Hi, I have hooked up an HC-05 bluetooth module to my Arduino Uno, and for some reason I'm not able to send data from the bluetooth module over to my Android phone (which is paired). Here's the code:
#include <SoftwareSerial.h>
int rx = 6;
int tx = 5;
SoftwareSerial myserial(rx, tx);
myserial.begin(9600);
myserial.println("Hello world");
delay(100);
I forgot to mention that I do in fact have a terminal software on my phone, but hello world will not print into the terminal. But I can send data from phone to BT module, but can't send data from BT module to phone for some reason...
How do you know you are doing that? And I'm betting you are not.
There is nothing wrong with your code per se, which suggests there is a lot wrong with your wiring and procedure. All of the latter is at the phone end.
You might find the following background notes useful
Well, I'm pretty sure I'm able to do that because I had wrote a sketch where if the BT received data from the phone the code would check if the incoming data was either a '1' or '0' and depending on which one of those it recieved it would turn an LED on/off. And I was successful in doing this. So that tells me that there is a connection established between the BT module and phone.
Okay, so I guess it was just the terminal software I was using, because I installed a different one and everything was working fine. I'm assuming the other terminal app just didn't print ASCII characters...
