Hello everyone, this is my very first post.
I want to buy an Arduino this week but first I want to clarify some things, because I already have a project in mind.
I need to create an application, let's say in Visual C++, or any other programming language in order to control Arduino. The most important thing is that I need it to be graphical, I need the application to be a window with, let's say, 3 buttons drawn in it, and every time I click the button the correct LED to light on the board. Is it generally possible to do this? I searched a lot and never got a clear answer, I've seen people even use PHP to get the Arduino working, but I want more info on how it's done.
I would think that you need to build a sketch with the arduino IDE (looks like its based on processing) and then have the arduino look for serial data to control which pins to switch and how.
then just code something in Visual C++ to send these commands to it with the com ports. I tried something like this before with Visual BASIC but couldnt get it to work right. I think it was a hardware issue with my PC (either that or I just couldnt figure it out lol)
Thanks for the quick reply, at least now I know it's possible
Do you know of any examples, something I could get started with? Maybe a source code or smth...
Personally I would use VB for this (I don't have directly applicable VB code but if you decide to use VB can post something to get you started), however from what I've seen "Procesing" may be a perfect match for what you want to do.
Bottom line is that this is well doable, so go ahead and buy your hardware.
Depending on which version of Visual Studio you have, it may or may not include C# capabilities. If it does, it is incredibly easy to design forms in C#. C# also makes it very easy to read from/write to the serial port, which is what you need to do in order to communicate with the Arduino.
Oh sure! But see... That's the problem. I am at work away from my computer, but it was an example I got online somewhere. I think it was about a year ago.
This code shows how you can type text into a line and it will send it to the arduino, and then the arduino will send it back and it will paste what you sent it into a line below. Same concept, just that instead of a button, it's text.
I am not putting the code here since it's a personal deal from another site.
