hello, i'm new using Arduino so i don't yet understand all connections allowed by Arduino.
i've an MEI Cashflow 115 DFx Coin Validator (http://www.ebay.com/itm/Video-Game-Parts-MEI-Cashflow-115-DFx-Coin-Validator-/370870720206?pt=UK_Video_Games_Coin_Operated_MJ&hash=item56599e16ce) and i want to reader input coins using my arduino. i already saw an adafruit coins acceptor (Counting Money with a Coin Acceptor « Adafruit Industries – Makers, hackers, artists, designers and engineers!) however my device has an 'Interface Connector (CF952X/CF952Xe only, Dual polarity and BCO)' with 16 pins much more than adafruit 4 pins acceptor. Someone can explain me how sould i connect this 16 pins to arduino?
ya, in device datasheet showed above they talk between 17 and 15 pins but may device have 16 pins who is very strange, however i don't understand reason.
Note: *The voltage applied to PIN 8 will result in either a parallel or BCO mode:
For Parallel Mode – Apply a high voltage to PIN 8. (e.g. 5v up to a maximum 12 v)
For BCO Mode – Apply a low voltage to PIN 8. (e.g. 0v)
17- Way Connector 15 - Way Connector MEI Parallel Std Input or Output Pin No. BACTA BCO Std
1 - A coin o/p O/P 1 Ident signal
2 1 B coin o/p O/P 2 Accept o/p 5
3 2 Coin o/p Common I/P 3 Accept o/p Common
4 3 F coin o/p O/P 4 Accept o/p 1
5 4 Polarising Key 1 - 5 Polarising Key
6 5 E coin o/p O/P 6 Accept o/p 2
7 6 D coin o/p O/P 7 Accept o/p 3
8 * 7 Output mode I/P 8 Select Line
9 8 C coin o/p O/P 9 Accept o/p 4
10 9 C coin inhibit I/P 10 Inhibit 4
11 10 +12V supply I/P 11 +12V supply
12 11 0V supply I/P 12 0V supply
13 12 D coin inhibit I/P 13 Inhibit 3
14 13 E coin inhibit I/P 14 Inhibit 2
15 14 F coin inhibit I/P 15 Inhibit 1
16 15 B coin inhibit I/P 16 Inhibit 5
17 - A coin inhibit I/P 17 Inhibit 6
