I'm working on an Arduino project and I'd really appreciate your help in reviewing or improving my code. Here's what I'm trying to achieve:
Arduino Mega 2560
DS3231 RTC module
1.8" SPI TFT LCD (ST7735 driver, 128x160, using Adafruit_ST7735 library)
Tower Pro SG-5010 servo motor
External 5V power supply for the servo
I want to create a 12-hour countdown timer based on the real-time clock (DS3231).
The countdown is displayed on the TFT screen .
Once the 12 hours are over:
The servo motor rotates from 0° to 180°, waits, and returns back to 0°.
A new 12-hour countdown begins.
can someone help me to this project?
kmin
May 15, 2025, 10:41am
2
You forgot to post your code.
Also, have you already tested separately all your components?
You need to install the following libraries.
RTClib (by Adafruit)
Adafruit GFX Library
Adafruit ST7735 and ST7789 Library
Servo
jim-p
May 15, 2025, 11:25am
4
Please take some time and read the following:
See also FAQ - Arduino Forum for general rules on forum behavior and etiquette.
Hello,
Welcome to the Arduino Forum.
This guide explains how to get the best out of this forum. Please read and follow the instructions below.
Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is frus…
jim-p
May 15, 2025, 11:55am
5
Are you working with this person (Mertgulec)
i have project, i need the code making lcd 12 hours alarm and when alarm expires servo need to start can someone help me?
#include <Wire.h>
#include <RTClib.h>
#include <Adafruit_GFX.h>
#include <Adafruit_ST7735.h>
#include <SPI.h>
#include <Servo.h>
// TFT ekran pinler
#define TFT_CS 53
#define TFT_RST 49
#define TFT_DC 48
Adafruit_ST7735 ekran(TFT_CS, TFT_DC, TFT_RST);
RTC_DS3231 rtc;
Servo motor;
const int MOTOR_PIN = 6; // servo motor sinyal pini
DateTime sonTetiklemeZamani; // en son servo motorun çalıştığı zaman
bool sayacAktifMi = true; // sayaç şu anda çalışıyor mu sorgusu
Wire.begin(); // I2C haberleşmesi
// TFT ekran başlatma
ekran.initR(INITR_BLACKTAB);
ekran.setRotation(1);
ekran.fillScreen(ST77XX_BLACK);
ekran.setTextSize(2);
ekran.setTextColor(ST77XX_WHITE);
// RTC modülü başlatma
if (!rtc.begin()) {
ekran.setCursor(0, 0);
ekran.println("RTC bulunamadi!");
while (1); // RTC yoksa kod kesilir
if (rtc.lostPower()) {
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
// servo motor 0 dereceye ayarlama
motor.attach(MOTOR_PIN);
motor.write(0);
// başlangıç zamanı çalıştığı saat
sonTetiklemeZamani = rtc.now();
DateTime simdi = rtc.now(); // Şu anki zamanı oku
//yeni gün sorgusu
TimeSpan kalanSure = TimeSpan(0, 12, 0, 0) - (simdi - sonTetiklemeZamani);
// TFT ekran temizle yazdır
ekran.setCursor(10, 10);
if (kalanSure.totalseconds() > 0) {
// sayaç hala devam ediyorsa geri sayımı yazdır
int saat = kalanSure.hours();
int dakika = kalanSure.minutes();
int saniye = kalanSure.seconds();
ekran.print("Geri Sayim:");
ekran.setCursor(10, 40);
yazSaatiYaz(saat, dakika, saniye);
// motor çalıştır ve sayaç sıfırla
if (sayacAktifMi) {
ekran.setTextColor(ST77XX_GREEN);
ekran.setCursor(10, 20);
ekran.println("MAMA VAKTİ!!");
ekran.setCursor(10, 50);
ekran.println("MAMA DÖKÜLÜYOR!");
// servo motoru 0 - 180
motor.write(180);
delay(2000);
motor.write(0);
delay(2000);
sonTetiklemeZamani = simdi;
sayacAktifMi = false;
// sayaç kapalıysa ve tetiklemeden 10 saniye geçerse baştan başlat
if ((simdi - sonTetiklemeZamani).totalseconds() > 10 && !sayacAktifMi) {
delay(1000); //ekranı her saniye güncelle
// saat biçimi saat dakika saniye örnek 10:27:54
void yazSaatiYaz(int saat, int dakika, int saniye) {
if (saat < 10) ekran.print("0");
ekran.print(saat); ekran.print(":");
if (dakika < 10) ekran.print("0");
ekran.print(dakika); ekran.print(":");
if (saniye < 10) ekran.print("0");
ekran.print(saniye);
here its my code
yes he is my brother why?
jim-p
May 15, 2025, 1:09pm
8
Because some people will create two accounts which is against forum rules.
I didn't know my brother created an account, Im sorry for that.
You could do a 12 hour countdown timer just using millis() with no real-time clock. Does your countdown have to happen from a particular time of day?
no, the countdown will start as soon as the arduino board is powered. how do I do what you say?
Something like this. It compiles, but I haven't tested it. There may be mistakes in it . I haven't provided code to convert the time remaining calculation to hh:mm:ss. You should understand how to do that.
const unsigned long period = 43200000UL; // 1000 x 60 x 60 x 12
static unsigned long previousActivationTime = 0;
unsigned long timeNow = millis();
if (timeNow - previousActivationTime > period) {
// Add your code for the servo here
previousActivationTime = timeNow;
// For displaying count down time, once a second?
static unsigned long previousClockUpdateTime = 0;
timeNow = millis();
if (timeNow - previousClockUpdateTime >= 1000) {
previousClockUpdateTime = timeNow;
// Convert period-(timeNow - previousActivationTime) to hh:mm:ss for display
Try it, and if you have problems then come back and ask more questions. I suggest you reduce the value of period for testing and add some Serial.println()s to print when servo will be activated and print when count down updates. I.E. just use the above code with Serial.println()s added until you are happy it's working and you understand how it works
so i can use millis() and eeprom am i right?
#include <EEPROM.h>
#include <SPI.h>
#include <Servo.h>
// TFT display pin configuration
#define TFT_CS 53
#define TFT_RST 49
#define TFT_DC 48
#define MOTOR_PIN 6
#define EEPROM_ADRESI 0
#define BEKLEME_SURESI 43200000UL // 12 hours in milliseconds (12*60*60*1000)
Servo motor;
unsigned long sonTetiklemeZamani = 0; // Last time the servo was activated
bool sayacAktifMi = true; // Is the countdown currently active?
// Initialize TFT screen
// Initialize servo motor
motor.write(0); // Set initial position to 0 degrees
// Read last activation time from EEPROM
EEPROM.get(EEPROM_ADRESI, sonTetiklemeZamani);
// If EEPROM is empty or contains invalid data, use current millis
if (sonTetiklemeZamani == 0 || sonTetiklemeZamani > millis()) {
sonTetiklemeZamani = millis();
unsigned long simdi = millis();
unsigned long gecenSure = simdi - sonTetiklemeZamani;
// Clear TFT and write updated countdown
if (gecenSure < BEKLEME_SURESI) {
// Countdown is ongoing, display remaining time
unsigned long kalanMs = BEKLEME_SURESI - gecenSure;
int saat = kalanMs / 3600000UL;
int dakika = (kalanMs % 3600000UL) / 60000UL;
int saniye = (kalanMs % 60000UL) / 1000UL;
ekran.print("Countdown:");
// Countdown finished, activate the servo motor
if (sayacAktifMi) {
ekran.println("FEEDING TIME!!");
ekran.println("DISPENSING FOOD");
// Move servo to 180 degrees and back to 0
motor.write(180);
delay(2000);
motor.write(0);
delay(2000);
// Save new activation time to EEPROM
EEPROM.put(EEPROM_ADRESI, sonTetiklemeZamani);
// Reactivate the countdown 10 seconds after the servo triggers
if ((millis() - sonTetiklemeZamani) > 10000 && !sayacAktifMi) {
delay(1000); // Update the display every second
// Display time in hh:mm:ss format
is there any place where you see an error sir?
If you want the 12 hour countdown to work across periods when there is no power to your Arduino, then you are back to using a real time clock, because the Arduino has no way of knowing how long the power was off. EEPROM won't help you.
When you said that, it made me think you didn't want to take into account power off periods.
I don't have time to check your code for you. Why don't you do what I said:
Dave_Lowther:
Or run your own code and see whether it works or not.
I strongly suggest you work with small parts of your code first, get them working, then add more parts to your code, check it works again, etc.
Thank you for your help, I will try, should I contact you if I have problems?
Post back here if you have problems then I, or someone else, will help you.
Hello mert.
The sketch on dry run seems functional and solid, however,
if (sayacAktifMi) {
You should be able to get past by this
// if (sayacAktifMi) {
//} Basically remove the condition bound
This if check is basically redundant, as this condition is already handled by your gecenSure variable, which works as the elapsedtime variable if I am not mistaken.
Using delay directly to hard block your code can work for this simple implementation, but it is often the best practice to use a while loop, so that the loop never gets blocked (right now this is not a problem as the job is just to spin the servo and nothing else.)
Good job and good luck.
And remember, efficient codes means less energy usage. Which means, more battery life.
