Arduino using leap motion controller
NEED URGENT HELP!!!
Hey i am trying to control arduino using leap motion controller. For my final year project i need to control the motion of my soft robot using this leap motion device. But in order to start with basic, i was simply testing the Arduino builtin led with leap and see if it can be controlled but unfortunately, i cant.
The reason i understand is that there is some kind of problem with serial communication, cz when i open the serial monitor of arduino, the prcoessing code doesnt run and vice versa. And the error that comes is 'COM3 port busy' Ill share the code for reference.
also i have Processing 3 installed, i hve also tried the latest processsing but it has the same issue as well.
ARDUINO:
int val;
// int led = 3;           // the pin that the LED is attached to
int brightness = 0;    // how bright the LED is
int fadeAmount = 5;    // how many points to fade the LED by
// the setup routine runs once when you press reset:
void setup()  {
  pinMode(LED_BUILTIN, OUTPUT);
// the loop routine runs over and over again forever:
void loop()  {
   if (Serial.available() == '\n') { //  Check if there is a new message
      val= Serial.read();
     // 1st fragment
      if (val<60) {
       digitalWrite(LED_BUILTIN,LOW);
      if (val>60) {
        digitalWrite(LED_BUILTIN,HIGH);
    // 2nd fragment
/*    val = map(val, 30, 165, 0, 255); // map(value, fromLow, fromHigh, toLow, toHigh)
    analogWrite(led, val);*/
PROCESSING:
import processing.serial.*;
// Processing code is available to download - link below the video.
import de.voidplus.leapmotion.*;
LeapMotion leap;
Serial myPort;
  leap = new LeapMotion(this);
  println(Serial.list());
  myPort = new Serial(this, Serial.list()[0], 9600);
void draw() {
  background(0);
  for (Hand hand : leap.getHands()) {
      pushMatrix();
      float handSize = hand.getSphereRadius();
      int handSize2 = int(handSize);
      myPort.write(handSize2);
      println(handSize2);
      popMatrix();
Welcome to the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
I moved your topic to an appropriate forum category @huzefa_turab.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Please edit your post, select all code and click the <CODE/> button and save your post. This will apply so-called code tags to the code which makes it easier to read, easier to copy and the forum software will display it correctly.
Please provide a link; I have no idea what it is.
Only one application can use a serial port at a time. When using your processing application, you can't use the serial monitor in the IDE, when using the serial monitor you can't use the port in the Processing app.
This is normal behaviour.
Here's a link hiving a brief intro about how to use leap with arduino and you'll also know what leap motion controller is.
This one immediately caught my eye: Serial.available() returns the number of bytes available, not a character.
just got another test code from internet, according to me the code is fine but i think my leap motion controller isn't taking the input as the Processing monitor doesnt change the value from 0 to 5 when i bring my hand above.
Processing:
import com.leapmotion.leap.*; //leap motion library
import processing.serial.*; //serial communication library
Controller leap; //define a controller
Serial port; //define a port
void setup(){
  size(250,250); //sketch size
   leap = new Controller(); // initialize the controller
    port = new Serial(this, Serial.list()[0], 9600);//initialize the port in my case its [2]
void draw(){
  FingerList fingers = leap.frame().fingers(); //finger list to get the fingers count
  int count = fingers.count(); // integer holds the count of fingers
  background(0);  // box background color
  fill(255); // text color
  textSize(height/2); // text size
  text(count, 90, 160); // text value and position on the box
 port.write(count+"\r"); // port sends the integer to arduino*/
Arduino:
int c = -1; // int for income value
  Serial.begin(115200); //set serial with baud rate
  if (Serial.available()>0){  //if we have incoming value
      c =Serial.read()-48; //read the value minus 48
  //  Serial.write(c);
    if(c == 0) digitalWrite(LED_BUILTIN,LOW); //if 0 fingers turn off led
    else if(c == 5) digitalWrite(LED_BUILTIN,HIGH); //if 5 fingers turn on led
Do you see a mismatch :slight_smile:
Note: comments that don't match the statement are totally useless and often confusing.
Work on one part first. I suggest that you get your Arduino code perfectly working with serial monitor; next you write the matching Processing code.
Yes thanks, i made that correction. However, i still cant get it to work :frowning:
