Arduino and nrf24l01+ code debugging <solved>
EDIT: I ended up fixing the code, I made a stupid typo >.<. I corrected the code in the post below in case anyone wanted to use it now or in the future.
I am trying to get a duemilanove to send data from a sensor to the arduino mega. I have connected both transievers with the proper spi pins for each board. The reg_read works when run on both devices. However when i try my code, the sender has proper output on serial, but the reciever has wierd output. Its just a bunch of exclamation marks:
Sender (Duemilanove):
/*Client
NANO 328:
    MISO -> 12
    MOSI -> 11
    SCK -> 13
    CE -> 8
    CSN -> 7
    GND -> GND
    VCC -> 3.3v
#include <SPI.h>
#include <Mirf.h>
#include <MirfHardwareSpiDriver.h>
#include <MirfSpiDriver.h>
#include <nRF24L01.h>
#include "DHT.h"
#define DHTPIN 2     // what pin we're connected to
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11   // DHT 11
#define DHTTYPE DHT11   // DHT 22  (AM2302)
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
DHT dht(DHTPIN, DHTTYPE);
// converts a float into a char
// and sends it via nRF24L01
void transmitf( float v)
  byte c;
  char buf[10];
  dtostrf(v,9,3,buf);
  for( int i=0 ; i<8 ; i++ )
    c = buf[i];
    Mirf.send(&c);
    while( Mirf.isSending() ) ;
// sends a string via the nRF24L01
void transmit(const char *string)
  byte c;
  for( int i=0 ; string[i]!=0x00 ; i++ )
    c = string[i];
    Mirf.send(&c);
// send a CR/LF sequence via the nRF24L01
void transmitlf(void)
  byte c;
  c = '\r';
  Mirf.send(&c);
  c = '\n';
  Mirf.send(&c);
  Mirf.cePin = 8;
  Mirf.csnPin = 7;
  // init the transceiver
  Mirf.spi = &MirfHardwareSpi;              //  ad this
  Mirf.init();
  // we transmit only a single byte each time
  Mirf.payload = 1;
  // selecting a channel which is not too noisy
  Mirf.channel = 90;
  Mirf.config();
  // Set 1MHz data rate
  Mirf.configRegister(RF_SETUP,0x06);
  // Set address - this one must match the
  // address the receiver is using!
  Mirf.setTADDR((byte *)"send1");
   dht.begin();
  float v01,v02;
  // read in some values
  v01 = dht.readHumidity();
  v02 = dht.readTemperature();
  // transmit a fixed token
  transmit(" : ");
  // transmit the first value
  transmit(v01);
  transmit(" % ");
  // transmit a separator
  transmit(" : ");
  // transmit a second token
  transmit(v02);
  transmit(" C ");
  // transmit a CR/LF for the PC
  // software to sync to
  transmitlf();
 Serial.println(v01);
  // ... just take your time
  delay(100);
Reciever (Mega 1280):
/*Server
MEGA 2560:
    MISO -> 50
    MOSI -> 51
    SCK -> 52
    CE -> 8
    CSN -> 7
    GND -> GND
    VCC -> 3.3v
#include <SPI.h>
#include <Mirf.h>
  Serial.begin(57600);
  Mirf.cePin = 8;
  Mirf.csnPin = 7;
  Mirf.init();
  // name the receiving channel - must match tranmitter setting!
  Mirf.setRADDR((byte *)"send1");
  // just a single byte is transmitted
  Mirf.payload = 1;
  // we use channel 90 as it is outside of WLAN bands
  // or channels used by wireless surveillance cameras
  Mirf.channel = 90;
  // now config the device....
  Mirf.config();
  // Set 1MHz data rate - this increases the range slightly
  Serial.println("Starting");
  byte c;
  // is there any data pending?
  if( Mirf.dataReady() )
     // well, get it
     Mirf.getData(&c);
    // ... and write it out to the PC
     Serial.print(c);
