ok, Robin2, lets start from the beginning with me giving all information (Stupid that I didn't share the circuits from the beginning... sorry about that.
I tried my best to to these in an online circuit builder, tell me if you want me to do a schematic instead. I'd be happy to do it.
The modules connect fine to each other (both light up green) but I have get two problems that I don't get:
1 - the value i read from the bluetooth is appr. 48 when the button on the slave is NOT pushed and appear. 76 when pushed. I have no idea why.
2 - The values stop updating in the serial monitor i.e it doesn't read the bluetooth after a couple of seconds (5-10s i would guess). I tried to put in a count (count++; Serial.println(count) ) and showed that the read (or print from the other module, I have no idea) stops after 6500-700 iterations
So here are the connection details and codes:
MASTER
SLAVE
And the codes
MASTER
#include <SoftwareSerial.h>
int LED_RED = 6;
int LED_YELLOW = 7;
int ledPin = 12;
int value_BT = 0;
int bluetoothTx = 9; // TX-O pin of Bluesmirf silver, Arduino D9
int bluetoothRx = 10; // RX-I pin of Bluesmirf silver, Arduino D10
SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
pinMode(LED_YELLOW, OUTPUT);
pinMode(LED_RED, OUTPUT);
pinMode(ledPin, OUTPUT);
pinMode(bluetoothTx, INPUT);
pinMode(bluetoothRx, OUTPUT);
///Indicating that this is the master
led_indicate_master();
bluetooth.begin(115200);
bluetooth.print("$$");
delay(100);
bluetooth.println("SM,1");
delay(100);
bluetooth.println("C,000666643C3D");
delay(100);
bluetooth.println("---");
Serial.println("Debugging works");
if (bluetooth.available() > 0) {
value_BT = bluetooth.read();
Serial.println(value_BT);
void led_indicate_master() {
digitalWrite(LED_YELLOW, HIGH);
digitalWrite(LED_RED, HIGH);
digitalWrite(LED_YELLOW, LOW);
digitalWrite(LED_RED, LOW);
delay(50);
delay(50);
delay(50);
SLAVE
int LED_RED = 5;
int LED_GREEN = 6;
int value_BT = 0;
int ledPin = 11;
int buttonPin = 12;
int buttonState = 0;
pinMode(LED_GREEN, OUTPUT);
///Indicating that this is the slave
led_indicate_slave();
delay(100);
bluetooth.println("SM,0");
delay(100);
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH) {
value_BT = 1;
digitalWrite(ledPin, HIGH);
bluetooth.print(value_BT);
value_BT = 0;
digitalWrite(ledPin, LOW);
void led_indicate_slave() {
digitalWrite(LED_GREEN,HIGH);
digitalWrite(LED_RED,HIGH);
delay(5000);
digitalWrite(LED_GREEN,LOW);
digitalWrite(LED_RED,LOW);
delay(50);
firmaj:
Thanks for all that. I will have a careful look at your code later today when I have some more time. In the meantime can you confirm that the code you have posted is the code that you referred to in Reply #19 as "successfully connected the two bluesmirfs which would suggest that the read and print works" And (now that I have read that quotation more closely) can you confirm whether you have actually sent and received data with that program.
I have had a quick look at the code. I don't see how it can possibly work because it is trying to use SoftwareSerial at 115200 baud. I'm pretty sure I made that point earlier.
We need to start with a piece of code that actually works. One of your Arduinos has Serial1 (HardwareSerial) which will work at 115200 baud if that is essential. Start (as I said earlier) with some code that makes that Arduino work in conjunction with your PC.
When I say "something that works" I mean the ability to send and receive text - eg "Hello World"
If you think what I am saying is wrong (it would not be the first time) please explain your reasoning and provide the evidence.
Your diagrams seem to be clear. Many of the same type are not and a photo of a pencil-drawn schematic is usually the best way to show connections.
Yes you did mention that earlier. I think I disregarded it because I thought all was good as it connected fine with the other bluetooth. But i'll try to take the default baud rate of the Bluesmirf modules down to 9600 and software serial.
I thought I've tried changing the baud rate to 9600 before.... but the only thing I did was typing softwareserial.begin(9600). Of course I have to change the baud rate of the modules as well........ Now it works...
You have no idea how long I've sat with this, you sir (Robin2) are an angel! Why is it that it doesn't work with a high baud rate?
My button is sent successfully and lights the Led on the other unit via BT perfectly. The only thing I'm wondering is why a '0' is sent as '48' and '1' as '49'. Why does it start at 48?
firmaj:
SoftwareSerial is a very poor substitute for a hardware USART.
Now I can go on with the project after getting the BT to work.
Couldn't do it without you Robin2!
EDIT:
If anyone has the same difficulties as me I used this code to set the baud rate on the softwareserial and the Bluesmirf module (The last three lines are the important ones):
delay(100); // Wait for CMD to come back
delay(100);
delay(100);
delay(100);
delay(100);
bluetooth.println("U,9600,N"); // Temporarily Change the baudrate to 9600 (until a reboot is done)
delay(100);
bluetooth.begin(9600);
