Hello. I bought arduino due few days ago. Datasheet says that DUE has pwm on 2-13 pins. But it's written on the pins 22-53 that there are pwm too. Are that pins works with pwm?
Hello s1stemdev
Welcome to the best Arduino forum ever.
Give them a try and code a test programm simply.
You have a defined macro digitalPinHasPWM ( n ) ) that tells you whether the particular pin has PWM or not. Try this program.
void setup ()
Serial.begin ( 115200 );
for ( byte n = 0; n < NUM_DIGITAL_PINS; n ++ )
Serial.print ( n );
Serial.print ( " " );
Serial.println ( digitalPinHasPWM ( n ) );
void loop ()
Thanks. Only pins 2-13 has pwm. But why does it say on pins 22-53 that they support PWM?
Who ?
Check out an Arduino Due pinout diagram. The ATSAM3X8E MCU has far more than 12 pins supporting PWM operation. Actually, just the dedicated PWM controller has 8 channels each having 2 outputs for a total 16 PWM pins. Then, there are numerous timer outputs which also support PWM operation.
If you really want to delve into it, download the datasheet, and compare it to a pinout diagram, then match the MCU pins to Arduino pins. Fair warning though; the datasheet is almost 1500 pages long, and pin functions aren't listed pin 1 to pin 144. (Yes, the MCU has 144 pins total, it's a QFP144 package.) Oh, and also, there are two pairs of pins that are tied together on the board. Check my post history if you want to explore that rabbit hole.
