Arduino as ssc servo controller.
Hi, i'm using arduino as a servo controler, with the library servo.h > Arduino Playground - Servo
And the code of this page: (i use almost the same but simpled, without some options that i don't use)
#include <Servo.h>
Servo servo1; Servo servo2;
  pinMode(1,OUTPUT);
  servo1.attach(14);
  servo1.setMaximumPulse(2200);
  servo2.attach(15);
  Serial.begin(19200);
  Serial.print("Ready");
  static int v = 0;
  if ( Serial.available()) {
    char ch = Serial.read();
    switch(ch) {
      case '0'...'9':
        v = v * 10 + ch - '0';
      case 's':
        servo1.write(v);
        v = 0;
      case 'w':
        servo2.write(v);
        v = 0;
      case 'd':
        servo2.detach();
      case 'a':
        servo2.attach(15);
  Servo::refresh();
A ssc servo controller uses this 3 serial bytes:
Byte 1 Byte 2 Byte 3
[sync marker (255)] [servo # (0-254) [position (0-254)]
How can it be done? i'm newbie in programming, and i think that it will be usefull because there are a lot of generic software to control the mini ssc..
I'm planning to do a robot arm like Lynxmotion arm, but with my own design.. i want to sensorize it and make it independent from pc with arduino board..
Thanks
Nobody knows about it?
is only to separate the ch variable in 3 bytes, but i don't know how...
Thanks
Does this fragment help?
 void processRequest(char servo, char position) {
     // tell the given servo to go to the given position
     // your servo code here
    if(ch == 255){  // handle request only after getting a sync byte
        char servo, position;
        servo = Serial.read();
        position = Serial.read();
        processRequest(servo, position);
