When I put the screws in place and try to tighten, nothing happens the screw doesn't tighten. I feel like screws lengths which is 6 mm is too short. Anyone experienced this issue? I was thinking of buying screws with same diameter but with 7-8mm lengths instead. But I'm open to any suggestions.
I don't know anything about that kit, but I wouldn't recommend getting longer screws. I would figure out what is wrong with the assembly that is causing the problem, since I would assume the screws are the correct size.
I am sure you are anxious to get this working, but accuracy is more important than speed.
There are five (?) servos to be mounted. The engineers determined a nut (where indicated) would not work (maybe it impeded movement of another part). Are you using the correct part? The parts count in your instructions will identify every part.
Clearly assembly instructions present different adapter from yours. They likely modified it to be compatible with different servos. If it prevents the servo to be mounted and work correctly, I suggest you to return the kit.
For step 17, I tried mounting the motor based on the manual but the motor cannot fit that way. it fits if I flip the motor the other way. I honestly think Arduino messed up.
use the 3 mm × 6 mm self-tapping screws (usually silver or black).
If the screws are M3 machine screws instead of self-tapping, they will NOT grip.
Check the tip of the screw:
If it’s sharp, it’s self-tapping (correct).
If it’s flat, it’s a machine screw (wrong)
If keep spinning with 6mm screw use 8mm because some kit shop wrong screw
The 3mmx6mm screws don't even touch the screw hole. I don't know how the person in the video fit it through so easily. I feel like the hole is just too small, I don't know does Arduino have the STL file I can use to edit the hole to make it bigger?
