arduino coins acceptor
hello,
i've an coins acceptor and i need to read 3 memored coins (2€ output=20, 1€ output=10 and 0.20€ output=2). I programmed arduino to read data from device COIN wire connected in arduino PIN3.
however when i inserted coins arduino don't display anything on console.
it's something wrong with my program(below)? or it's about the connection PIN?
volatile byte coinPulseCount =0;
byte newCoinInserted;
byte cmd=0;
int opCountPin =3;
volatile unsigned long pulseTime;
  Serial.print("Input on pin ");
  Serial.print(opCountPin);
  pinMode(opCountPin,INPUT);
  attachInterrupt(1,coinpulse,RISING);
  if(coinPulseCount > 0 && millis() - pulseTime > 200)
   newCoinInserted = coinPulseCount;
   coinPulseCount = 0;
  switch(newCoinInserted)
    case 1:
      Serial.println("0.01€");
      newCoinInserted =0;
    case 2:
      Serial.println("0.2€");
      newCoinInserted =0;
    case 3:
      Serial.println("1€");
      newCoinInserted =0;
void coinpulse()
  coinPulseCount++;
  pulseTime = millis();
DON'T Cross post!
Keep your question here: coins acceptor CH-932 - Programming Questions - Arduino Forum
// Per.
