Servos start twitching/jittering as soon as said sketch is uploaded
I’ve spent last 2-months learning from the post on Arduino forum and debugging sketch as much as possible. I’ve already burnt 2 MEGA boards in learning process which brings me to my first post for help. Thank you in advance for your consideration as I’m new to this.
HARDWARE:
-Arduino MEGA 2560 then switched to Keyestudio PLUS board (servo on pin 2 & pin 5)
-Servos types: 35kg. DSSERVO RDS3235
-FlySky FS-i6x 10ch transmitter / Flysky FS-IA10B 10ch Receiver Support iBUS
-FlySky receiver attached via iBUS to Keyestudio PLUS board (Arduino MEGA).
FYI: Same issues encountered using original Arduino MEGA 2560 board (burning 2 MEGA boards in process), so its not the Chinese board.
SKECTCHES:
WORKING sketches:
Sweep” Arduino example sketch works. So I know nothing wrong with servos.
A sketch prompt for direct angles works, for example:
myServo.write(0); myServo.write(45);myServo.write(90);myServo.write(180);
NOT WORKING sketch:
As soon as said sketch uploaded, servos begin twitching/jittering. Tho I am still able to control servo movement via FlySky transmitter using VRA and VRB knobs the servos move with a twitching/jittering.
POWER:
12V 1amp barrel DC on Arduino MEGA/Keyestudio PLUS board
  Arduino FS-I6X Demo fsi6x-arduino-mega-ibus.ino
  Read iBus output port from FS-IA6B receiver module
  Display values for Channel 5 and Channel 6 (servos attached) on Serial Monitor
  Channel functions by Ricardo Paiva https://gist.github.com/werneckpaiva/
  Additions by DroneBot Workshop 2021 https://dronebotworkshop.com
//Inlcude Libraries
#include <AFMotor.h>
#include <Servo.h>                	// Include Servo Library
#include <IBusBM.h>               // Include iBusBM Library
IBusBM ibus;                      // Create iBus Object
Servo servoVer;                   // Vertical Servo servoVer
Servo servoHor;                   // Horizontal Servo servoHor
int servoVerPin = 5;
int servoHorPin = 2;
int posServoVer = 0;
int posServoHor = 0;
int CH5;
int CH6;
// Read the number of a given channel and convert to the range provided.
// If the channel is off, return the default value
int readChannel(byte channelInput, int minLimit, int maxLimit, int defaultValue) {
    uint16_t ch = ibus.readChannel(channelInput);
    if (ch < 100) return defaultValue;
    return map(ch, 1000, 2000, minLimit, maxLimit);
        ibus.begin(Serial1);
        servoVer.attach(servoVerPin);                      // attach servoVer to servorVerPin 5 FlySky channel 6
        servoHor.attach(servoHorPin);                      // attach servoHor to servorHorPin 2 FlySky channel 5
        servoVer.write(posServoVer);                       // start the servo at position 0 middle Vertical
        servoHor.write(posServoHor);                       // start the servo at position 0 middle Horizontal
        CH5 = readChannel(4, -100, 100, 0);
        posServoVer = map(CH5, 0, 110, 0, 180);
        delay(100);
        CH6 = readChannel(5, -100, 100, 0);
        posServoHor = map(CH6, 0, 110, 0, 180);
        delay(100);
Schematic.
Inadequate servo power supply. Power them separately, and don't forget to connect the grounds.
Thank you for your comment.
I am powering separately via barrel 12v, the USB-C cable you see there was for uploading sketch purposes only.
Again. Complete schematic. Something's wrong.
See this post, today:
That is the problem. Those servos are rated for 7.4 V maximum, at typically 2.5 Amperes per servo.
And you say you have spent two months on this?
ok. But how is it they work when testing with sweep arduino sketch example whilst they are even connected via USB-C. I don't run them very long only for testing.
The servo power supply must be capable of providing 5 to 7.4V at 5 Amperes for two of those servos.
Sweep doesn't equal to driving them at full speed.
How is your servo power supply ?
Will look further into what you are saying, as I mentioned this is my first project. Appreciate you mate!
I am using the barrel 12v on keyestudio PLUS board.
Try:
ibus.begin(Serial1, IBUSBM_NOTIMER);
and add
    ibus.loop();
forget that, just seen you have delays in the loop.
I don't know that board. But I would imagine that if you use that to power servo, you drive them at 5V supplied by onboard voltage regulator ? And your servos draw multiple amps.
Find a 5-7V 5A power supply to power servos separately.
The Keyestudio board claims it can supply 2A at 5V so it's just barely enough for one servo if it has a heavy load.
How does it act if just ONE servo is connect?
Coul be software, the way iBUS works.
will try your suggestion, cheers mate!
ok. I just tired again with one servo but still same issue.
Since it works with the other sketches, I suspect a software issue but I'm not familiar with iBUS
Run the DroneBotWorkShop original code to verify your system works. Add iBus later.
Rather than using map and servo.write try servo.writeMicroseconds(us)
