Arduino does not send data via bluetooth
I have a HC-05 module, and Arduino Uno. I have connected everythink like that, only instead 20k transistor I used 2x10k (I want to send data from ultrasonic module).
I writed simple code, to check if bt module works:
#include <SoftwareSerial.h>
SoftwareSerial bluetooth(2, 3);
  Serial.begin (9600);
  bluetooth.begin(9600);
  if (bluetooth.available())
    Serial.write(bluetooth.read());
  if (Serial.available())
    bluetooth.write(Serial.read());
 delay(50);
And what is my problem. I can send data from terminal on my phone, and it appears on my pc, but it does not work when I type somethink on my pc. It doesn't show on my phone.
I connected the bt module to 2 and 3 pin, because on 0 and 1 (and without SoftwareSerial.h) even sending data from phone to pc wasn't working.
Thanks.
http://tronixlabs.com.au/news/tutorial-using-hc06-bluetooth-to-serial-wireless-uart-adaptors-with-arduino/
I still cant receive data from pc, it is not showing on my phone. Is this connected correct?
No. You have connected bluetooth to hardware serial, pins 0,1,while the programme is trying to talk to it over software serial, pin 2,3.
It is connected to 2, 3 (hard to see on the photo).
