I am trying to build a system for remote controlling a sound controller which I am going to feed using an Arduino Due. I want to communicate using ethernet and for that reason, I planned to use Due as the server and use Processing to create a GUI as the client so I can connect to the Due from my PC and control the pins from the GUI.
I am relatively new to using ethernet for control so I am trying to learn the libraries for both Arduino (which I am using EthernetENC library because I have an ENC28J60 breakout board to connect the Due to the router) and Processing 3. Because of this reason, I first wanted to do something more simple to get the hang of it so I decided to use an RGB LED to control the color which is similar to what I am actually planning to do.
I managed to control the LED by creating a web page and from the web page I can control the LED light just like I wanted. Here is the Arduino code for that:
// After uploading the code use the command prompt and type "ping <Static/UDHP IP>" to check if the server is ready.
#include <SPI.h>
#include <EthernetENC.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 137, 205 }; // IP address in LAN – need to change according to your Network address
byte gateway[] = { 192, 168, 137, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
String readString;
int redPin = 13;
int greenPin = 12;
int bluePin = 11;
pinMode(redPin, OUTPUT); //pin selected to control
pinMode(bluePin, OUTPUT); //pin selected to control
pinMode(greenPin, OUTPUT); //pin selected to control
// Turn off all the channels
digitalWrite(redPin, HIGH);
digitalWrite(greenPin, HIGH);
digitalWrite(bluePin, HIGH);
// Test LED
digitalWrite(redPin, LOW); // set pin high
delay(250);
digitalWrite(redPin, HIGH); // set pin low
delay(250);
digitalWrite(greenPin, LOW); // set pin high
delay(250);
digitalWrite(greenPin, HIGH); // set pin low
delay(250);
digitalWrite(bluePin, LOW); // set pin low
delay(250);
digitalWrite(bluePin, HIGH); // set pin high
//start Ethernet
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//if HTTP request has ended– 0x0D is Carriage Return \n ASCII
if (c == 0x0D) {
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<TITLE> ETHERNET CONTROLLER</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<hr>");
client.println("<H1 style=\"color:green;\">ETHERNET CONTROLLER</H1>");
client.println("<H1 style=\"color:green;\">COLOUR CONTROLLER FROM WEBPAGE</H1>");
client.println("<H2><a href=\"/?RED\"\">Red</a><br></H2>");
client.println("<H2><a href=\"/?GREEN\"\">Green</a><br></H2>");
client.println("<H2><a href=\"/?BLUE\"\">Blue</a><br></H2>");
client.println("</BODY>");
client.println("</HTML>");
delay(10);
// stopping client
client.stop();
// control arduino pin
if (readString.indexOf("?RED") > -1) // checks for RED
digitalWrite(redPin, !digitalRead(redPin)); // toggle redPin
Serial.println("RED has toggled");
if (readString.indexOf("?GREEN") > -1) // checks for GREEN
digitalWrite(greenPin, !digitalRead(greenPin)); // toggle greenPin
Serial.println("GREEN has toggled");
if (readString.indexOf("?BLUE") > -1) // checks for BLUE
digitalWrite(bluePin, !digitalRead(bluePin)); // toggle bluePin
Serial.println("BLUE has toggled");
//clearing string for next read
readString = "";
This is the web page I am using to control the LED
Right now I am trying to translate this to Processing 3 and I created a GUI with the following code and embedded the links for RED, GREEN and BLUE from the web page to the buttons just to see how it feels like but this is obviously not what I want to do:
import processing.net.*;
// Button settings
int redbuttonX, redbuttonY, greenbuttonX, greenbuttonY, bluebuttonX, bluebuttonY;
int buttonSizeX = 150; // Diameter of button
int buttonSizeY = 80;
color red, green, blue;
color redHighlight, greenHighlight, blueHighlight;
boolean redOver = false;
boolean redPressed = false;
boolean greenOver = false;
boolean greenPressed = false;
boolean blueOver = false;
boolean bluePressed = false;
size(400, 600);
background(color(150));
red = color(250,0,0);
green = color(0,250,0);
blue = color(0,0,250);
redHighlight = color(200,125,125);
greenHighlight = color(125,200,125);
blueHighlight = color(125,125,200);
redbuttonX = width/2-buttonSizeX/2;
redbuttonY = height/2-buttonSizeY/2-100;
greenbuttonX = width/2-buttonSizeX/2;
greenbuttonY = height/2-buttonSizeY/2;
bluebuttonX = width/2-buttonSizeX/2;
bluebuttonY = height/2-buttonSizeY/2+100;
void draw() {
update(mouseX, mouseY);
if (redOver) {
fill(redHighlight);
fill(red);
stroke(25);
strokeWeight(5);
rect(redbuttonX, redbuttonY, buttonSizeX, buttonSizeY);
if (greenOver) {
fill(greenHighlight);
fill(green);
stroke(25);
strokeWeight(5);
rect(greenbuttonX, greenbuttonY, buttonSizeX, buttonSizeY);
if (blueOver) {
fill(blueHighlight);
fill(blue);
stroke(25);
strokeWeight(5);
rect(bluebuttonX, bluebuttonY, buttonSizeX, buttonSizeY);
fill(0);
textSize(30);
text("Ethernet RGB GUI", redbuttonX+buttonSizeX/4-80, redbuttonY+buttonSizeY/2-100);
void update(int x, int y) {
if ( overButton(redbuttonX, redbuttonY, buttonSizeX, buttonSizeY) ) {
redOver = true;
redOver = false;
if ( overButton(greenbuttonX, greenbuttonY, buttonSizeX, buttonSizeY) ) {
greenOver = true;
greenOver = false;
if ( overButton(bluebuttonX, bluebuttonY, buttonSizeX, buttonSizeY) ) {
blueOver = true;
blueOver = false;
void mousePressed() {
if (redOver) {
println("Red button has been pressed!");
if(!redPressed) {
link("http://192.168.137.205/?RED");
if (greenOver) {
println("Green button has been pressed!");
if(!greenPressed) {
link("http://192.168.137.205/?GREEN");
if (blueOver) {
println("Blue button has been pressed!");
if(!bluePressed) {
link("http://192.168.137.205/?BLUE");
delay(100);
boolean overButton(int x, int y, int width, int height) {
if (mouseX >= x && mouseX <= x+width &&
mouseY >= y && mouseY <= y+height) {
return true;
return false;
I tried multiple things to connect Processing to Arduino server as client and I managed to do it with this code:
Client c;
String input;
size(450, 255);
background(204);
stroke(0);
frameRate(25); // Slow it down a little
// Connect to the server's IP address and port
c = new Client(this, "192.168.137.205", 80); // Replace with your server's IP and port
void draw()
c.write("Hello Server\n");
// Receive data from server
if (c.available() > 0) {
input = c.readString();
input = input.substring(0, input.indexOf("\n")); // Only up to the newline
textSize(25);
text(input, width/2-75, height/2);
And with a simple Arduino code such as this:
#include <SPI.h>
String input;
String readString;
EthernetServerPrint server = EthernetServerPrint(80);
server.begin();
// if an incoming client connects, there will be bytes available to read:
if (client > -1) {
input = client.readString();
server.write("Hello Client\n");
Serial.println(input);
I tried to receive and send "Hello Client/Server" text but I can't read the "Hello Client" message on the Processing GUI and I can only see the "Hello Server" message after I close the Processing GUI. My goal here was to send strings such as "RED", "GREEN" and "BLUE" and check these strings in Arduino just like in the web page version to toggle the pins. I am not comfortable with ethernet libraries still and I would like to have some advices to improve my code. Thanks in advance!
