Arduino and Leap Motion - Black Screen
Hi guys, I have been trying to code using Leap Motion and Arduino to control servo and led using Processing 3.5.4, (both codes attached below), and when I run the processing code, I got black screen. Did I miss anything? I got no error whatsoever when running the code (I think the codes are working fine, yet the black screen and the servo wont move)
// Processing code
import processing.serial.*;
import de.voidplus.leapmotion.*;
LeapMotion leap;
Serial myPort;
  leap = new LeapMotion(this);
  println(Serial.list());
  myPort = new Serial(this,"COM3", 9600);
void draw() {
  background(0);
  for (Hand hand : leap.getHands()) {
      pushMatrix();
      float handSize = hand.getSphereRadius();
      int handSize2 = int(handSize);
      myPort.write(handSize2);
      println(handSize2);
      popMatrix();
#include <Servo.h>
// Arduino code is available to download - link below the video.
Servo m1;
int pos = 0;
int val;
int led = 3;           // the pin that the LED is attached to
int brightness = 0;    // how bright the LED is
int fadeAmount = 5;    // how many points to fade the LED by
// the setup routine runs once when you press reset:
void setup()  {
  pinMode(led, OUTPUT);
  m1.attach(A0);
// the loop routine runs over and over again forever:
void loop()  {
   if (Serial.available() == '\n') { //  Check if there is a new message
      val= Serial.read();
     // 1st fragment
   /*if (val<60) {
    for (pos = 175; pos >= 60; pos -= 1) { // goes from 0 degrees to 180 degrees
    // in steps of 1 degree
    m1.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  if (val>60) {
    for (pos = 60; pos <= 175; pos += 1) { // goes from 180 degrees to 0 degrees
    // 2nd fragment
    val = map(val, 30, 165, 50, 175); // map(value, fromLow, fromHigh, toLow, toHigh)
    m1.write(val);
That does not check for a new message.
See
Serial Basics
You need to check what available returns.
(I mean, it will eventually return that value, but...)
