Hello everyone.
I'm trying to make a simple weather station with simple code and the issue is that the online code editor is acting like the thingProperties.h File doesn't exist.
Here is the main file:
#include "WeatherStation_feb25b.h"
#include "thingProperties.h"
initialize();
void loop(){
ArduinoCloud.update();
getAndSendTemp();
// getAndSendHumidity();
This is the thingProperties file:
// Code generated by Arduino IoT Cloud, DO NOT EDIT.
#include <ArduinoIoTCloud.h>
#include <Arduino_ConnectionHandler.h>
const char SSID[] = SECRET_SSID; // Network SSID (name)
const char PASS[] = SECRET_OPTIONAL_PASS; // Network password (use for WPA, or use as key for WEP)
float humidity;
int temperature;
void initProperties(){
ArduinoCloud.addProperty(humidity, READ, 60 * SECONDS, NULL);
ArduinoCloud.addProperty(temperature, READ, 60 * SECONDS, NULL);
ArduinoCloud.updateCertificate(CERT_AUTHORITY, CERT_SERIAL, CERT_NOT_BEFORE, CERT_NOT_AFTER, CERT_SIGNATURE_RS);
WiFiConnectionHandler ArduinoIoTPreferredConnection(SSID, PASS);
And here is my header file:
#ifndef WEATHER_STATION_H
#define WEATHER_STATION_H
#include <AM2302-Sensor.h>
#include <Arduino.h>
constexpr unsigned int SENSOR_PIN {7U};
AM2302::AM2302_Sensor am2302{SENSOR_PIN};
void initialize(){
initProperties();
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
void getAndSendTemp(){
auto status = am2302.read();
int Temperature2 = am2302.get_Temperature();
temperature = Temperature2 * 1.8 + 25;
// void getAndSendHumidity(){
// auto status = am2302.read();
// humidity = am2302.get_Humidity();
#endif
And here is the error:
FQBN: arduino:renesas_uno:unor4wifi
Using board 'unor4wifi' from platform in folder: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2
Using core 'arduino' from platform in folder: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2
Detecting libraries used...
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/WeatherStation_feb25a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/sketch/WeatherStation_feb25a.ino.cpp -o /dev/null
Alternatives for AM2302-Sensor.h: [AM2302-Sensor@1.4.0]
ResolveLibrary(AM2302-Sensor.h)
-> candidates: [AM2302-Sensor@1.4.0]
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/WeatherStation_feb25a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/AM2302-Sensor/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/sketch/WeatherStation_feb25a.ino.cpp -o /dev/null
Alternatives for ArduinoIoTCloud.h: [ArduinoIoTCloud@2.3.1]
ResolveLibrary(ArduinoIoTCloud.h)
-> candidates: [ArduinoIoTCloud@2.3.1]
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/WeatherStation_feb25a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/AM2302-Sensor/src -I/var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/sketch/WeatherStation_feb25a.ino.cpp -o /dev/null
Alternatives for Arduino_ConnectionHandler.h: [Arduino_ConnectionHandler@1.0.0]
ResolveLibrary(Arduino_ConnectionHandler.h)
-> candidates: [Arduino_ConnectionHandler@1.0.0]
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/WeatherStation_feb25a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/AM2302-Sensor/src -I/var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src -I/var/run/arduino/directories-user/libraries/Arduino_ConnectionHandler/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/sketch/WeatherStation_feb25a.ino.cpp -o /dev/null
Alternatives for Arduino_DebugUtils.h: [Arduino_DebugUtils@1.4.0]
ResolveLibrary(Arduino_DebugUtils.h)
-> candidates: [Arduino_DebugUtils@1.4.0]
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/WeatherStation_feb25a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/AM2302-Sensor/src -I/var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src -I/var/run/arduino/directories-user/libraries/Arduino_ConnectionHandler/src -I/var/run/arduino/directories-user/libraries/Arduino_DebugUtils/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/sketch/WeatherStation_feb25a.ino.cpp -o /dev/null
Alternatives for WiFiS3.h: [WiFiS3@0.0.0]
ResolveLibrary(WiFiS3.h)
-> candidates: [WiFiS3@0.0.0]
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/WeatherStation_feb25a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/AM2302-Sensor/src -I/var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src -I/var/run/arduino/directories-user/libraries/Arduino_ConnectionHandler/src -I/var/run/arduino/directories-user/libraries/Arduino_DebugUtils/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/WiFiS3/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/sketch/WeatherStation_feb25a.ino.cpp -o /dev/null
Alternatives for ArduinoMqttClient.h: [ArduinoMqttClient@0.1.8]
ResolveLibrary(ArduinoMqttClient.h)
-> candidates: [ArduinoMqttClient@0.1.8]
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/WeatherStation_feb25a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/AM2302-Sensor/src -I/var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src -I/var/run/arduino/directories-user/libraries/Arduino_ConnectionHandler/src -I/var/run/arduino/directories-user/libraries/Arduino_DebugUtils/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/WiFiS3/src -I/var/run/arduino/directories-user/libraries/ArduinoMqttClient/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/sketch/WeatherStation_feb25a.ino.cpp -o /dev/null
Alternatives for Arduino_SecureElement.h: [Arduino_SecureElement@0.3.0]
ResolveLibrary(Arduino_SecureElement.h)
-> candidates: [Arduino_SecureElement@0.3.0]
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/WeatherStation_feb25a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/AM2302-Sensor/src -I/var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src -I/var/run/arduino/directories-user/libraries/Arduino_ConnectionHandler/src -I/var/run/arduino/directories-user/libraries/Arduino_DebugUtils/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/WiFiS3/src -I/var/run/arduino/directories-user/libraries/ArduinoMqttClient/src -I/var/run/arduino/directories-user/libraries/Arduino_SecureElement/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/sketch/WeatherStation_feb25a.ino.cpp -o /dev/null
Alternatives for SoftwareATSE.h: [SoftwareATSE@0.0.1]
ResolveLibrary(SoftwareATSE.h)
-> candidates: [SoftwareATSE@0.0.1]
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/WeatherStation_feb25a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/AM2302-Sensor/src -I/var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src -I/var/run/arduino/directories-user/libraries/Arduino_ConnectionHandler/src -I/var/run/arduino/directories-user/libraries/Arduino_DebugUtils/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/WiFiS3/src -I/var/run/arduino/directories-user/libraries/ArduinoMqttClient/src -I/var/run/arduino/directories-user/libraries/Arduino_SecureElement/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/SoftwareATSE/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/sketch/WeatherStation_feb25a.ino.cpp -o /dev/null
Alternatives for OTAUpdate.h: [OTAUpdate@0.0.1]
ResolveLibrary(OTAUpdate.h)
-> candidates: [OTAUpdate@0.0.1]
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/WeatherStation_feb25a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/AM2302-Sensor/src -I/var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src -I/var/run/arduino/directories-user/libraries/Arduino_ConnectionHandler/src -I/var/run/arduino/directories-user/libraries/Arduino_DebugUtils/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/WiFiS3/src -I/var/run/arduino/directories-user/libraries/ArduinoMqttClient/src -I/var/run/arduino/directories-user/libraries/Arduino_SecureElement/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/SoftwareATSE/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/OTAUpdate/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/sketch/WeatherStation_feb25a.ino.cpp -o /dev/null
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/AM2302-Sensor/src/AM2302-Sensor.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/ArduinoIoTCloud.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/ArduinoIoTCloudDevice.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/ArduinoIoTCloudLPWAN.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/ArduinoIoTCloudNotecard.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/ArduinoIoTCloudTCP.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/ArduinoIoTCloudThing.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/cbor/CBOR.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/cbor/CBORDecoder.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/cbor/CBOREncoder.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/cbor/MessageDecoder.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/cbor/MessageEncoder.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/cbor/lib/tinycbor/src/cborencoder.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/cbor/lib/tinycbor/src/cborencoder_close_container_checked.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/cbor/lib/tinycbor/src/cborerrorstrings.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/cbor/lib/tinycbor/src/cborparser.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/cbor/lib/tinycbor/src/cborparser_dup_string.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/cbor/lib/tinycbor/src/cborpretty.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/cbor/lib/tinycbor/src/cborpretty_stdio.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/cbor/lib/tinycbor/src/cbortojson.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/cbor/lib/tinycbor/src/cborvalidation.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/cbor/lib/tinycbor/src/open_memstream.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/ota/implementation/OTAEsp32.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/ota/implementation/OTANanoRP2040.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/ota/implementation/OTASTM32H7.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/ota/implementation/OTASamd.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/ota/implementation/OTAUnoR4.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/ota/interface/OTAInterface.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/ota/interface/OTAInterfaceDefault.cpp
Alternatives for ArduinoHttpClient.h: [ArduinoHttpClient@0.6.1]
ResolveLibrary(ArduinoHttpClient.h)
-> candidates: [ArduinoHttpClient@0.6.1]
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/property/Property.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/property/PropertyContainer.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/BearSSLClient.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_big_cbcdec.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_big_cbcenc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_big_ctr.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_big_ctrcbc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_big_dec.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_big_enc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_common.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_ct.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_ct64.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_ct64_cbcdec.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_ct64_cbcenc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_ct64_ctr.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_ct64_ctrcbc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_ct64_dec.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_ct64_enc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_ct_cbcdec.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_ct_cbcenc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_ct_ctr.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_ct_ctrcbc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_ct_dec.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_ct_enc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_pwr8.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_pwr8_cbcdec.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_pwr8_cbcenc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_pwr8_ctr.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_pwr8_ctrcbc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_small_cbcdec.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_small_cbcenc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_small_ctr.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_small_ctrcbc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_small_dec.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_small_enc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_x86ni.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_x86ni_cbcdec.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_x86ni_cbcenc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aes_x86ni_ctr.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/aesctr_drbg.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/asn1enc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ccm.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ccopy.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/chacha20_ct.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/chacha20_sse2.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/dec16be.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/dec16le.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/dec32be.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/dec32le.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/dec64be.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/dec64le.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/des_ct.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/des_ct_cbcdec.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/des_ct_cbcenc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/des_support.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/des_tab.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/des_tab_cbcdec.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/des_tab_cbcenc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/dig_oid.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/dig_size.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/eax.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ec_all_m15.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ec_all_m31.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ec_c25519_i15.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ec_c25519_i31.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ec_c25519_m15.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ec_c25519_m31.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ec_curve25519.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ec_default.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ec_keygen.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ec_p256_m15.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ec_p256_m31.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ec_prime_i15.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ec_prime_i31.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ec_pubkey.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ec_secp256r1.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ec_secp384r1.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ec_secp521r1.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ecdsa_atr.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ecdsa_default_sign_asn1.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ecdsa_default_sign_raw.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ecdsa_default_vrfy_asn1.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ecdsa_default_vrfy_raw.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ecdsa_i15_bits.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ecdsa_i15_sign_asn1.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ecdsa_i15_sign_raw.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ecdsa_i15_vrfy_asn1.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ecdsa_i15_vrfy_raw.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ecdsa_i31_bits.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ecdsa_i31_sign_asn1.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ecdsa_i31_sign_raw.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ecdsa_i31_vrfy_asn1.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ecdsa_i31_vrfy_raw.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ecdsa_rta.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/enc16be.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/enc16le.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/enc32be.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/enc32le.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/enc64be.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/enc64le.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/encode_ec_pk8der.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/encode_ec_rawder.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/encode_rsa_pk8der.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/encode_rsa_rawder.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/gcm.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ghash_ctmul.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ghash_ctmul32.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ghash_ctmul64.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ghash_pclmul.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ghash_pwr8.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/hkdf.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/hmac.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/hmac_ct.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/hmac_drbg.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i15_add.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i15_bitlen.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i15_decmod.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i15_decode.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i15_decred.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i15_encode.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i15_fmont.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i15_iszero.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i15_moddiv.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i15_modpow.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i15_modpow2.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i15_montmul.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i15_mulacc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i15_muladd.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i15_ninv15.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i15_reduce.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i15_rshift.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i15_sub.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i15_tmont.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i31_add.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i31_bitlen.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i31_decmod.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i31_decode.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i31_decred.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i31_encode.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i31_fmont.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i31_iszero.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i31_moddiv.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i31_modpow.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i31_modpow2.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i31_montmul.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i31_mulacc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i31_muladd.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i31_ninv31.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i31_reduce.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i31_rshift.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i31_sub.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i31_tmont.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i32_add.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i32_bitlen.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i32_decmod.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i32_decode.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i32_decred.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i32_div32.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i32_encode.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i32_fmont.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i32_iszero.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i32_modpow.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i32_montmul.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i32_mulacc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i32_muladd.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i32_ninv32.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i32_reduce.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i32_sub.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i32_tmont.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/i62_modpow2.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/md5.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/md5sha1.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/mgf1.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/multihash.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/pemdec.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/pemenc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/poly1305_ctmul.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/poly1305_ctmul32.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/poly1305_ctmulq.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/poly1305_i15.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/prf.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/prf_md5sha1.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/prf_sha256.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/prf_sha384.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_default_keygen.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_default_modulus.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_default_oaep_decrypt.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_default_oaep_encrypt.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_default_pkcs1_sign.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_default_pkcs1_vrfy.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_default_priv.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_default_privexp.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_default_pub.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_default_pubexp.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i15_keygen.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i15_modulus.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i15_oaep_decrypt.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i15_oaep_encrypt.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i15_pkcs1_sign.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i15_pkcs1_vrfy.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i15_priv.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i15_privexp.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i15_pub.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i15_pubexp.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i31_keygen.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i31_keygen_inner.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i31_modulus.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i31_oaep_decrypt.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i31_oaep_encrypt.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i31_pkcs1_sign.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i31_pkcs1_vrfy.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i31_priv.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i31_privexp.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i31_pub.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i31_pubexp.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i32_oaep_decrypt.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i32_oaep_encrypt.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i32_pkcs1_sign.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i32_pkcs1_vrfy.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i32_priv.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i32_pub.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i62_keygen.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i62_oaep_decrypt.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i62_oaep_encrypt.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i62_pkcs1_sign.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i62_pkcs1_vrfy.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i62_priv.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_i62_pub.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_oaep_pad.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_oaep_unpad.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_pkcs1_sig_pad.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_pkcs1_sig_unpad.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/rsa_ssl_decrypt.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/settings.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/sha1.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/sha2big.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/sha2small.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/skey_decoder.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_ccert_single_ec.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_ccert_single_rsa.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_client.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_client_default_rsapub.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_client_full.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_engine.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_engine_default_aescbc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_engine_default_aesccm.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_engine_default_aesgcm.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_engine_default_chapol.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_engine_default_descbc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_engine_default_ec.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_engine_default_ecdsa.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_engine_default_rsavrfy.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_hashes.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_hs_client.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_hs_server.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_io.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_keyexport.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_lru.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_rec_cbc.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_rec_ccm.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_rec_chapol.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_rec_gcm.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_scert_single_ec.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_scert_single_rsa.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_server.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_server_full_ec.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_server_full_rsa.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_server_mine2c.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_server_mine2g.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_server_minf2c.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_server_minf2g.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_server_minr2g.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_server_minu2g.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/ssl_server_minv2g.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/sysrng.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/x509_decoder.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/x509_knownkey.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/x509_minimal.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/bearssl/x509_minimal_full.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/profile/aiotc_profile.c
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/utility/SHA256.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/utility/TLSClientMqtt.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/utility/TLSClientOta.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/utility/eccX08_sign_asn1.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/tls/utility/eccX08_vrfy_asn1.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/utility/lzss/lzss.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/utility/time/NTPUtils.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/utility/time/RTCMillis.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/utility/time/TimeService.cpp
Alternatives for RTC.h: [M5StickC@0.3.0 M5StickCPlus@0.1.1 M5Station@0.0.1 M5Core2@0.2.0 RTC@1.0]
ResolveLibrary(RTC.h)
-> candidates: [M5StickC@0.3.0 M5StickCPlus@0.1.1 M5Station@0.0.1 M5Core2@0.2.0 RTC@1.0]
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/utility/time/TimedAttempt.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src/utility/watchdog/Watchdog.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/Arduino_ConnectionHandler/src/CatM1ConnectionHandler.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/Arduino_ConnectionHandler/src/CellularConnectionHandler.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/Arduino_ConnectionHandler/src/ConnectionHandlerInterface.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/Arduino_ConnectionHandler/src/EthernetConnectionHandler.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/Arduino_ConnectionHandler/src/GSMConnectionHandler.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/Arduino_ConnectionHandler/src/LoRaConnectionHandler.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/Arduino_ConnectionHandler/src/NBConnectionHandler.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/Arduino_ConnectionHandler/src/NotecardConnectionHandler.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/Arduino_ConnectionHandler/src/WiFiConnectionHandler.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/Arduino_DebugUtils/src/Arduino_DebugUtils.cpp
Using cached library dependencies for file: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/WiFiS3/src/Modem.cpp
Using cached library dependencies for file: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/WiFiS3/src/StringHelpers.cpp
Using cached library dependencies for file: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/WiFiS3/src/WiFi.cpp
Using cached library dependencies for file: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/WiFiS3/src/WiFiClient.cpp
Using cached library dependencies for file: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/WiFiS3/src/WiFiFileSystem.cpp
Using cached library dependencies for file: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/WiFiS3/src/WiFiSSLClient.cpp
Using cached library dependencies for file: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/WiFiS3/src/WiFiServer.cpp
Using cached library dependencies for file: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/WiFiS3/src/WiFiUdp.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoMqttClient/src/MqttClient.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/Arduino_SecureElement/src/ECP256Certificate.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/Arduino_SecureElement/src/SecureElement.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/Arduino_SecureElement/src/utility/SElementArduinoCloudCertificate.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/Arduino_SecureElement/src/utility/SElementArduinoCloudDeviceId.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/Arduino_SecureElement/src/utility/SElementCSR.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/Arduino_SecureElement/src/utility/SElementCertificate.cpp
Using cached library dependencies for file: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/SoftwareATSE/src/SoftwareATSE.cpp
Using cached library dependencies for file: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/OTAUpdate/src/OTAUpdate.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoHttpClient/src/HttpClient.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoHttpClient/src/URLEncoder.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoHttpClient/src/WebSocketClient.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoHttpClient/src/b64.cpp
Using cached library dependencies for file: /var/run/arduino/directories-user/libraries/ArduinoHttpClient/src/utility/URLParser/http_parser.c
Using cached library dependencies for file: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/RTC/src/RTC.cpp
Generating function prototypes...
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/WeatherStation_feb25a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/AM2302-Sensor/src -I/var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src -I/var/run/arduino/directories-user/libraries/Arduino_ConnectionHandler/src -I/var/run/arduino/directories-user/libraries/Arduino_DebugUtils/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/WiFiS3/src -I/var/run/arduino/directories-user/libraries/ArduinoMqttClient/src -I/var/run/arduino/directories-user/libraries/Arduino_SecureElement/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/SoftwareATSE/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/OTAUpdate/src -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/RTC/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/sketch/WeatherStation_feb25a.ino.cpp -o /tmp/3816831960/sketch_merged.cpp
/run/arduino/directories-data/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/3816831960/sketch_merged.cpp
Compiling sketch...
/run/arduino/directories-data/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -MMD -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -MMD -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 "-DPROJECT_NAME=\"/var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/WeatherStation_feb25a.ino\"" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/tinyusb -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino/api/deprecated-avr-comp -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/cores/arduino -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4 -I/var/run/arduino/directories-user/libraries/AM2302-Sensor/src -I/var/run/arduino/directories-user/libraries/ArduinoIoTCloud/src -I/var/run/arduino/directories-user/libraries/Arduino_ConnectionHandler/src -I/var/run/arduino/directories-user/libraries/Arduino_DebugUtils/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/WiFiS3/src -I/var/run/arduino/directories-user/libraries/ArduinoMqttClient/src -I/var/run/arduino/directories-user/libraries/Arduino_SecureElement/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/SoftwareATSE/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/OTAUpdate/src -I/var/run/arduino/directories-user/libraries/ArduinoHttpClient/src -I/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/RTC/src -iprefix/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2 @/run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/variants/UNOWIFIR4/includes.txt /var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/sketch/WeatherStation_feb25a.ino.cpp -o /var/run/arduino/user-cache/sketches/446B7BFDAAE6520181279439A4DF94E5/sketch/WeatherStation_feb25a.ino.cpp.o
Using library AM2302-Sensor at version 1.4.0 in folder: /run/arduino/directories-data/internal/AM2302-Sensor_1.4.0_95e28fdacde1c9f8
Using library ArduinoIoTCloud at version 2.3.1 in folder: /run/arduino/directories-data/internal/ArduinoIoTCloud_2.3.1_a02959e4a18fbf48
Using library Arduino_ConnectionHandler at version 1.0.0 in folder: /run/arduino/directories-data/internal/Arduino_ConnectionHandler_1.0.0_005977d7b4d81c2e
Using library Arduino_DebugUtils at version 1.4.0 in folder: /run/arduino/directories-data/internal/Arduino_DebugUtils_1.4.0_0354ee2edf6910cd
Using library WiFiS3 at version 0.0.0 in folder: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/WiFiS3
Using library ArduinoMqttClient at version 0.1.8 in folder: /run/arduino/directories-data/internal/ArduinoMqttClient_0.1.8_b1e57bf359553881
Using library Arduino_SecureElement at version 0.3.0 in folder: /run/arduino/directories-data/internal/Arduino_SecureElement_0.3.0_0ab04497bcc5f5fb
Using library SoftwareATSE at version 0.0.1 in folder: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/SoftwareATSE
Using library OTAUpdate at version 0.0.1 in folder: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/OTAUpdate
Using library ArduinoHttpClient at version 0.6.1 in folder: /run/arduino/directories-data/internal/ArduinoHttpClient_0.6.1_969df906691206c8
Using library RTC at version 1.0 in folder: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/RTC
In file included from /run/arduino/sketches/WeatherStation_feb25a/WeatherStation_feb25a.ino:2:0:
/run/arduino/sketches/WeatherStation_feb25a/WeatherStation_feb25b.h: In function 'void initialize()':
/run/arduino/sketches/WeatherStation_feb25a/WeatherStation_feb25b.h:9:3: error: 'initProperties' was not declared in this scope
initProperties();
/run/arduino/sketches/WeatherStation_feb25a/WeatherStation_feb25b.h:9:3: note: suggested alternative: 'addProperty'
initProperties();
addProperty
/run/arduino/sketches/WeatherStation_feb25a/WeatherStation_feb25b.h:10:3: error: 'ArduinoCloud' was not declared in this scope
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
/run/arduino/sketches/WeatherStation_feb25a/WeatherStation_feb25b.h:10:22: error: 'ArduinoIoTPreferredConnection' was not declared in this scope
/run/arduino/sketches/WeatherStation_feb25a/WeatherStation_feb25b.h:11:3: error: 'setDebugMessageLevel' was not declared in this scope
setDebugMessageLevel(2);
/run/arduino/sketches/WeatherStation_feb25a/WeatherStation_feb25b.h: In function 'void getAndSendTemp()':
/run/arduino/sketches/WeatherStation_feb25a/WeatherStation_feb25b.h:17:3: error: 'temperature' was not declared in this scope
temperature = Temperature2 * 1.8 + 25;
/run/arduino/sketches/WeatherStation_feb25a/WeatherStation_feb25b.h:17:3: note: suggested alternative: 'Temperature2'
Temperature2
Multiple libraries were found for "RTC.h"
Used: /run/arduino/directories-data/packages/arduino/hardware/renesas_uno/1.3.2/libraries/RTC
Not used: /run/arduino/directories-data/internal/M5StickC_0.3.0_a99c11f2c0b70886
Not used: /run/arduino/directories-data/internal/M5StickCPlus_0.1.1_3da481354d8492d0
Not used: /run/arduino/directories-data/internal/M5Station_0.0.1_59c962b74b2e5439
Not used: /run/arduino/directories-data/internal/M5Core2_0.2.0_b8c417594bcb0714
The code did work with just the getAndSendTemp() function, but the error started happening after I added the "getAndSendHumidity()" function in the main and header file, which is now in comments, and even when I removed the function the error continued.
This already previously happened in a previous version of my code, so I made a new thing in the Cloud, but like the old version, this version is having the same issue with the same error.
Thanks for any help.
