Arduino crashing from analogue input pin connecting to accel,
Im new to this forum and Arduino itself so excuse the mess that is my code!
i have two accelerometers plugging into the 6 analogue inputs on my Uno.
When 0-2 are plugged in from accelerometer one's xyz, the programme operates as should.
Include the x from accelerometer two and everything is still ok.
However, the minute y or z are connected to ai4 or ai5 then the arduino appears to crash and needs resetting.
ive included my code, any help would be GREATLY appreciated.
many thanks,
RGUBell!
// LIBRARIES
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4);
// ASSIGN LED COLOURS TO INTEGER for pins
int redled = 9;
int yelled = 8;
int greled = 7;
int buttonin = 5;
// ASSIGN SWITCH FOR PHASE DISPLAY for pins
int SwitchRight = 2;
int SwitchLeft = 3;
  float Xone;
  float Yone;
  float Zone;
  float Xtwo;
  float Ytwo;
  float Ztwo;
  float ABSXone;
  float ABSYone;
  float ABSZone;
  float ABSXtwo;
  float ABSYtwo;
  float ABSZtwo;
int scale = 3;
double counter = 0;
// INITAL SEQUENCE UPON START UP
  Serial.begin(115200); //start serial at 9600 baud
  Serial.println("1");
  pinMode(redled, OUTPUT); //set digital pins
  pinMode(yelled, OUTPUT);
  pinMode(greled, OUTPUT);
  pinMode(buttonin, INPUT);
  lcd.begin(); //initiate lcd
  Wire.begin();
  lcd.backlight();
  lcd.setCursor(0, 0);     //initial title splash screen
  lcd.print("Kieran Bell");
  lcd.setCursor(0, 1);
  lcd.print("1306903");
  lcd.setCursor(0, 3);
  lcd.print("MEng Project");
  // LAMP TEST SEQUENCE
      digitalWrite(redled, LOW);
      digitalWrite(greled, LOW);
      digitalWrite(yelled, HIGH);
  delay (1000);
      digitalWrite(greled, HIGH);
      digitalWrite(yelled, LOW);
  delay (1000);
  delay (1000);
  lcd.clear();
  lcd.setCursor(0, 0);    //secondary title splash screen
  lcd.print("Generator Condition");
  lcd.print("   Monitoring System");
  lcd.print("  Vibration Sensing");
      digitalWrite(redled, HIGH);
  delay (1000);
  delay (1000);
  delay (500);
  lcd.clear();
  delay (500);
  Xone = 0;
  Yone = 0;
  Zone = 0;
  Xtwo = 0;
  Ytwo = 0;
  Ztwo = 0;
  int SwitchOne;
  int SwitchTwo;
  SwitchOne = digitalRead(SwitchRight);
  SwitchTwo = digitalRead(SwitchLeft);
  int rawXone = analogRead(A0);
  int rawYone = analogRead(A1);
  int rawZone = analogRead(A2);
  int rawXtwo = analogRead(A3);
  int rawYtwo = analogRead(A4);
  int rawZtwo = analogRead(A5);
  float scaledXone, scaledYone, scaledZone;
  float scaledXtwo, scaledYtwo, scaledZtwo;
  scaledXone = mapf(rawXone, 0, 675, -scale, scale); // 3.3/5 *1023 ~=675
  scaledYone = mapf(rawYone, 0, 675, -scale, scale);
  scaledZone = mapf(rawZone, 0, 675, -scale, scale);
  scaledXtwo = mapf(rawXtwo, 0, 675, -scale, scale);
  scaledYtwo = mapf(rawYtwo, 0, 675, -scale, scale);
  scaledZtwo = mapf(rawZtwo, 0, 675, -scale, scale);
  ABSXone = abs(scaledXone);
  ABSYone = abs(scaledYone);
  ABSZone = abs(scaledZone);
  ABSXtwo = abs(scaledXtwo);
  ABSYtwo = abs(scaledYtwo);
  ABSZtwo = abs(scaledZtwo);
  // WRITE NEW PEAK VALUE
  if ( ABSXone > Xone ) { Xone = scaledXone; }
  if ( ABSYone > Yone ) { Yone = scaledYone; }
  if ( ABSZone > Zone ) { Zone = scaledZone; }
  if ( ABSXtwo > Xtwo ) { Xtwo = scaledXtwo; }
  if ( ABSYtwo > Ytwo ) { Ytwo = scaledYtwo; }
  if ( ABSZtwo > Ztwo ) { Ztwo = scaledZtwo; }
  if ( counter == 1000 || counter == 0)
       if ( SwitchTwo == 0 && SwitchOne == 1 )
       lcd.print("Brng. Vibr. (g) NDE");
       lcd.print("X: ");
       lcd.print(ABSXone);
       lcd.setCursor(9, 1);
       lcd.print("(Pk: ");
       lcd.print(Xone);
       lcd.print(")");
       lcd.setCursor(0, 2);
       lcd.print("Y: ");
       lcd.print(abs(ABSYone));
       lcd.setCursor(9, 2);
       lcd.print("(Pk: ");
       lcd.print(Yone);
       lcd.print(")");
       lcd.print("Z: ");
       lcd.print(abs(ABSZone));
       lcd.setCursor(9, 3);
       lcd.print("(Pk: ");
       lcd.print(Zone);
       lcd.print(")");
       else //if ( SwitchTwo == 1 && SwitchOne == 0 )
       lcd.print("Brng. Vibr. (g)  DE");
       lcd.print("X: ");
       lcd.print(ABSXtwo);
       lcd.print("(Pk: ");
       lcd.print(Xtwo);
       lcd.print(")");
       lcd.print("Y: ");
       lcd.print(ABSYtwo);
       lcd.print("(Pk: ");
       lcd.print(Ytwo);
       lcd.print(")");
       lcd.print("Z: ");
       lcd.print(ABSZtwo);
       lcd.print("(Pk: ");
       lcd.print(Ztwo);
       lcd.print(")");
  // ALARM SETUP
  if ( Xone > 1 || Yone > 1 || Zone > 2)
  else if( Xone > 0.5 || Yone > 0.5 || Zone > 1.5)
  counter = 0;
  //delay(100);
  // RATHER THAN DELAY, IMPLEMENT COUNTER TO RUN THROUGH CODE.
  // IF COUNTER REACHES VALUE, PRINT LCD
  counter++;
  float mapf(float x, float in_min, float in_max, float out_min, float out_max)
   return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
A4 and A5 are the I2C pins, which you're already using for the LCD.
(edit: more likely, you have the LCD on the dedicated I2C pins, but those are electrically the same as A4 and A5.)
Manor,
Do you mean that i cant use the A4 and A5 because they are in some way tied to the I2C connections i am using for my LCD? sorry, im a bit confused.
They ARE the I2C connections: check with your ohmeter and you'll see they are indeed connected.
From the Uno product page:
TWI: A4 or SDA pin and A5 or SCL pin. Support TWI communication using the Wire library.
Ah great,
so to resolve my issue i need to upgrade to a Mega, is that correct?
thanks for your help
RGUBell:
I'd say so, but others might have other solutions.
Mega, or a Promini or other SMD '328P with 8 analog inputs, or Atmega1284P which has 8 analog inputs and has separate SCL/SDA pins. Here's one form factor of '1284P board I offer:
http://www.crossroadsfencing.com/BobuinoRev17/
The MightyCore makes it easy to use the '1284P in the IDE. My boards are the Bobuino board type (defines the software names to physical pin mapping) running at 16 MHz.
