Arduino and SmartThings Relay interface
I have the following boards:
Arduino Uno Rev3
Seeed Studio Relay Shield https://www.seeedstudio.com/Relay-Shield-v3.0-p-2440.html#
SmartThings Shield https://support.smartthings.com/hc/en-us/articles/213652126-SmartThings-Shield-for-Arduino
I am trying to adapt the code from SmartThings to switch a relay on for 1 second when the On command is sent and switch a second relay on for a one second duration when the Off command is sent via SmartThings.
I have tried adding the basic code to the prewritten SmartThings Sketch however I am struggling to get it to work.
I want to assign relay1 to pin 7 and relay2 to pin 6 with a one second activation of the relay before it returns to its none energized state. effectively a momentary make switch.
Any assistance with this would be much appreciated.
the Sketch is below:
/// @file
/// @brief
///   Arduino SmartThings Shield LED Example with Network Status
/// @note
///              ______________
///             |         SW[] |
///             |[]RST         |
///             |         AREF |--
///             |          GND |--
///             |           13 |--X LED
///             |           12 |--
///             |           11 |--
///           --| 3.3V      10 |--
///           --| 5V         9 |--
///           --| GND        8 |--
///           --| GND          |
///           --| Vin        7 |--
///             |            6 |--
///           --| A0         5 |--
///           --| A1    ( )  4 |--
///           --| A2         3 |--X THING_RX
///           --| A3  ____   2 |--X THING_TX
///           --| A4 |    |  1 |--
///           --| A5 |    |  0 |--
///             |____|    |____|
///                  |____|
#include <SoftwareSerial.h>   //TODO need to set due to some weird wire language linker, should we absorb this whole library into smartthings
#include <SmartThings.h>
// Pin Definitions    | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
//                    V V V V V V V V V V V V V V V V V V V V V V V V V V V V V
#define PIN_LED         13
#define PIN_THING_RX    3
#define PIN_THING_TX    2
// Global Variables   | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
SmartThingsCallout_t messageCallout;    // call out function forward decalaration
SmartThings smartthing(PIN_THING_RX, PIN_THING_TX, messageCallout);  // constructor
bool isDebugEnabled;    // enable or disable debug in this example
int stateLED;           // state to track last set value of LED
int stateNetwork;       // state of the network
// Local Functions  | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
//                  V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V
void on()
 stateLED = 1;                 // save state as 1 (on)
 digitalWrite(PIN_LED, HIGH);  // turn LED on
 smartthing.shieldSetLED(0, 0, 2);
 smartthing.send("on");        // send message to cloud
void off()
 stateLED = 0;                 // set state to 0 (off)
 digitalWrite(PIN_LED, LOW);   // turn LED off
 smartthing.shieldSetLED(0, 0, 0);
 smartthing.send("off");       // send message to cloud
void setNetworkStateLED()
 SmartThingsNetworkState_t tempState = smartthing.shieldGetLastNetworkState();
 if (tempState != stateNetwork)
   switch (tempState)
     case STATE_NO_NETWORK:
       if (isDebugEnabled) Serial.println("NO_NETWORK");
       smartthing.shieldSetLED(2, 0, 0); // red
     case STATE_JOINING:
       if (isDebugEnabled) Serial.println("JOINING");
     case STATE_JOINED:
       if (isDebugEnabled) Serial.println("JOINED");
       smartthing.shieldSetLED(0, 0, 0); // off
     case STATE_JOINED_NOPARENT:
       if (isDebugEnabled) Serial.println("JOINED_NOPARENT");
       smartthing.shieldSetLED(2, 0, 2); // purple
     case STATE_LEAVING:
       if (isDebugEnabled) Serial.println("LEAVING");
     default:
     case STATE_UNKNOWN:
       if (isDebugEnabled) Serial.println("UNKNOWN");
       smartthing.shieldSetLED(0, 2, 0); // green
   stateNetwork = tempState;
// API Functions    | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
 // setup default state of global variables
 isDebugEnabled = true;
 stateLED = 0;                 // matches state of hardware pin set below
 stateNetwork = STATE_JOINED;  // set to joined to keep state off if off
 // setup hardware pins
 pinMode(PIN_LED, OUTPUT);     // define PIN_LED as an output
 digitalWrite(PIN_LED, LOW);   // set value to LOW (off) to match stateLED=0
 if (isDebugEnabled)
 { // setup debug serial port
   Serial.begin(9600);         // setup serial with a baud rate of 9600
   Serial.println("setup..");  // print out 'setup..' on start
 // run smartthing logic
 smartthing.run();
 setNetworkStateLED();
void messageCallout(String message)
 // if debug is enabled print out the received message
 if (isDebugEnabled)
   Serial.print("Received message: '");
   Serial.print(message);
   Serial.println("' ");
 // if message contents equals to 'on' then call on() function
 // else if message contents equals to 'off' then call off() function
 if (message.equals("on"))
   on();
 else if (message.equals("off"))
   off();
[code
[/code]
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Also links to your two shields please.
Tom I made the amendments thanks, are you able to shed any light on my request ?
Thanks.... Tom.. :slight_smile:
Tom please see the amended message the links are next to each of the shield except the Arduino Uno that is a Rev 3 unit.
If you are going to stack them.
Check which pins are used by each shield.
Apart from 5V, 3.3V and gnd pins check if both shields try and use the same pin.
Please try not to go back and edit/correct a post after a mistake has been shown, as it can cause confusion to anybody in future using this thread as a possible solution to their problem.. :slight_smile:
