Arduino due Is not getting install
Hello everyone. I have bought new arduino due. I am trying to install it in my windows 10 but no success. whenwver i plug it in my pc I go to device manager and update its driver it shows
The drivers for this device are not installed. (Code 28)
Access is denied.
I have tried many other ways but no success can anyone tell me how to install it.
I am getting this while uploading sketch if I installed using FTDI drivers. Please help me.
I suspect a charge only USB cable. Try with another USB cable (power + data).
I have changed the wire too but still no success. How can I get to know that its power cable or power+data?
Mine one is data+ charging. Kindly give me some solution
i have done that too. Try to understand once I add path for driver installation in device manager it gives me the output.
The drivers for your device are found but error occurred while installing them.
Access is denied.
I don't know how to solve this problem I have done a number of methods.
I have done dealing of signature drivers as wee.
But no success. Kindly guide me as this is the only relevant forum.
You can try to delete the entire sam folder before reinstalling the DUE compiler files:
In an IDE window, select File>Preferences. Click in the URL at the bottom:
C/Users/XXX/Appdata/Local/Arduino 15/preferences.txt
Follow this path:
packages/arduino/hardware/sam
Delete sam folder and close all IDE windows.
Open a new IDE window and reinstall arduino DUE files:
Tools/board/board manager/Arduino Sam boards (Arduino Cortex M3)
Try to select a previous version, not the most recent one.
Push the Erase button for 3 seconds, then the Reset button for 3 seconds before uploading a new sketch.
