Hallo Everyone,
I ask you again your help to solve an issue of my project.
For space reasons, I am using a 108 LEDs matrix (WS2812b) as indicator of the temperature and current of 6 fuel cells. Those fuel cells provide the power to run a servo-motor of 750 KVA. For me is critical to have an actual reference of current and temperature value to keep my fuel cells (extremely expensive) safe.
My problem comes when I tried to put everthing together. I can drive my motor using the servo library of the arduino and I can drive the LEDs using the NeoPixel library but they don't work together. As soon as I need to refresh the LEDs display, I lost the motor PWM Signal.
After some time I found this paragraph inside the NeoPixel library:
void Adafruit_NeoPixel::show(void) {
if(!pixels) return;
while((micros() - endTime) < 50L);
// endTime is a private member (rather than global var) so that mutliple
// instances on different pins can be quickly issued in succession (each
// instance doesn't delay the next).
// In order to make this code runtime-configurable to work with any pin,
// SBI/CBI instructions are eschewed in favor of full PORT writes via the
// OUT or ST instructions. It relies on two facts: that peripheral
// functions (such as PWM) take precedence on output pins, so our PORT-
// wide writes won't interfere, and that interrupts are globally disabled
// while data is being issued to the LEDs, so no other code will be
// accessing the PORT. The code takes an initial 'snapshot' of the PORT
// state, computes 'pin high' and 'pin low' values, and writes these back
// to the PORT register as needed.
noInterrupts(); // Need 100% focus on instruction timing
Since I have the Motor pin and the LEDs pin on the same port of the Arduino (See attachments), I changed the NeoPixel library trying to get a solution for my problem but I couldn't make it.
Until now my system runs without LEDs but is because I disabled the following lines:
for ( int i = 0; i < 6; i++)
if (currArray[i] != oldcurrArray[i])// || (tempArray[i] != oldtempArray[i]))
// Only refresh if some value has changed.
// RefreshLEDs();
// leds.show();
My question is: What should I modify into the NeoPixel library to control my motor while at the same time I am refreshing my LEDs? That means what should I modify at the "show" function? or should I change my approach and look for another library? If that is the case, which one do you recommend me?
I attached you two files to check my hardware. But as I told you they work separately just fine. I also attached my software if you want to take a look, but I warn you it is huge.
Thanks for your help.
H2PU_mainV8.ino (47.5 KB)
