I'm building an Arduino based alarm monitor. I have normally closed door sensors installed and wired to my Arduino.
5v -> door sensor -> digialPin
Normally the circuit is closed. Do I need a resistor between 5v and the digital pin? When a digitalPin is set to INPUT it seems to have a pretty high resistance?
I was trying to be efficient. No sense in have a closed circuit that's pumping a bunch of electricity through it. Would a resistor in-live save me some electricity, and maybe a little heat?
Reversed... there is electricity flow when the doors are closed (which is most of the time).
Part of the reason I asked is because if I put an LED inline with the door sensor and input pin it lights up really dim. It's like there is some sort of internal resistance on the digital pins.
