I am trying to make an Arduino controlled flying wing and a joystick app to control the plane but I can't get the app right as well as the evelvon mixing code plus the data receiving part from the app too. The app is made in MIT app inventor so if you can help please do. (Arduino Bluetooth flying wing - MIT App Inventor Help - MIT App Inventor Community) Processing: wing_.aia...
Please help me.
You are in the wrong forum!
@mayinjabob indeed you are.
Installation and troubleshooting is for Problems with the Arduino itself NOT your project. It says so in the description. Therefore I have moved your post here.
Thanks but can u help me
fw.ino (3.2 KB)
That is the ino file.
Not sure, I have no experience with App Inventor, so I am not sure how your code relates and is different from pre written code. You ask for "help" but you are not very forthcoming about what you want help with.
Please read this
how to get the best out of this forum
At the very least we need you to post the code in the proper way, in a code box. We don't even know what Arduino you are using, nor the schematic of what you are working on.
Then you need to describe what the code actually does as opposed to what you want it to do.
Mike,
I have installed bob's app and run it. The two joysticks on his screen are not responding correctly -- their movements are not correct. Moving a finger over the right joystick makes the left joystick move. Probably a some simple errors in the app blocks.
So at this stage the app has to be corrected before he should look at what occurs on the Arduino side.
The app is a good example of needing reliable fast BT comms. Interesting to see how it develops.
OK let me try fixing the app first thanks but also could anyone help with a sample code that can turn two servos into proper elevon control for pitch and roll.
Hi @mayinjabob
Your flying-wing's elevons need to move in the same direction for pitch and in opposite directions for roll. However, you also have to take into account that your elevon servos are likely to be a mirror image of each other, (with respect to the centre line of your fuselage), which means that same signal will cause the servos to move in opposite directions.
First, you'll need to map your roll and pitch input control signals to the values you're using to control the servos, which is usually either: 0 to 180 with centre at 90 or in microseconds: 1000us to 2000us with centre at 1500us.
Taking this mirroring into account, the motor mixing for a flying-wing is relatively simple:
servo1 = mapped_pitch + mapped_roll;
servo2 = -mapped_pitch + mapped_roll;
Finally, you'll need to constrain the output to the servos so that the addition or subtraction of motor mixing doesn't exceed the servos' minimum and maximum values.
To ensure that the servos are going in the right directions just try it out on the bench (with any motor disconnected or props removed). If the servos are going in the wrong direction then reverse either the polarity of your pitch and roll control input, or the values in the motor mixer.
OK if I may ask why first add the pitch and then subtract it. And then what about when I need the craft to do a roll and not pitch only and vicevaser and rather not doing the same at once, because in may code I have some thing where I kind of check whether to take a value for either a roll or a pitch but there after I then have to give a value for the other axis so as for it to stay neutral. Also advice me on that please.
If you can't work this out, I doubt building this flying wing is a good idea!
It's basic physics!!!!
No I can bit I worries me that I may do the same things at once. I building it for its simplicity 3CHs and few electronics that is it.
Hi @mayinjabob
My apologies, I guess I could've explained that a lot better.
First subtract 1500 from mapped pitch and roll values, mix, then add 1500 using an optional servo trim offset at 50 (for 50%, or in other words stick centre):
mappedPitch = mapped_pitch - 1500;
mappedRoll = mapped_roll - 1500;
servo1 = servo1 + (10 * offset) + 1000;
servo2 = servo2 + (10 * offset) + 1000;
constrain(servo1);
constrain(servo2);
For example, you start with your pitch and roll stick centred, this generates pitch and roll values of 1500. If you now move the roll stick to the left it generates a value of 1300, while pitch remains at 1500:
mapped_pitch = 1500 - 1500 = 0
mapped_roll = 1300 - 1500 = -200
servo1 = 0 + (-200) = -200
servo2 = -0 + (-200) = -200
servo1 = -200 + (10 * 50) + 1000 = 1300
servo2 = -200 + (10 * 50) + 1000 = 1300
constrain(1300) = 1300
Since the servos are mirrored they move in the opposite direction so one elevon moves up while the other down, causing the aircraft to roll.
Taking another example, returning the roll to 1500, you now pull the stick back so that the pitch is at now at 1750:
mapped_pitch = 1750 - 1500 = 250
mapped_roll = 1500 - 1500 = 0
servo1 = (+250) + 0 = 250
servo2 = (-250) + 0 = -250
servo1 = 250 + (10 * 50) + 1000 = 1750
servo2 = -250 + (10 * 50) + 1000 = 1250
constrain(1750) = 1750
constrain(1250) = 1250
Since the servos are mirrored they move in the opposite directions, however since one is commanded to move up and the other down, the overall effect is that both elevons move up, causing the aircraft to pitch.
Wow had to read that 2 times. OK let try that thank you.
What of both roll and pitch having values that are at times the same what happens then
Hi @mayinjabob
Might I ask how you're powering your Arduino, motor and servos?
If you're using a brushed motor then it's easiest to use a H-bridge motor driver, brushless motors require an Electronic Speed Controller or ESC. Either need to be rated to exceed both the voltage of your battery and the maximum voltage/current used by your motor.
Both Servos will require a regulated power source that can supply at least 2A of current at 5V. Note that a common mistake is to attempt to power the servos from the Arduino 5V pin. Also, a breadboard isn't suitable for this amount of current.
Traditionally on model fixed wing aircraft, the battery directly powers an ESC through a wiring harness (soldered wires rated to exceed the maximum expected current) that in turn powers the motor. However, ESCs often have a 5V Battery Elimination Circuit or BEC. This provides the regulated 5V power for the matchbox sized RC receiver that additionally powers any servos that are connected to it as well.
For now am using a DC charger of 12v and 1.5A and a MOSFET to drive the motor, and am also having problems with driving it properly. And the servos are not working at all but am going to post the other things the code, app and schematics too. And on that note I would like to thank you for your constant support.
Progress so far......
Nice.
But yer gonna have to get way better response to control input if you actually ever fly something with this setup.
a7
