I have an Arduino Uno clone, a dfPlayer module and a CC1101 D-SUN module. The CC1101 module looks like this:
When I connect the Arduino with my PC via USB,everything works fine.
When I connect it with any phone charger, something goes wrong. (The orange LED of the dfPlayer caught my eye btw because it doesn't turn off.)
I'm pretty sure I correctly wired everything together. I have also double checked that everything is actually connected as expected using a miltimeter. (So it shouldn't be a faulty wire or breadboard.)
Wireing between CC1101 module and Arduino Uno :
GDO0 -> 6
MISO -> 12
MOSI -> 11
GND -> GND
CSN -> 10
GDO2 -> -
SCK -> 13
VCC -> 3.3v
Wireing between dfPlayer module and Arduino:
VCC -> 3.3v
GND -> GND
GND -> GND (Yes, I connected both GND pins of the dfPlayer to the Arduino's GND)
RX -> 1k resistor -> 8
TX -> 9
I'm not using Serial in my sketch. But just in case I have tried bridging ther Arduino's TX and RX. It made no difference though.
So yeah the usual issues for "Arduino only works on PC" don't appear to be the problem.
I mean missing ground connection and a Serial.begin call.
I'm running out of ideas. I ripped everythong appart multiple times replaced the Arduino, wires and breadboard with brand new ones multiple times and even continuity tested the connections. I just don't understand what is wrong here.
My sketch can be seen here: Long-Range-Arduino-Doorbell/ArduinoDoorbellReceiver.ino at master · T-vK/Long-Range-Arduino-Doorbell · GitHub
The DEBUG variable is commented out and I have verified that there is no Serial output when I do so. (In case you were thinking another library might define DEBUG.)
