#include nested too deeply Arduino IDE
Here is the code:
#include "ArduinoIoTCloud.h"
#include "WiFiConnectionManager.h"
const char THING_ID[] = "97e8b9343-d81e-45d7-84bc-61eafe7cd9b7";
const char SSID[WiFi]     = SECRET_SSID;    // Network SSID (name)
const char PASS[NOTYOURS]     = SECRET_PASS;    // Network password (use for WPA, or use as key for WEP)
int Deliveries;
void initProperties(){
  ArduinoCloud.setThingId(THING_ID);
  ArduinoCloud.addProperty(deliveries, READ, ON_CHANGE, NULL);
ConnectionManager *ArduinoIoTPreferredConnection = new WiFiConnectionManager(SSID, PASS);
I have a different tab that says #include WiFiConnectionManager.h, and that is where I am getting this error. I copied and pasted the code from a project that I found online. Any help is a appreciated
Could you explain what the problem is?
Please post the error message.
ok. Here is the error message
Arduino: 1.8.15 (Mac OS X), Board: "Arduino MKR1000"
In file included from /Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/WiFiConnectionManager.h:1:0,
                 from /Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/WiFiConnectionManager.h:1,
                 from /Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h:2,
                 from /Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino:17:
WiFiConnectionManager.h:1:35: error: #include nested too deeply
exit status 1
option enabled in File -> Preferences.
Looks like WiFiConnectionManager.h includes WiFiConnectionManager.h
yes. if this is a problem then how do I fix this?
DON'T put
in WiFiConnectionManager.h.
Why did you use the same name as the library file? Do you not have the library installed?
If I do this thing then I get this error.
In file included from /Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h:1:0,
ArduinoIoTCloud.h:1:10: fatal error: ArduinoIoTCloud.h: No such file or directory
 #include <ArduinoIoTCloud.h>
compilation terminated.
exit status 1
I have yet another tab where I put #include <ArduinoIoTCloud.h>
I tried searching for the library, but it came empty
you mean this library? ArduinoIoTCloud/src/ArduinoIoTCloud.h at master · arduino-libraries/ArduinoIoTCloud · GitHub
That does look like the correct library, but 1: Why are there so many lines of code, and 2, where would I put that library ?
have you tried looking for it in library manager?
alright, it seems like that fixed that problem, but I get another one:
In file included from /Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino:17:0:
thingProperties.h:7:18: error: stray '@' in program
 const char PASS[C@s]     = SECRET_PASS;    // Network password (use for WPA, or use as key for WEP)
thingProperties.h:6:21: error: array bound is not an integer constant before ']' token
thingProperties.h:7:17: error: 'C' was not declared in this scope
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h:7:17: note: suggested alternative: 'AC'
                 AC
thingProperties.h:7:19: error: expected ']' before 'st1nelu5'
In file included from /Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/ArduinoIoTCloud.h:1:0,
                 from /Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h:1,
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h: In function 'void initProperties()':
thingProperties.h:14:28: error: 'deliveries' was not declared in this scope
/Users/Daniel/Documents/Arduino/libraries/ArduinoIoTCloud/src/ArduinoIoTCloud.h:103:46: note: in definition of macro 'addProperty'
 #define addProperty( v, ...) addPropertyReal(v, #v, __VA_ARGS__)
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h:14:28: note: suggested alternative: 'Deliveries'
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h: At global scope:
thingProperties.h:17:1: error: 'ConnectionManager' does not name a type; did you mean 'ConnectionHandler'?
 ConnectionHandler
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino: In function 'void setup()':
MAILBOX_notifier:52:22: error: 'ArduinoIoTPreferredConnection' was not declared in this scope
   ArduinoCloud.begin(ArduinoIoTPreferredConnection);
MAILBOX_notifier:61:2: error: 'deliveries' was not declared in this scope
  deliveries = 0;
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino:61:2: note: suggested alternative: 'Deliveries'
  deliveries = 0;
  Deliveries
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino: In function 'void loop()':
MAILBOX_notifier:117:5: error: 'deliveries' was not declared in this scope
     deliveries++;
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino:117:5: note: suggested alternative: 'Deliveries'
     deliveries++;
     Deliveries
exit status 1
The error pops up where it says const char PASS[] on line 3
It looks like it is seeing this on line 7:
Can you not see the 'C@s' characters in the IDE window? If not, they may be representing a non-printable character that you can't see but the compiler can. Try deleting the '[' and ']' and everything between, then type [] back in.
I believe I fixed that problem now, could you help me with this one? I get this error on line 10
thingProperties.h:10:1: error: expected ',' or ';' before 'int'
int Deliveries;
thingProperties.h:13:3: error: 'ArduinoCloud' was not declared in this scope
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h:13:3: note: suggested alternative: 'Arduino_h'
Arduino_h
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h:14:28: note: suggested alternative: 'degrees'
degrees
thingProperties.h:14:40: error: 'READ' was not declared in this scope
thingProperties.h:14:46: error: 'ON_CHANGE' was not declared in this scope
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/thingProperties.h:14:46: note: suggested alternative: 'CHANGE'
CHANGE
MAILBOX_notifier:48:3: error: 'setDebugMessageLevel' was not declared in this scope
setDebugMessageLevel(4);
MAILBOX_notifier:49:3: error: 'ArduinoCloud' was not declared in this scope
ArduinoCloud.printDebugInfo();
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino:49:3: note: suggested alternative: 'Arduino_h'
Arduino_h
deliveries = 0;
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino:61:2: note: suggested alternative: 'degrees'
deliveries = 0;
degrees
MAILBOX_notifier:74:3: error: 'ArduinoCloud' was not declared in this scope
ArduinoCloud.update();
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino:74:3: note: suggested alternative: 'Arduino_h'
Arduino_h
deliveries++;
/Users/Daniel/Downloads/adriens-MAILBOX_notifier-7c1ccba/MAILBOX_notifier/MAILBOX_notifier.ino:117:5: note: suggested alternative: 'degrees'
deliveries++;
degrees
exit status 1
Looks like you forgot the ';' at the end of the statement before this one.
THANKS SO MUCH. I don't want to bother much, but in my main file I get this error, after adding the ;
#include "arduino_secrets.h"
  Sketch generated by the Arduino IoT Cloud Thing "MAILBOX"
  https://create.arduino.cc/cloud/things/9b41adac-e48d-428e-9ccd-0dddd50c4be5
  Arduino IoT Cloud Properties description
  The following variables are automatically generated and updated when changes are made to the Thing properties
  int deliveries;
  Properties which are marked as READ/WRITE in the Cloud Thing will also have functions
  which are called when their values are changed from the Dashboard.
  These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
// PIN configuration
const int trigPin = 6;    // Trigger
const int echoPin = 7;    // Echo
// variables
long duration, cm, inches;
int prev_cm = 30;
int curr_cm = 30;
int prev_status = 0;
int curr_status = 0;// out
int zone_radius_cm = 10;
int nb_current_deliveries = 0;// number of times an input has been detected
int nb_previous_deliveries = 0;
int loop_counter = 0;
  // Initialize serial and wait for port to open:
  // This delay gives the chance to wait for a Serial Monitor without blocking if none is found
  delay(1500);
  Serial.println("Booting Mailbox scanner...");
  delay(200);
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
     The following function allows you to obtain more information
     related to the state of network and IoT Cloud connection and errors
     the higher number the more granular information you’ll get.
     The default is 0 (only errors).
     Maximum is 4
 deliveries = 0;
  //Define inputs and outputs
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  // some led pight
  pinMode(LED_BUILTIN, OUTPUT);
  Serial.println("Mailbox scanner booted.");
  // Your code here
  if (nb_current_deliveries > nb_previous_deliveries){
  Serial.println("Watching inbox...");
  // The sensor is triggered by a HIGH pulse of 10 or more microseconds.
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
  digitalWrite(trigPin, LOW);
  delayMicroseconds(5);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  // Read the signal from the sensor: a HIGH pulse whose
  // duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  duration = pulseIn(echoPin, HIGH);
  // Convert the time into a distance
  cm = (duration/2) / 29.1;     // Divide by 29.1 or multiply by 0.0343
  //inches = (duration/2) / 74;   // Divide by 74 or multiply by 0.0135
  prev_cm = curr_cm;
  curr_cm = cm;
  prev_status = curr_status;
  //Serial.print(inches);
  //Serial.print("in, ");
  //Serial.print(cm);
  //Serial.print("cm");
  //Serial.println();
  if (curr_cm < zone_radius_cm){
    // object in the zone
    Serial.println("");
    Serial.println("Object in the zone !");
    // Increase nb. of deliveries
    nb_previous_deliveries = nb_current_deliveries;
    nb_current_deliveries++;
    // update deliveries for cloud counter
    deliveries++;
    //ack = false;
    Serial.println("Acknowledge flag reset to false.");
    notify();
    Serial.println("Sleeping for a while now...");
    delay(3000);
    //prev_status = curr_status;
    curr_status = 1;
  else {
    if(loop_counter == 0){
    Serial.print(".");
    //"Serial.println("No activity in the zone, watching moves...");
    delay(100); // Wait for 100 millisecond(s)
  delay(100);
  loop_counter++;
  loop_counter = loop_counter % 25;
//                        Custom functions
void notify(){
      Serial.println("Notifying...");
      //digitalWrite(LED_BUILTIN, HIGH);
      Serial.print("<");
      Serial.print(nb_current_deliveries);
      Serial.println("> total deliveries.");
      //delay(10000);
      Serial.println("Notified.");
      Serial.println("#################################");
      //digitalWrite(LED_BUILTIN, LOW);
      int i = 0;
      while ( i < 20){
        digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
        delay(200);                       // wait for a second
        digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
        delay(200);
        i++;
THE ERROR IS ON LINE 75.
If You need the whole error message, please let me know
Were you supposed to put this line in?
`ArduinoIoTCloud ArduinoCloud;'
Look at the examples for the ArduinoIoTCloud library examples to see how the library works.
Looks like you called the variable "Deliveries", not "deliveries".
I'm sorry, I can't find the line where it says `ArduinoIoTCloud ArduinoCloud; in my code
