I am using the program and schematic that came with the starter kit for the motorized pinwheel project. However, instead of 9v batter I am using a 8v battery cell from the airsoft gun. I did everything right, but i believe the problem is in the transistor. Any suggestions?
**The motor clicks when i press down the button, but does not fully rotate. However, when i simply connect the motor to the power source it fires rapidly.
Just to add a little more info to this thread, an "8v airsoft battery" is actually an 8.4v NiMH or NiCD battery pack, typically no less than 700mAh, usually 1500mAhr or more.
If the transistor requires 12v, a 9v battery may have been able to work, but a 8.4v battery may not.
