Arduino button interrupts is not working
Hello everyone,
The project is base on multiple led effects. We can switch the effects by pushing button. So i added an interrupts to the button. I written some code for it but its the interrups is not working.
This is the simulation on tinkercad. please help me to fixed the code.
CODE:
int LED[] = {12, 11, 10, 9, 8};
int     button_switch =                       2; // external interrupt pin
int 	counter = 0;
#define switched                            true // value if the button switch has been pressed
#define triggered                           true // controls interrupt handler
#define interrupt_trigger_type            CHANGE // interrupt triggered on a RISING input
#define debounce                   20 // time to wait in milli secs
volatile  bool interrupt_process_status = {
  !triggered                                     // start with no switch press pending, ie false (!triggered)
bool initialisation_complete =            false; // inhibit any interrupts until initialisation is complete
unsigned long previous[] = {0, 0};
const long interval[] = {100, 200};
// ISR for handling interrupt triggers arising from associated button switch
void button_interrupt_handler()
  if (initialisation_complete == true)
  { //  all variables are initialised so we are okay to continue to process this interrupt
    if (interrupt_process_status == !triggered) {
      // new interrupt so okay start a new button read process -
      // now need to wait for button release plus debounce period to elapse
      // this will be done in the button_read function
      if (digitalRead(button_switch) == HIGH) {
        // button pressed, so we can start the read on/off + debounce cycle wich will
        // be completed by the button_read() function.
        interrupt_process_status = triggered;  // keep this ISR 'quiet' until button read fully completed
} // end of button_interrupt_handler
bool read_button() {
  int button_reading;
  // static variables because we need to retain old values between function calls
  static bool     switching_pending = false;
  static long int elapse_timer;
  if (interrupt_process_status == triggered) {
    Serial.print("Interrupt");
    // interrupt has been raised on this button so now need to complete
    // the button read process, ie wait until it has been released
    // and debounce time elapsed
    button_reading = digitalRead(button_switch);
    if (button_reading == HIGH) {
      // switch is pressed, so start/restart wait for button relealse, plus end of debounce process
      switching_pending = true;
      elapse_timer = millis(); // start elapse timing for debounce checking
    if (switching_pending && button_reading == LOW) {
      // switch was pressed, now released, so check if debounce time elapsed
      if (millis() - elapse_timer >= debounce) {
        // dounce time elapsed, so switch press cycle complete
        switching_pending = false;             // reset for next button press interrupt cycle
        interrupt_process_status = !triggered; // reopen ISR for business now button on/off/debounce cycle complete
        return switched;                       // advise that switch has been pressed
  return !switched; // either no press request or debounce period not elapsed
} // end of read_button function
  for (int i=0; i < 5;i++){
  pinMode(LED[i], OUTPUT);
  pinMode(button_switch, INPUT);
  attachInterrupt(digitalPinToInterrupt(button_switch),
                  button_interrupt_handler,
                  interrupt_trigger_type);
  initialisation_complete = true; // open interrupt processing for business
} // end of setup function
  unsigned long currentMillis = 0;
  int i=0;
  if (read_button() == switched) {
    counter++;
    Serial.println(counter);
    switch(counter){
  case 1:
    Serial.println("s1");
      while(i < 5){
        currentMillis = millis();
        if (currentMillis - previous[0] >= interval[0]) {
          Serial.println(currentMillis);
    previous[0] = currentMillis;
  digitalWrite(LED[i], HIGH);
          i++;
   i = 0;
      while( i < 5){
        if (currentMillis - previous[1] >= interval[1]) {
    previous[1] = currentMillis;
  digitalWrite(LED[i], LOW);
          i++;
  case 2:
      Serial.println("s2");
  case 3:
    Serial.println("s3");
  default:
    counter = 0;
if you want to debug how the interrupt works, first leave only the interrupt in the code, without all this mess with a functions with leds and millis. When the interrupt works - gradually add everything else.
Slow operating switches need only be scanned every 50ms.
Interrupts are meant for use with very fast events and almost never needed.
I have no idea why you think that this is related to Interfacing w/ Software on the Computer. Hence your topic has been moved to a more suitable location on the forum.
Thanks for using code tags in your first post :+1:
Using interrupts call for considerable knowledge and is not needed for checking buttons. It most often only create severe difficulties.
A couple of compile warnings:
/Users/john/Documents/Arduino/sketch_oct09a/sketch_oct09a.ino: In function 'void loop()':
/Users/john/Documents/Arduino/sketch_oct09a/sketch_oct09a.ino:112:43: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
/Users/john/Documents/Arduino/sketch_oct09a/sketch_oct09a.ino:125:43: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
Try using 'unsigned' or 'unsigned long':
Also, this should be 'unsigned long int' because that is the type that millis() returns:
Thanks for your reply. :slight_smile:
I tried the interrupt code and it working but when I added the while loop in it I written some led effect code. So when I press the button, the effect is not changing.
I don't know why the interrupt is not working.
I used interrupt here because later I will add multiple led effects, but the problem is when I run the code the led effect kept running in a loop. I'm not able to switch the mode that's why, I decided to add interrupts. So whenever the interrupt happens, the effect stop and changes to a different effect. This is what I'm trying to do.
With this while loop your interrupt is completely useless:
Your code do not check the button until the loop finished.
If you want to change effect before it finished - you have to check interrupt state inside the loop
I tried it but its not working. whenever I press the push button the effect is not changing. IDK what is the problem.
Can you please help me with that IDK where should I add the interrupt state.
try
while ((i<5) && (switched != read_button()))
  • Tell us what you think this is doing:
  • Confirm you are only using simple LEDs and you are using this circuit ?
2022-10-19_0-31-49
Here is something you can play with:
// https://forum.arduino.cc/t/arduino-button-interrupts-is-not-working/1043406
// Version    YY/MM/DD    Description
// 1.00       22/10/19    Running sketch
#define CLOSED                        HIGH
#define OPENED                        LOW
#define LEDon                         HIGH
#define LEDoff                        LOW
const byte heartbeatLED             = 13;
const byte LED[]                    = {12, 11, 10, 9, 8}; //Pin---[220R]---[A>|K]---GND
const byte button_switch            = 2;                  //5V---[Switch]---Pin---[10k]---GND
byte index                          = 0;
byte lastButton_switchState;
unsigned long heartbeatTime;
unsigned long switchTime;
unsigned long commonTime;
unsigned long interval0             = 100ul;
unsigned long interval1             = 200ul;
//State Machine states
enum States {State0, State1, State2, State3, State4};
//States mState = State0;
int  counter                        = State0;
  pinMode(heartbeatLED, OUTPUT);
  for (int i = 0; i < 5; i++)
  //*************************************                          h e a r t b e a t   T I M E R
  //to see if the sketch is blocking,
  //toggle the heartbeat LED every 500ms
  if (millis() - heartbeatTime >= 500)
    //restart the TIMER
    heartbeatTime = millis();
    //toggle the LED
    digitalWrite(heartbeatLED, !digitalRead(heartbeatLED));
  //*************************************                          s w i t c h   T I M E R
  //is it time to check the switches ? every 50ms
  if (millis() - switchTime >= 1)
    //restart the TIMER
    switchTime = millis();
    //go and check the switches
    checkSwitches();
  //check our State Machine
  checkMachine();
  //other non blocking code goes here
} //END of   loop()
void checkMachine()
  switch (counter)
    case State0:
        //do nothing
    case State1:
      if (millis() - commonTime >= interval0)
        digitalWrite(LED[index], LEDon);
        //restart the TIMER
        commonTime = millis();
        index++;
        //have all the LEDs been dealt with ?
        if (index > 4)
          index = 0;
    case State2:
        if (millis() - commonTime >= interval1)
          digitalWrite(LED[index], LEDoff);
          //restart the TIMER
          index++;
          if (index > 4)
            index = 0;
    case State3:
    case State4:
  } //END   switch/case
} //END of   checkMachine()
void checkSwitches()
  //*********************************************                    b u t t o n _ s w i t c h
  //button_switch code
  byte currentState = digitalRead(button_switch);
  //was there a change in state ?
  if (lastButton_switchState != currentState)
    //update to the new state
    lastButton_switchState = currentState;
    //is the switch closed ?
    if (currentState == CLOSED)
      //next animation
      counter++;
      //are we finished ?
      if (counter > State2)            // <-----<<<<  match the number of animations
        //back to the beginning
        counter = State0;
      //point to the first LED
      index = 0;
      //restart the TIMER
  } //END of  button_switch code
} //END of   checkSwitches()
Thank you so much :heart_eyes: . Its worked but there is one more problem occur which I aready fixed it.
When you want to say thanks for somebody in the forum - you can use likes.
And if your problem is solved - mark most useful comment as "Solution"
Thank you so much all of you. :heart_eyes:
BTW @b707 I got it.
Thank you for the code. :heart_eyes:
Notice that interrupts were not needed!
