Arduino is not showing up in device manager (not in ports or as an unknown device).
Physically on the board the light turns on when connected to some power source.
The light with "L" and the power on turns on.
I tried changing cables and tried using in 2 different computers and a laptop it does not make any sound or anything when i connect it to my pc or laptop.
Sadly it never worked before but it used to get detected before like the beep would come in my windows 7 earlier but when i got my new pc it does not work i tried using it back in win 7 in my friends pc still it did not detect it did not work but . And no i did not connect anything just the usb cable to it.
Does your new computer beep when you connect other devices? I ask because that sound is configurable, so if it is turned off and the beep is the sole indicator you are using for the "working' state, then the lack of a beep would be misleading.
Your photos show you have an ATMEGA16U2 as the USB to serial interface.
You could try following the guide I posted previously. The image in the guide shows a slightly different board layout around the 6-pin header by the RESET button.
