Arduino Button Code Switching
Hi, I'm working on police flasher project and using Arduino Nano for it.
Here is my code and it's working as expected but I want to add a button to switch modes. I will proceed after solve the button issue.
This code is Mode 1.
pinMode(2, INPUT); //Mode Button
pinMode(5, OUTPUT); // LED RED
pinMode(6, OUTPUT); // LED BLUE
pinMode(7, OUTPUT); // LED WHITE
pinMode(8, OUTPUT); // LED WHITE
if (digitalRead == (2, HIGH)); // When Mode button is pushed...
digitalWrite(5, HIGH);
digitalWrite(7, HIGH);
delay(50);
digitalWrite(5, LOW);
digitalWrite(7, LOW);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
digitalWrite(6, HIGH);
digitalWrite(8, HIGH);
delay(50);
digitalWrite(6, LOW);
digitalWrite(8, LOW);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
//so on...
This is Mode 2
delay(20);
delay(20);
delay(20);
delay(20);
When I press the button I want to switch 1. Mode's loop to 2. Modes loop. But could't make it. Someone help please.
Please post the full code of your best attempt, using code tags when you do, and describe the problems you encountered
should be
if (digitalRead(2) == HIGH) {
You must carefully follow the rules of C/C++ language. You cannot choose to write something that you think might be the same thing.
When I press the button it won't switch to Mode 2 :frowning: What's wrong in the code?
void loop() { //Mode1
if (digitalRead(2) == HIGH); { // When Mode button is pushed...
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
void loop1() { //Mode2
if (digitalRead(2) == HIGH); // When Mode button is pushed...
delay(20);
delay(20);
delay(20);
delay(20);
Still need an assistance...
I already did @UKHeliBob
then later
How will the code know which of them to react to ?
If you want to change modes then you need to detect when the button becomes pressed rather than when it is pressed
See the StateChangeDetection example in the IDE
There are, however, other problems such as your use of delay() during which nothing, including reading of input states can happen and the fact that I suspect that you do not have a pulldown resistor in place to keep the input pin at a known state at all times
Still incorrect.
loop1() is never called.
Could you write down the right code?
I wrote it down in post #3.
Nope, I already put 10k pulldown resistor.
const int buttonPin = 2;
const int ledPin = 5;
int buttonPushCounter = 0;
int buttonState = 0;
int lastButtonState = 0;
  pinMode(buttonPin, INPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  buttonState = digitalRead(buttonPin);
  if (buttonState != lastButtonState) {
    if (buttonState == HIGH) {
      buttonPushCounter++;
      Serial.println("on");
      Serial.print("number of button pushes: ");
      Serial.println(buttonPushCounter);
      Serial.println("off");
    delay(50);
  lastButtonState = buttonState;
  if (buttonPushCounter % 2 == 0) {
So, this is IDE codes when I press the button all 4 LED's are on if I press again all of them off. Now, I have to adapt this to my code which are Mode 1 and Mode 2.
Good progress!
I would suggest:
      if (buttonPushCounter >= 2) buttonPushCounter = 0;
Then later you do not need to use "%"
if (buttonPushCounter == 0) {
If you are only going to have 2 modes and the sketch will either be running one mode or the other then you only need one variable, possibly a boolean, to know which mode that the sketch is in
if (mode1 == true)
  //code for mode 1
  //code for mode 2
Bear in mind the possible problems caused by using blocking delay()s which will slow down response to button presses
You would be better to write the sketch as a state machine and non blocking millis() timing, but use your current method for now and see how it goes
Exactly where do I have to put these in my codes?
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
    delay(50);
You don't strictly need another variable as you already have buttonPushCounter but a specifically named variable will help make the code more readable
So, depending on the value of buttonPressCounter set the value of the mode1 variable, then later in loop use its value to determine which block of code runs, much as using the value of buttonPressCounter in the code that you posted
If you do not want to introduce another variable then use buttonPressCounter % 2 directly to control the code that runs at the expense of code readability
Worked partially but still someting wrong.
I need to increase the number of mods like 10 different mode.
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
 if (buttonPushCounter >= 1) buttonPushCounter = 0;
  if (buttonPushCounter = 1) { //Mode 1
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
  if (buttonPushCounter = 2) { //Mode 2
delay(10);
delay(10);
delay(10);
delay(10);
https://www.learncpp.com/cpp-tutorial/switch-statement-basics/
  if (buttonPushCounter = 1)   //Mode 1
  if (buttonPushCounter = 2)   //Mode 2
These lines are wrong for a start
= is used to assign a value to a variable
== is used to compare values
Ok, what I'm gonna do to fix?
