
#endif
static bool updateDisplay = true;
// Handle inputs
buttonState = encoder.getButton();
encPos += encoder.getValue();
encDelta = encPos - encPosPrev;
#ifdef DEBUG
if (buttonState != 0) {
Serial.print(F("Button: ")); Serial.println(buttonState);
if (encDelta != 0) {
Serial.print(F("Encoder: ")); Serial.println(encDelta);
#endif
// ADC readings
if (millis() - analyzeTimer >= ANALYZE_INTERVAL) {
readings.addReading(ads.readLastConversion());
analyzeTimer = millis();
// Battery
if (millis() - batteryTimer >= BATTERY_INTERVAL) {
batteryVoltage = A0;
// convert ADC reading to mV
// ref = 3.3V -> mV = adc * 100 / 31
// + factor 2 from divider
batteryVoltage *= (10 * 2);
batteryVoltage /= 31;
batteryVoltage *= 10;
if (batteryVoltage <= BATTERY_THRESHOLD) {
batteryWarning = true;
batteryTimer = millis();
// State machine
switch (state) {
if (millis() - displayTimer >= SPLASH_DELAY) {
state = STATE_ANALYZE;
#ifdef BUZZER_ENABLE
tone(BUZZER_PIN,4000,200);
#endif
case STATE_ANALYZE:
case STATE_HOLD:
// handle inputs
switch (buttonState) {
case ClickEncoder::Clicked:
if (state == STATE_ANALYZE) {
state = STATE_HOLD;
else {
tone(BUZZER_PIN,2000,200);
#endif
case ClickEncoder::Held:
state = STATE_CALIBRATE_MENU;
stateCalibMenu = YES;
#ifdef DEBUG
case ClickEncoder::DoubleClicked: //6
Serial.print(F("ADC reading: ")); Serial.println(readings.getAverage());
Serial.print(F("Sensor µV: ")); Serial.println(sensorMicroVolts);
Serial.print(F("Calib. factor: ")); Serial.println(calibrationFactor);
Serial.print(F("O2 concentration: ")); Serial.println(oxygenConcentration);
Serial.print(F("Battery: ")); Serial.println(batteryVoltage);
tone(BUZZER_PIN,4000,500);
#endif
#endif
if (encDelta > 0) {
stateModDisplay++;
else if (encDelta < 0) {
stateModDisplay--;
if (millis() - displayTimer >= DISPLAY_REFRESH_RATE) {
sensorMicroVolts = ((int32_t)readings.getAverage() * 7812L) / 1000L;
if (sensorMicroVolts <= 0) {
// TODO: ERROR BAD SENSOR
// adjust threshold ? ex. 5mV ?
oxygenConcentration = (int16_t)((sensorMicroVolts * 1000L) / calibrationFactor);
if (oxygenConcentration < 0) {
// TODO: ask for calibration
else if (oxygenConcentration > 10200) {
// TODO: ERROR MODE
// MOD calculation
uint16_t pO2_max, mod;
if (stateModDisplay == MV) {
sprintf_P(displayFooterBuffer, PSTR("Sensor: %d.%02d mV"),
(int16_t)(sensorMicroVolts / 1000L),
(int8_t)((sensorMicroVolts % 1000L) / 10));
else {
switch(stateModDisplay) {
case PPO2_1_4:
pO2_max = 1400;
case PPO2_1_5:
pO2_max = 1500;
case PPO2_1_6:
pO2_max = 1600;
default:
pO2_max = 1000; // you should not be here...
mod = calc_mod(oxygenConcentration, pO2_max);
sprintf_P(displayFooterBuffer, PSTR("pO2 %d.%d > MOD %dm"),
(uint8_t)(pO2_max / 1000),
(uint8_t)((pO2_max % 1000) / 100),
(uint8_t)(mod / 100) );
if (encDelta > 0) {
if (buttonState == ClickEncoder::Clicked) {
state = STATE_CALIBRATE;
calibrateTimer = millis();
else {
// TODO: handle inputs ?
if (millis() - calibrateTimer >= CALIBRATION_TIME) {
// TODO: check calibration sample quality (e.g. max deviation)
// 7812 is ADS resolution in [nV / LSB] at PGA = 16
// 2095 is calibration oxygen concentration (20.95% in air)
int32_t sensorMicroVolts = ((int32_t)readings.getAverage() * 7812L) / 1000L;
calibrationFactor = (int16_t)((sensorMicroVolts * 1000L) / 2095L);
#ifdef DEBUG
Serial.println(F("Calibration complete"));
Serial.print(F("Sensor: ")); Serial.print(sensorMicroVolts); Serial.println(F(" µV"));
Serial.print(F("Calibration factor:")); Serial.println(calibrationFactor);
#endif
EEPROM.put(EEPROM_CALIBRATION_ADDRESS, calibrationFactor);
#ifdef DEBUG
Serial.println(F("Saved to EEPROM"));
#endif
#endif
tone(BUZZER_PIN,3000,500);
#endif
// render
case STATE_ERROR:
// tone(BUZZER_PIN,1000,1000); // would beep continuously - should be activated when entering error mode
#endif
// TODO
if (updateDisplay) {
renderDisplay();
updateDisplay = false;
and this is code that read battery accuratly
#include <Wire.h>
#include "Vcc.h"
// Constants for VCC and battery monitoring
const float VccMin = 0.0; // Minimum expected Vcc level, in Volts.
const float VccMax = 3.303; // Maximum expected Vcc level, in Volts (use a multimeter to measure).
const float VccCorrection = 0.98544; // Tweak this to match your Vcc reading with your multimeter.
const float lowBat = 2.9; // Minimum battery voltage for "dead battery".
const float fullBat = 4.2; // Fully charged battery voltage.
Vcc vcc(VccCorrection); // Vcc object with correction factor
int batt_pin = A0; // Battery is connected to pin A0
// Create U8g2 object for SH1106 OLED 128x64 display (I2C)
U8G2_SH1106_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE); // I2C initialization
Serial.begin(9600); // Start serial communication for debugging
u8g2.begin(); // Initialize OLED display
// Read the VCC voltage by collecting 100 samples
int j;
float v = 0;
for (j = 0; j < 100; j++) {
v += vcc.Read_Volts(); // Read VCC
delay(5);
// Average of 100 VCC voltage samples
v = v / j;
// Display VCC on Serial Monitor
Serial.print("VCC: ");
Serial.println(v, 3); // Print VCC to 3 decimal places
// Read the battery voltage by collecting 100 samples
int i;
float batt_volt = 0;
for (i = 0; i < 100; i++) {
// Using VCC as reference for battery voltage
batt_volt += ((analogRead(batt_pin) * (v / 1023.0)) * 2);
delay(5);
// Average of 100 battery voltage samples
batt_volt = batt_volt / i;
// Display Battery info on Serial Monitor
Serial.print("Battery: ");
Serial.print(batt_volt, 2); // Print battery voltage to 2 decimal places
Serial.print("V ");
// Convert battery voltage to percentage
Serial.print(((batt_volt - lowBat) / (fullBat - lowBat)) * 100);
Serial.println("%");
// Display data on OLED
renderDisplay(v, batt_volt);
delay(100); // Small delay before next reading
void renderDisplay(float vcc, float battVolt) {
// Clear the buffer to prepare the display for new data
u8g2.clearBuffer();
// Set font for display text
u8g2.setFont(u8g2_font_ncenB08_tr);
// Display VCC voltage
u8g2.setCursor(0, 20);
u8g2.print("VCC: ");
u8g2.print(vcc, 3); // Display VCC with 3 decimal places
// Display Battery voltage
u8g2.setCursor(0, 40);
u8g2.print("Battery: ");
u8g2.print(battVolt, 2); // Display battery voltage with 2 decimal places
// Display Battery percentage
float battPercentage = ((battVolt - lowBat) / (fullBat - lowBat)) * 100;
u8g2.setCursor(0, 60);
u8g2.print("Battery %: ");
u8g2.print(battPercentage, 0); // Display battery percentage with no decimals
// Send the buffer to the display
u8g2.sendBuffer();
