Nrf24l01 Problems with Arduino Uno and Teensy 4.0
Hello!
I am trying to make a rc airplane with arduinos. I am currently fighting with the NRF24l01 to work because it will not seem to work. Before anyone says anything, I did solder a 10uf capacitor to the pwr and ground pins on both the nrfs with no luck. Additionally I have checked the power with a multimeter and it is staying solidly at 3.3 with no signs of instability. I also triple checked the wiring of both of them. I also twisted a ground wire around both the miso and mosi wires for both the receiver and the transmitter, again with no luck. I also tried replacing the nrf's with other modules I have around and still had no luck.
I also tried another program and it seemed to work and transmitted and recieved properly so it seems the problem is for sure in the code.
Here is the transmitter code(Arduino Uno):
        DIY Arduino based RC Transmitter
  by Dejan Nedelkovski, www.HowToMechatronics.com
  Library: TMRh20/RF24, https://github.com/tmrh20/RF24/
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
// Define the digital inputs
#define jB1 1  // Joystick button 1
#define jB2 0  // Joystick button 2
#define t1 7   // Toggle switch 1
#define t2 4   // Toggle switch 1
#define b1 8   // Button 1
#define b2 9   // Button 2
#define b3 2   // Button 3
#define b4 3   // Button 4
float elapsedTime, currentTime, previousTime;
int c = 0;
RF24 radio(5, 6);   // nRF24L01 (CE, CSN)
const byte address[6] = "00001"; // Address
// Max size of this struct is 32 bytes - NRF24L01 buffer limit
struct Data_Package {
  byte j1PotX;
  byte j1PotY;
  byte j1Button;
  byte j2PotX;
  byte j2PotY;
  byte j2Button;
  byte pot1;
  byte pot2;
  byte tSwitch1;
  byte tSwitch2;
  byte button1;
  byte button2;
  byte button3;
  byte button4;
Data_Package data; //Create a variable with the above structure
  // Initialize interface to the MPU6050
  // Call this function if you need to get the IMU error values for your module
  //calculate_IMU_error();
  // Define the radio communication
  radio.begin();
  radio.openWritingPipe(address);
  radio.setAutoAck(false);
  radio.setDataRate(RF24_250KBPS);
  radio.setPALevel(RF24_PA_LOW);
  // Activate the Arduino internal pull-up resistors
  pinMode(jB1, INPUT_PULLUP);
  pinMode(jB2, INPUT_PULLUP);
  pinMode(t1, INPUT_PULLUP);
  pinMode(t2, INPUT_PULLUP);
  pinMode(b1, INPUT_PULLUP);
  pinMode(b2, INPUT_PULLUP);
  pinMode(b3, INPUT_PULLUP);
  pinMode(b4, INPUT_PULLUP);
  // Set initial default values
  data.j1PotX = 127; // Values from 0 to 255. When Joystick is in resting position, the value is in the middle, or 127. We actually map the pot value from 0 to 1023 to 0 to 255 because that's one BYTE value
  data.j1PotY = 127;
  data.j2PotX = 127;
  data.j2PotY = 127;
  data.j1Button = 1;
  data.j2Button = 1;
  data.pot1 = 1;
  data.pot2 = 1;
  data.tSwitch1 = 1;
  data.tSwitch2 = 1;
  data.button1 = 1;
  data.button2 = 1;
  data.button3 = 1;
  data.button4 = 1;
  // Read all analog inputs and map them to one Byte value
  data.j1PotX = map(analogRead(A1), 0, 1023, 0, 255); // Convert the analog read value from 0 to 1023 into a BYTE value from 0 to 255
  data.j1PotY = map(analogRead(A0), 0, 1023, 0, 255);
  data.j2PotX = map(analogRead(A2), 0, 1023, 0, 255);
  data.j2PotY = map(analogRead(A3), 0, 1023, 0, 255);
  data.pot1 = map(analogRead(A7), 0, 1023, 0, 255);
  data.pot2 = map(analogRead(A6), 0, 1023, 0, 255);
  // Read all digital inputs
  data.j1Button = digitalRead(jB1);
  data.j2Button = digitalRead(jB2);
  data.tSwitch2 = digitalRead(t2);
  data.button1 = digitalRead(b1);
  data.button2 = digitalRead(b2);
  data.button3 = digitalRead(b3);
  data.button4 = digitalRead(b4);
  // If toggle switch 1 is switched on
  // Send the whole data from the structure to the receiver
  radio.write(&data, sizeof(Data_Package));
  Serial.println(data.j1PotX);
And here is the receivers code(Teensy 4.0):
#include <SPI.h>
#include <RF24.h>
#include <Servo.h>
RF24 radio(10, 9);   // nRF24L01 (CE, CSN)
unsigned long lastReceiveTime = 0;
unsigned long currentTime = 0;
Servo throttle1;  // create servo object to control the ESC
Servo throttle2;
Servo rudderServo;
Servo elevatorServo;
Servo aileron1Servo;
Servo aileron2Servo;
int throttleValue, rudderValue, elevatorValue, aileron1Value, aileron2Value, travelAdjust;
  byte j1PotX;
  byte j1PotY;
  byte j1Button;
  byte j2PotX;
  byte j2PotY;
  byte j2Button;
  byte pot1;
  byte pot2;
  byte tSwitch1;
  byte tSwitch2;
  byte button1;
  byte button2;
  byte button3;
  byte button4;
void resetData() {
  // Reset the values when there is no radio connection - Set initial default values
  data.j1PotX = 127;
  data.j1PotY = 80; // Motors stops // the central point of the joystick is not starting point for the throttle, its at value of 80 instead of 127
  data.j2PotX = 127;
  data.j2PotY = 127;
  data.j1Button = 1;
  data.j2Button = 1;
  data.pot1 = 1;
  data.pot2 = 1;
  data.tSwitch1 = 1;
  data.tSwitch2 = 1;
  data.button1 = 1;
  data.button2 = 1;
  data.button3 = 1;
  data.button4 = 1;
  radio.begin();
  radio.openReadingPipe(0, address);
  radio.setPALevel(RF24_PA_MAX);
  radio.startListening(); //  Set the module as receiver
  resetData();
  throttle1.attach(2);
  throttle2.attach(4);
  rudderServo.attach(7);   // CH1
  elevatorServo.attach(8); // CH2
  aileron1Servo.attach(5); // CH3
  aileron2Servo.attach(6); // CH4
// throt L   - 2
// throt R   - 4
// alerion L - 5
// alerion R - 6
// rud       - 7
// elevator  - 8
  // Check whether we keep receving data, or we have a connection between the two modules
  currentTime = millis();
  if ( currentTime - lastReceiveTime > 1000 ) { // If current time is more then 1 second since we have recived the last data, that means we have lost connection
    resetData(); // If connection is lost, reset the data. It prevents unwanted behavior, for example if a drone jas a throttle up, if we lose connection it can keep flying away if we dont reset the function
  // Check whether there is data to be received
  if (radio.available()) {
    radio.read(&data, sizeof(Data_Package)); // Read the whole data and store it into the 'data' structure
    lastReceiveTime = millis(); // At this moment we have received the data
  // Controlling throttle - brushless motor with ESC
  throttleValue = constrain(data.j1PotY, 80, 255); // Joysticks stays in middle. So we only need values the upper values from 130 to 255
  throttleValue = map(throttleValue, 80, 255, 1000, 2000);
  throttle1.writeMicroseconds(throttleValue);
  throttle2.writeMicroseconds(throttleValue);
  // Adjusting the servos responsiveness
  travelAdjust = map(data.pot2, 0, 255, 0, 25);
  // Elevator control
  elevatorValue = map(data.j2PotY, 0, 255, (85 - travelAdjust), (35 + travelAdjust));
  elevatorServo.write(elevatorValue);
  // Ailerons control
  aileron1Value = map(data.j2PotX, 0, 255, (10 + travelAdjust), (80 - travelAdjust));
  aileron1Servo.write(aileron1Value);
  aileron2Servo.write(aileron1Value);
  // Rudder trimming function
  if (data.j1PotX > 127) {
    rudderValue = data.pot1 + (data.j1PotX - 127);
  if (data.j1PotX < 127) {
    rudderValue = data.pot1 - (127 - data.j1PotX);
  // Rudder control
  rudderValue = map(rudderValue, 0, 255, (10 + travelAdjust), (90 - travelAdjust));
  rudderServo.write(rudderValue);
It is code I used from a tutorial by "How to Mechatronics" and edited to fit my needs.
Currently on the serial monitor for the transmitter it outputs the value of j1PotX as it should, but the receiver just outputs 127, which is the value it should output if it has no signal.
Can someone give me a list of more things to trouble shoot the nrf modules or show me how to fix my code so it works properly? Thank you!
very similar sketches:
why not asking there?
Recvr:
#include <SPI.h>
#include <RF24.h>
#include <Servo.h>
  uint8_t j1PotX;
  uint8_t j1PotY;
  uint8_t j1Button;
  uint8_t j2PotX;
  uint8_t j2PotY;
  uint8_t j2Button;
  uint8_t pot1;
  uint8_t pot2;
  uint8_t tSwitch1;
  uint8_t tSwitch2;
  uint8_t button1;
  uint8_t button2;
  uint8_t button3;
  uint8_t button4;
void resetData() {
  data.j1PotX = 127;
  data.j1Button = 1;
  data.j2PotX = 127;
  data.j2PotY = 127;
  data.j2Button = 1;
  data.pot1 = 1;
  data.pot2 = 1;
  data.tSwitch1 = 1;
  data.tSwitch2 = 1;
  data.button1 = 1;
  data.button2 = 1;
  data.button3 = 1;
  data.button4 = 1;
  radio.begin();
 // resetData();
    Serial.println(currentTime - lastReceiveTime);
    char Text[30];
    sprintf(Text, "03%u 03%u 03%u 03%u 03%u 03%u\r\n", data.j1PotX, data.j1PotY, data.j2PotX, data.j2PotY, data.pot1, data.pot2);
    Serial.println(Text);
Post your schematic and some pictures be sure to show all power sources, grounds and note any lead over 10"/25cm.
