Arduino Clock TV out
I was impressed with this public domain Arduino clock with TV out. It makes your old TV really cool looking. The question is how to modify the code so that it runs in Portrait instead of landscape. The TV i have does not have screen rotate option, so I was hoping some advice. here is the clock code.
//start "sketch"
#include <TVout.h>
#include "Wire.h"
//#include <pollserial.h>
#include <fontALL.h>
TVout TV;
//pollserial pserial;
#define DS1307_I2C_ADDRESS 0x68  // This is the I2C address
// Global Variables
long previousMillis = 0;        // will store last time time was updated
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
long interval = 200;
int tvx,tvy,tvradius,x2,y2,x3,y3;
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
return ( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
return ( (val/16*10) + (val%16) );
// Gets the date and time from the ds1307 and prints result
void getDateDs1307()
// Reset the register pointer
Wire.beginTransmission(DS1307_I2C_ADDRESS);
Wire.end(0x00);
Wire.endTransmission();
Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
// A few of these need masks because certain bits are control bits
second     = bcdToDec(Wire.receive() & 0x7f);
minute     = bcdToDec(Wire.receive());
hour       = bcdToDec(Wire.receive() & 0x3f);  // Need to change this if 12 hour am/pm
dayOfWeek  = bcdToDec(Wire.receive());
dayOfMonth = bcdToDec(Wire.receive());
month      = bcdToDec(Wire.receive());
year       = bcdToDec(Wire.receive());
void printTime()
TV.set_cursor(0,0);
TV.print( char( hour/10 + 0x30) );
TV.print( char( hour%10 + 0x30) );
TV.print(":");
TV.print( char(minute/10 + 0x30));
TV.print( char(minute%10 + 0x30));
TV.print(":");
TV.print(char (second/10+0x30));
TV.print(char (second%10+0x30));
TV.set_cursor(8,9);
TV.print(char(dayOfMonth/10+0x30));
TV.print(char(dayOfMonth%10+0x30));
TV.print("/");
TV.print(char(month/10+0x30));
TV.print(char(month%10+0x30));
TV.set_cursor(10,18);
TV.print("20");
TV.print(char(year/10+0x30));
TV.print(char(year%10+0x30));
TV.draw_circle(tvx,tvy,tvradius-5,BLACK,BLACK);
float angle = second*6 ;
angle=(angle/57.29577951) ; //Convert degrees to radians
x3=(tvx+(sin(angle)*(tvradius-6)));
y3=(tvy-(cos(angle)*(tvradius-6)));
TV.draw_line(tvx,tvy,x3,y3,WHITE);
angle = minute * 6 ;
x3=(tvx+(sin(angle)*(tvradius-11)));
y3=(tvy-(cos(angle)*(tvradius-11)));
angle = hour * 30 + int((minute / 12) * 6 )   ;
x3=(tvx+(sin(angle)*(tvradius-15)));
y3=(tvy-(cos(angle)*(tvradius-15)));
void setup()  {
Wire.begin();
getDateDs1307() ;
//TV.begin(_NTSC,184,72);
//the circle didn't look very round with 184,72
TV.begin(_NTSC,150,71);
TV.select_font(font6x8);
TV.clear_screen();
//TV.println("TV Clock");
tvx= TV.hres()/2;
tvy=TV.vres()/2;
tvradius=TV.vres()/2 ;
//clock face
 TV.draw_circle(tvx,tvy,tvradius,WHITE);
//hour ticks
for( int z=0; z < 360;z= z + 30 ){
  //Begin at 0° and stop at 360°
  float angle = z ;
  x2=(tvx+(sin(angle)*tvradius));
  y2=(tvy-(cos(angle)*tvradius));
  x3=(tvx+(sin(angle)*(tvradius-5)));
  y3=(tvy-(cos(angle)*(tvradius-5)));
  TV.draw_line(x2,y2,x3,y3,WHITE);
//TV.set_hbi_hook(pserial.begin(57600));
// if (pserial.available()) {
//   TV.print((char)pserial.read());
// other processing here maybe
if(currentMillis - previousMillis > interval) {
  // save the last time you printed and updated
  TV.delay(1);
  printTime();
  //read RTC
  getDateDs1307() ;
It may be possible to rotate the clock face itself. Probably all that is required is to add 90 degrees to the angles, or swap sin() for cos() and cos() for sin().
However, I don't believe the TVout library has the ability to rotate text by 90 degrees. Perhaps you could create a new font where the required digits and symbols are rotated.
