arduino + ajax + xml + ThingSpeak
Hey all,
I want to make a remote control system and display sensors parameters so I'm using ThingSpeak to plot graphs and some buttons to control leds, seperatly everything works perfect, but when I add them together ThingSpeak doesnt get a data.
There is a html code:
<html>
    <head >
	<meta http-equiv="Content-Type" content="text/html;charset=UTF-8">
        <title>title</title>
        <script>
		strLED3 = "";
		strLED4 = "";
		var LED3_state = 0;
		var data_val=0;
		var num_updates = 0;	// number of 200ms periods used to calculate time to send data to ThingSpeak
		  function GetArduinoInputs()
		   nocache = "&nocache=" + Math.random() * 1000000;
            var request = new XMLHttpRequest();
            request.onreadystatechange = function()
                if (this.readyState == 4) {
                    if (this.status == 200) {
                        if (this.responseXML != null) {
						document.getElementById("input4").innerHTML =
                               this.responseXML.getElementsByTagName('analog1')[0].childNodes[0].nodeValue;
								                  data_val=this.responseXML.getElementsByTagName('analog1')[0].childNodes[0].nodeValue;
								if (this.responseXML.getElementsByTagName('LED')[0].childNodes[0].nodeValue === "on") {
								document.getElementById("LED3").innerHTML = "ON (TURN OFF)";
								LED3_state = 1;
							    else {
								document.getElementById("LED3").innerHTML = "OFF (TURN ON)";
								LED3_state = 0;
								if (this.responseXML.getElementsByTagName('LED1')[0].childNodes[0].nodeValue === "on") {
								document.getElementById("LED4").innerHTML = "ON (TURN OFF)";
								LED4_state = 1;
							    else {
								document.getElementById("LED4").innerHTML = "OFF (TURN ON)";
								LED4_state = 0;
								if (num_updates >= 100) {
									num_updates = 0;
									// send voltage to ThingSpeak
									ThingSpeakSend("XXXXXXXXXXXXX",data_val);	// insert your ThingSpeak Write API Key here
								num_updates++;
            request.open("GET", "ajax_inputs" + nocache, true);  //request.open("GET", "ajax_inputs" + strLED3 + strLED4 + nocache, true);
            request.send(null);
            setTimeout('GetArduinoInputs()', 200);
			strLED3 = "";
			strLED4 = "";
		function GetButton1()
			if (LED3_state === 1) {
				LED3_state = 0;
				strLED3 = "&LED3=0";
			else {
				LED3_state = 1;
				strLED3 = "&LED3=1";
		function GetButton2()
			if (LED4_state === 1) {
				LED4_state = 0;
				strLED4 = "&LED4=0";
			else {
				LED4_state = 1;
				strLED4 = "&LED4=1";
			// function to send data to ThingSpeak
		function ThingSpeakSend(api_write_key, data)
			var ts_req = new XMLHttpRequest();
			// GET request string - modify if more fields are needed
			var req_str = "http://api.thingspeak.com/update?key=" + api_write_key + "&field1=" + data;
			ts_req.onreadystatechange = function()
				// not doing anything with response from ThingSpeak
			// send the data to ThingSpeak
			ts_req.open("GET", req_str, true);
			ts_req.send(null);
		</script>
    </head>
		 <body onload="GetArduinoInputs()">
		 <button  type="button" id="LED3" onclick="GetButton1()"> OFF (TURN ON) </button>
		 <button  type="button" id="LED4" onclick="GetButton2()"> OFF (TURN ON) </button>
		  <iframe width="450" height="260" style="border: 1px solid #cccccc; margin: 0 0 10px 10px;"
		 src="https://thingspeak.com/channels/235349/charts/1?bgcolor=%23ffffff&color=%23d62020&dynamic=true&results=7&title=%C5%BDem%C4%97s+dr%C4%97gm%C4%97&type=line&xaxis=Data&yaxis=%25&yaxismax=100&yaxismin=0"></iframe>
		  </body>
How I figured out its a problem with a GET message, when I simply write:
graph is plotted, but when I add to this request strings which keep LED states values it doesnt work.
So maybe you could help me?
What is the responseXML with and without the extra parameters? You can examine whats being sent and received from a webpage using Firebug (for Firefox) or the Chrome developer tools- look for the 'Network' tab.
thanks, somehow it started to work even I did nothing to fix it :smiley:
