HC-05 Serial Comms - 2 way not working in SoftwareSerial
#include <SoftwareSerial.h>
#define tx 11
#define rx 10
SoftwareSerial bt(rx, tx); //RX, TX
  bt.begin(9600);
  if(bt.available()>0)
    Serial.println(bt.readString());
reciever
transmitter
#define tx 11
#define rx 10
SoftwareSerial bt(rx,tx); //RX, TX
  bt.begin(9600);
  bt.write("12333");
so this is not working.....hardware serial is working but we can not use hardware serial in our project. wiring will send later. PLEASE Help
what microcontroller boards are you using ? how many serial ports do you require?
have a look at AltSoftSerial
Take a search engine of your choice and ask the WWW for 'bluetooth +arduino' to collect some data to be sorted out to get the needed information.
sender is uno
reciever is uno ( nano for testing )
code is from www.
hardware serial is working but we need software serial as we are creating a user product.
you say hardware serial is working - do you mean the USB Serial to the serial monitor?
the UNO does not have any other available hardware ports?
if you are building a user product using Bluetooth or BLE I recommend you move to a ESP32 which has onboard WiFi and Bluetooth
tx pins as in 0 and 1 is working in comms like i have code to send 123 every second through hc05 and the reciever is picking it up and displaying it
but when using software serial library, the input is just garbage
from arduino-uno-pins-a-complete-practical-guide
Note that the Serial used by USB is the same as the one used with pins 0 and 1. So, if you want to connect another device to the RX/TX pins of your board, remember not to use the Serial through USB.
try AltSoftSerial
does not work for my needs, i need all digital pins as i am making a bluetooth controller robot.....and using motor driver shield v1 which uses almost all digital pins except 0,1,2,10,9
Your code is spitting out 5 bytes as fast as possible and on the receiving end you print what you get but the baud rate for printing out is the same as the reception so your buffers probably end up full and blocking code / missing data
Does the code work if you do this?
  bt.write("12333");
Also change the Serial baud rate to 115200 on the receiver side
i will try but i did not understand what u meant
it is working but sometimes there are 2 texts instead of 1
also, it is very slow and i need data transmission instantly
right handside is transmission and left is recieving....notice the errors
please, please don't post pictures of text... Not only they are not readable nor usable directly for copy&paste but they use up lots of storage and internet bandwidth which contributes to polluting the planet.
well you send the message only twice per second.
Also readString has a builtin timeout at 1s so that's what you wait for.
if you change the receiving end code to:
#define tx 11
#define rx 10
  bt.begin(9600);
    Serial.write((char) bt.read());
and open your Serial monitor at 115200 bauds, it will work much better
I would suggest to study Serial Input Basics to handle this
this is actual reciever code
#include <AFMotor.h>
#include <Servo.h>
AF_DCMotor motor1(1);
AF_DCMotor motor2(2);
AF_DCMotor motor3(3);
AF_DCMotor motor4(4);
Servo servo1;
Servo servo2;
Servo servoClaw;
String command = "";
  // Set initial speed of the motors & stop
  motor1.setSpeed(200);
  motor1.run(RELEASE);
  motor2.setSpeed(200);
  motor2.run(RELEASE);
  motor3.setSpeed(200);
  motor3.run(RELEASE);
  motor4.setSpeed(200);
  motor4.run(RELEASE);
  servo1.attach(9);     // Attach servo1 to pin 9
  servo2.attach(6);     // Attach servo2 to pin 6
  servoClaw.attach(5);  // Attach servoClaw to pin 5
  Serial.begin(9600);  // Initialize hardware serial communication
  if (Serial.available())
    char c = Serial.read();
    // Check for end of command
    if (c == '\n')
      processCommand(command);
      command = "";  // Clear the command string
      command += c;  // Append character to command string
  delay(100);
void processCommand(const String& command)
  Serial.print("Received command: ");
  Serial.println(command);
  // Compare the received command with predefined commands and take action accordingly
  if (command.equals("MF"))
    moveForward();
  else if (command.equals("MR"))
    moveRight();
  else if (command.equals("MB"))
    moveBackward();
  else if (command.equals("ML"))
    moveLeft();
  else if (command.equals("serleft"))
    moveLeftServo();
  else if (command.equals("serright"))
    moveRightServo();
  else if (command.equals("serup"))
    moveUpServo();
  else if (command.equals("serdown"))
    moveDownServo();
  else if (command.equals("serclaw"))
    openCloseClaw();
    stopMotors();
void moveForward()
  motor1.run(FORWARD);
  motor2.run(FORWARD);
  motor3.run(FORWARD);
  motor4.run(FORWARD);
  Serial.println("Moving forward");
void moveRight()
  motor1.run(BACKWARD);
  motor2.run(BACKWARD);
  Serial.println("Moving right");
void moveBackward()
  motor3.run(BACKWARD);
  motor4.run(BACKWARD);
  Serial.println("Moving backward");
void moveLeft()
  Serial.println("Moving left");
void moveLeftServo()
  int pos = servo1.read();
  if (pos < 180)
    pos += 5;
    servo1.write(pos);
  Serial.println("Moving left servo");
void moveRightServo()
  if (pos > 0)
    pos -= 5;
    servo1.write(pos);
  Serial.println("Moving right servo");
void moveUpServo()
  int pos = servo2.read();
  if (pos < 180)
    pos += 5;
    servo2.write(pos);
  Serial.println("Moving up servo");
void moveDownServo()
  if (pos > 0)
    pos -= 5;
    servo2.write(pos);
  Serial.println("Moving down servo");
void openCloseClaw()
  int pos = servoClaw.read();
  if (pos == 0)
    servoClaw.write(90);
    Serial.println("Opening claw");
    servoClaw.write(0);
    Serial.println("Closing claw");
void stopMotors()
  Serial.println("Stopping motors");
which is needed to work with this transmitter code
SoftwareSerial bluetoothSerial(8, 7); // RX, TX pins of HC-05
const int joystick1XPin = A0; // Analog input pin for Joystick 1 X-axis
const int joystick1YPin = A1; // Analog input pin for Joystick 1 Y-axis
const int joystick2XPin = A2; // Analog input pin for Joystick 2 X-axis
const int joystick2YPin = A3; // Analog input pin for Joystick 2 Y-axis
const int joystickButtonPin = 2; // Digital input pin for Joystick button
const int joystickThreshold = 50; // Threshold value to consider joystick movement
  bluetoothSerial.begin(9600); // Initialize Bluetooth serial communication
  pinMode(joystickButtonPin, INPUT_PULLUP); // Set the joystick button pin as INPUT_PULLUP
  int joystick1XValue = analogRead(joystick1XPin);
  int joystick1YValue = analogRead(joystick1YPin);
  int joystick2XValue = analogRead(joystick2XPin);
  int joystick2YValue = analogRead(joystick2YPin);
  int joystickButtonValue = digitalRead(joystickButtonPin);
  int joystick1XCommand = getJoystickCommand(joystick1XValue);
  int joystick1YCommand = getJoystickCommand(joystick1YValue);
  int joystick2XCommand = getJoystickCommand(joystick2XValue);
  int joystick2YCommand = getJoystickCommand(joystick2YValue);
  // Print the raw joystick values to the serial monitor
  //Serial.print("Joystick 1 X: ");
  //Serial.print(joystick1XValue);
  //Serial.print("\tJoystick 1 Y: ");
  //Serial.print(joystick1YValue);
  //Serial.print("\tJoystick 2 X: ");
  //Serial.print(joystick2XValue);
  //Serial.print("\tJoystick 2 Y: ");
  //Serial.println(joystick2YValue);
  // Print the joystick commands to the serial monitor
  //Serial.print("Joystick 1 X Command: ");
  //Serial.print(joystick1XCommand);
  //Serial.print("\tJoystick 1 Y Command: ");
  //Serial.print(joystick1YCommand);
  //Serial.print("\tJoystick 2 X Command: ");
  //Serial.print(joystick2XCommand);
  //Serial.print("\tJoystick 2 Y Command: ");
  //Serial.println(joystick2YCommand);
  // Check Joystick 1 movement
  if (joystick1XCommand == -1)
    Serial.println("Move Right");
    sendBluetoothCommand("MR"); // Move Right
  else if (joystick1XCommand == 1)
    Serial.println("Move Left");
    sendBluetoothCommand("ML"); // Move Left
  else if (joystick1YCommand == -1)
    Serial.println("Move Backward");
    sendBluetoothCommand("MB"); // Move Backward
  else if (joystick1YCommand == 1)
    Serial.println("Move Forward");
    sendBluetoothCommand("MF"); // Move Forward
    Serial.println("STOP");
    sendBluetoothCommand("gasd");
  // Check Joystick 2 movement
  if (joystick2XCommand == -1)
    Serial.println("Left Servo Movement");
    sendBluetoothCommand("serleft"); // Left servo movement
  else if (joystick2XCommand == 1)
    Serial.println("Right Servo Movement");
    sendBluetoothCommand("serright"); // Right servo movement
  else if (joystick2YCommand == -1)
    Serial.println("Up Servo Movement");
    sendBluetoothCommand("serup"); // Up servo movement
  else if (joystick2YCommand == 1)
    Serial.println("Down Servo Movement");
    sendBluetoothCommand("serdown"); // Down servo movement
  // Check Joystick button
  if (joystickButtonValue == LOW)
    Serial.println("Joystick Button Pressed");
    sendBluetoothCommand("serclaw"); // Claw movement
  delay(100); // Delay for 1 second
int getJoystickCommand(int value)
  if (value < (512 - joystickThreshold))
    return -1; // Negative command for left or up movement
  else if (value > (512 + joystickThreshold))
    return 1; // Positive command for right or down movement
    return 0; // No movement
void sendBluetoothCommand(const char* command)
  bluetoothSerial.print(command);
so will it work with this....deadline is monday
so this is working but how do i integrate it into this
when it is working, it is showing like
exampleexampleesampleexample
when i want it to be
example
example
example
example
you need the sender to send an end marker, so that you know the message is complete. you can make that a line feed '\n' or carriage return '\r' or both
with both, it can be achieve simply with println() instead of print()
  bluetoothSerial.println(command);
otherwise you can include the end marker in the message
sendBluetoothCommand("serleft\n");
//                           ^^ end of line character
can you please send me the code if you have time
just change the sendBluetoothCommand function with what I gave you in post 20
This is showing example example when it should show
Example
Example
Example1
Servo1 etc
