Arduino create agent on chromebook
installed arduino cloud app. plugged in arduino and an LED lights up.
downloaded ArduinoCreateAgent-1.3.5-linux-amd64-installer.tar.gz, used 7zipper to extract it and I have a .run file. how to I run it.
Googling says chromebook doesn't run .run files. I put in linux and installed it there but thats in linux side and still the same.
the arduino cloud doesn't see a port. I'm helping out with coderdojo so not my arduino or cable.
Question is how to run that file on chromebook so i can start programming.
Thank you,
Matthew
How did you install the create agent?
Try again from there?
That is for Chromebook….
Thank you for replying.
I followed this link Arduino Cloud - Getting started..
it asked me to download the file which automatically ended with .tar.gz, after extracting I run into mentioned problem. I can't install it.
I have the arduino cloud app thanks.
Matthew
What did
Select your OS as?
If that installation link worked correctly then maybe you could use:
