Hi everyone.
I've recently added to the Arduino library registry, this new library that allows you to easily model and run a finite state machine within urs Arduino projects.
I use FSMs very often in my codes and for this reason some years ago I had developed the YA_FSM library.
AgileStateMachine is born from the ashes of the previous project which performed more or less the same tasks but in a more "rough" way.
The principle according to which it was developed is freely inspired to the "State Machine Framework of the well-known QT" C++ environment (obviously very simplified since it's designed for the embedded world).
Furthermore, this library allows you to associate "Actions" with states. This behavior is inspired by the operation of the SFC (Sequential Function Chart) models widely used in industrial automation.
Some additional info from Github readme:
States represent the different situations in which the machine can be at any time for given inputs.
A Transition connect two states, and are associated with a boolean trigger condition.
The finite state machine can interact with the rest of the firmware:
- using callback functions;
- using "boolean" Actions (similar to what is done with PLCs);
- using a mix between the two methodologies;
State definition and callback functions
Each states can be binded up to three different callback functions that will be executed when the state is activated (on enter), when is left (on exit) and while is running (on run).
For each state it is also possible to define an optional maximum and a minimum duration time.
If a callback function is not needed, simply use value nullptr or NULL instead of the name of function.
Transition definition and trigger
To connect two states, a transition need to be defined. The trigger of transition can be performed with a bool function() or a bool variable.
Also the timeout of state itself can be used for triggering to next state.
Action definition
For each state you can define also a set of qualified Actions, that will be executed when state is active causing effect to the target bool variable
The library support this action qualifiers:
| Action qualifier | Description | Short explanation on the effect | Duration |
| N | Non-stored | Action is active (target = TRUE) as long as the state input is active | NO |
| R | Reset | Reset to FALSE the value of target variable | NO |
| S | Set (or Stored) | Set to TRUE the value of target variable | NO |
| L | time Limited | target = TRUE until the end of the set time or until the state is deactivated | YES |
| D | time Delayed | target = TRUE after the set time has elapsed until the state is deactivated | YES |
| RE | Rising Edge | target = TRUE only once after the state is activated | NO |
| FE | Falling Edge | target = TRUE only once after the state is de-activated*** | NO |
*** Since the state is not active anymore, target must bel cleared manually
