I want my Arduino Mega to output certain data bits when a certain I2C address is called - so I guess I want it to be a slave to either my computer or to a second Arduino. It is taking in data from a sensor so it is already an I2C master to an IMU.
Is this possible? Or am I thinking about this the wrong way, sorry I am new to I2C protocol and still trying to understand what I can do.
Thanks!
Your line of thinking is perfectly alright with a little bit off-track. I am converting you idea into a block diagram which will certainly help you to do the I2C Bus coding.
1. UNO is Master; MEGA is Slave-1 with 7-bit (0x08 = 0b0001000) I2C Bus address; MPU6050 is Slave-2 with 7-bit (0x69 = 0b1101001) I2C Bus address. MEGA is not working as the Master of Slave-2. This is possible in the Multi-master I2C Network which is not being currently supported by Arduino.
2. The I2C Bus is created by including the following lines at the appropriate place of the sketch.
#include<Wire.h>
Wire.begin();
3. Before exchanging data with Slave-1 (for example), the Master checks the presence of Slave-1 by executing the following codes in the setup() function.
Wire.beginTransmission(slave1Address); //0x08
byte busStatus = Wire.endTransmission();
if(busStatus !=0x00)
Serial.print("Slave is absent....!");
while(1); //wait for ever
4. In I2C Bus, the data exchange is always 1-byte at a time. The Master executes the following codes of lines to transfer data byte 0x35 (for example) to Slave-1.
Wire.write(0x35); //data byte 0x35
5. When the data byte(s) has reached to the Slave and then has entered into the FIFO, the Slave goes to the void receiveEvent(int howMany){} sub-program (an interrupt context; no Serial.print()/write() commands are recommended). The user now can read the data byte(s) from the FIFO and save them into variables. For the said sub-program to become effective, the following declaration should be made in the setup() function of Slave-1.
Wire.onReceive(receiveEvent);.
6. ................................
Block diagram is great thank you! Really helps me visualise how to get started - just a few quick questions...
- Read info from IMU
- Send back bytes received from address corresponding to the command
And just have different conditions for the different sensors
Thanks again for help - I just want to get the idea right in my head before I try to code it!
RachelDunwoody:
- Could I control both Arduinos from the same PC?
Yes! You can open two Serial Monitors SM1 and SM2 in the desktop of one PC. In the diagram of Post#1, they are actually one PC though 2 PCs are shown for clarity.
- If the Mega is slave address 0x08 - Can I access the different addresses on the IMU or is it more - if UNO sends a certain command
The MEGA will never conflict with the register addresses of the IMU. The IMU's registers are accessed through the gate of IMU's Bus address.
