I'm attempting to make this project. https://www.instructables.com/id/Arduino-Based-Lap-Timer/
Here is the code from that.
#include <Wire.h>
#include <EEPROM.h>
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
#include <SoftwareSerial.h>
SoftwareSerial Thermal(3, 2);
Adafruit_7segment matrixGreen = Adafruit_7segment();
Adafruit_7segment matrixRed = Adafruit_7segment();
int photocellPin = 7;
int photocellReading;
int photocellBreak = 0;
int lapCount = 0;
int lapTime = 0;
int lapTimes[10];
int FastestLap = 6000;
int minLaptime = 1000;
int clockSync = 7600;
int totalTime = 0;
int TotalLaps = 3;
int heatTime = 80;
int heatInterval = 255;
char printDensity = 15;
char printBreakTime = 15;
float timeprint;
pinMode(A1, INPUT_PULLUP);
pinMode(7, INPUT_PULLUP);
matrixGreen.begin(0x70); // no address soldered
matrixRed.begin(0x71); // A1 soldered
matrixGreen.print(10000, DEC);
matrixRed.print(10000, DEC);
matrixGreen.writeDisplay();
matrixRed.writeDisplay();
//EEPROM.put ( 0, FastestLap);
Thermal.begin(19200); // to write to our new printer
initPrinter();
DisplayText(0);
int Whattodo = 0;
Whattodo = Button();
Serial.println(Whattodo, DEC);
if (Whattodo == 1) {
LapTime(TotalLaps);
if (Whattodo == 2) {
Serial.println("Set Laps");
SetLaps();
void SetLaps() {
int l;
int la;
int b;
DisplayText(1);
la = analogRead(A2);
b = analogRead(A1);
while (b < 200 or b > 300) {
l = map(la,1023,0,1,9);
matrixRed.print(l, DEC);
delay(10);
b = analogRead(A1);
TotalLaps = l;
void DisplayText(int T) {
// 1 = Laps
if (T==0) {
matrixGreen.writeDigitRaw(0,B01000000);
matrixGreen.writeDigitRaw(1,B01000000);
matrixGreen.writeDigitRaw(3,B01000000);
matrixGreen.writeDigitRaw(4,B01000000);
matrixRed.writeDigitRaw(0,B01000000);
matrixRed.writeDigitRaw(1,B01000000);
matrixRed.writeDigitRaw(3,B01000000);
matrixRed.writeDigitRaw(4,B01000000);
if (T ==1) {
matrixGreen.writeDigitRaw(0,B00111000);
matrixGreen.writeDigitRaw(1,B01110111);
matrixGreen.writeDigitRaw(3,B01110011);
matrixGreen.writeDigitRaw(4,B01101101);
int Button() {
int select = 0;
int b = analogRead(A1);
while (b > 900) {
b = analogRead(A1);
if (b > 400 and b < 500) {
select = 1;
if (b > 300 and b < 400) {
select = 2;
if (b > 200 and b < 300) {
select = 3;
return select;
void initPrinter()
//Modify the print speed and heat
Thermal.write(27);
Thermal.write(55);
Thermal.write(7); //Default 64 dots = 8*('7'+1)
Thermal.write(heatTime); //Default 80 or 800us
Thermal.write(heatInterval); //Default 2 or 20us
//Modify the print density and timeout
Thermal.write(18);
Thermal.write(35);
int printSetting = (printDensity<<4) | printBreakTime;
Thermal.write(printSetting); //Combination of printDensity and printBreakTime
void LapTime(int Laps){
RaceStatus(0);
photocellReading = 0;
lapTime = 0;
lapCount = 0;
photocellReading = digitalRead(photocellPin);
while (photocellReading == photocellBreak ) {
photocellReading = analogRead(photocellPin);
if (analogRead(A1) > 200 and analogRead(A1) < 300) {
Serial.println("Back to menu");
return;
matrixGreen.print((Laps), DEC);
matrixGreen.drawColon(false);
matrixRed.print(0, DEC);
matrixRed.drawColon(true);
for (int x=0; x<10; x++) { lapTimes[x] = 0; }
while (photocellReading != photocellBreak) { // wait for start of Race
return;
// Start LapTiming!!!
while (lapCount < Laps) {
matrixGreen.print((Laps - lapCount - 1), DEC);
while (photocellReading != photocellBreak or lapTime < minLaptime ) {
delayMicroseconds(clockSync);
lapTime = lapTime+1;
matrixRed.print(lapTime, DEC);
return;
EEPROM.get(0, FastestLap);
if (lapTime < FastestLap) {
EEPROM.put ( 0, lapTime);
lapTimes[lapCount] = lapTime;
lapCount++;
lapTime = 0;
Thermal.println("Crazy Kart Race Results! ");
Thermal.println("=========================");
totalTime = 0;
for (int l=0; l<Laps; l++){
Thermal.print("Lap ");
Thermal.print(l +1);
Thermal.print(": ");
totalTime = totalTime + lapTimes[l];
timeprint = (float)lapTimes[l]/100;
Thermal.print(timeprint,2);
Thermal.println(" seconds");
Thermal.write(10);
Thermal.print("Total: ");
Thermal.println(TimeFormat(totalTime));
Thermal.write(10);
Thermal.write(10);
String TimeFormat(int t) {
int millisec = t % 100;
int tseconds = t /100;
int tminutes = tseconds / 60;
int seconds = tseconds % 60;
String timestring = "";
if (tminutes == 0) {
timestring = String(seconds,DEC) + "." + String(millisec, DEC) + " Seconds";
if (tminutes == 1) {
timestring = String(tminutes,DEC) + " Minute " + String(seconds,DEC) + "." + String(millisec, DEC) + " Seconds";
if (tminutes > 1) {
timestring = String(tminutes,DEC) + " Minutes " + String(seconds,DEC) + "." + String(millisec, DEC) + " Seconds";
return timestring;
void RaceStatus(int Status) {
if (Status == 0) {
if (Status == 1) {
matrixGreen.print(FastestLap, DEC);
matrixGreen.drawColon(true);
I have a E3F-5DN1 NPN NO through beam sensor and the Arduino Uno. I'd like to bench test the concept before I spend too much money on this.
I've been looking for a simple example to connect the Sensor to the Uno and monitor the times through the serial monitor.
If the code above was modified to use Serial.println and accept the serial input to set and reset the race options I could test this much easier.
Does anyone have an example like that?
