Arduino Cloud won't connect to UNO R3, L LED no longer lights
Continuing the discussion from L Light Does Not Light Up:
I'm having a similar problem - I have an Elegoo Arduino Super Starter Kit and when I unboxed it everything was ok and mostly functional. I have two problems: the first has always happened ever since I got the kit, and it is that the arduino cloud editor refuses to connect to my board (an Arduino Uno R3), and the second, which started a couple months ago, is that, after experimenting, my board's L LED no longer lights, not even when I press the button. I'm not sure if I burned out the led, because I plugged it into slightly higher power than normal at one point, but the power LED is fine. Can someone tell me how to fix this because my parents will kill me if I have to return or replace it :skull:
Oh, also, the serial numbers on my chip are: 35473D ATMEGA328p U 24030G2
Disconnect everything from UNO, run this program
void setup ()
  pinMode (LED_BUILTIN,OUTPUT);
  digitalWrite (LED_BUILTIN,HIGH);
Does the L led come on?
What is IT? What was the voltage of "slightly higher power than normal"?
Do you have the Agent (software) installed?
Does the "L" LED light as you plug the Arduino into USB or stand-alone power and does the Arduino Power LED light?
Do you hear your computer operating system "chime" when you plug the Arduino into the USB port?
Arduino have a troubleshooting page:
https://support.arduino.cc/hc/en-us/articles/360014869820-Install-the-Arduino-Cloud-Agent
Also, if you have a non-OEM-Arduino, you will get this... (with a warning at the bottom)
(but the "continue" button does not proceed to the "configure" page)
