Hi
I want to be able to use the arduinos internal EEPROM but I also have to use the RX TX pins. The EEPROM has to read at the start of the code and sometimes used in the loop. Is there a component that can switch (disconnect) the RX and TX pins from the arduino, I could use relays but there expensive and big. Can transistors or some another component be used?
Thanks
Ian
