I have been pulling my hair out for some time, attempting to make my boats throttle run by utilizing a servo to pull the throttle.
I honestly know very little about how to program an Arduino. I wish I did this would be a lot easier. So I'm asking for help. I'm about to paint a picture so bare with me, so if you're not familiar, it may be easier to understand. I will try to attach photos and explain examples.
Currently, I have a 21' Carolina skiff DLX boat. The main motor is a 115 Suzuki. The smaller motor, a 9.9 Mercury, is about 18 inches to the right of the primary motor. Its purpose is to maneuver the boat while fishing in shallow water.
I want the controller to be a joystick with 4 momentary (tactile) buttons and a trigger on the front. (see photo 1)
The buttons A, B, C, D, and the trigger E. A-D will be in a 2x2 set. A will be the top button far left. B will be bottom left. C will be top Right. D will be bottom right .
Button A function will be Run
Button B will be Idle
Button C will be throttle Up
Button D will be throttle Down
The servo, when attached to the throttle in the "run" position, the servo will move to the specified position 1-6. 1 being about 15% throttle. 6 about 90% throttle. When you press the Idle button regardless of what gear the boat is in, the throttle goes back to zero throttle. The trigger will be full throttle at any time when held.
Hopefully, if you have made it this far, I painted a good enough picture for you to understand my goals with this project.
The attached link is the type of joystick I would like to use, but unfortunately, they are about 900 bucks. I have the frame of the exact joystick with no buttons or componets.
https://www.suregripcontrols.com/je-handle-product_template.htm
The below website is a type of throttle control called an Itroll, which virtually the same concept but not in a joystick. I need to know where I can find the correct buttons that I can add to the joystick so that it will function properly.
http://www.itroll.us/itroll.price.buy.2020.html
Im pretty sure the Itroll is just an Arduino that is commercially manufactured.
If needed, I will purchase all the parts and mail them to whoever will help and also compensate the person for there time. I want the completion of this project to be by the middle of March. Thanks Please feel free to email me tahoyle@gmail.com, and I will provide further contact info so that we can talk about it more in-depth.
