Salve vorrei utilizzare una eeprom 24c08 per salvare dei dati provenienti da un sensore.
La parte della sensoristica funziona ho problemi con la scrittura e lettura dei dati sulla eeprom.
Provo a scrivere il valore 0xAB sulla eeprom ma mi ritrovo il valore FF qualcuno mi sa dire dove sbaglio?
* Use the I2C bus with small EEPROMs
* 24C01, 20C02, 24C04, 24C08, 24C16
* Sketch: I2C_EEPROM_Small.pde
* Derived from sketch for 24C64 devices posted on
* http://www.arduino.cc/playground/Code/I2CEEPROM
* From hkhijhe Date: 01/10/2010
* This one by davekw7x
* March, 2011
* For a single device, connect as follows:
* EEPROM 4 (GND) to GND
* EEPROM 8 (Vcc) to Vcc (5 Volts)
* EEPROM 5 (SDA) to Arduino Analog Pin 4
* EEPROM 6 (SCL) to Arduino Analog Pin 5
* EEPROM 7 (WP) to GND
* EEPROM 1 (A0) to GND
* EEPROM 2 (A1) to GND
* EEPROM 3 (A2) to GND
#include <Wire.h>
// The seven-bit device address for EEPROMs
// I'll define it here rather than hard-code it inside all of the
// functions.
const byte DEVADDR = 0x50;
Wire.begin();
eeprom_write_byte( DEVADDR, 0, 0xAB );
Serial.println("Memory written");
delay(2000);
byte b = eeprom_read_byte(DEVADDR, 0);
Serial.println(b, HEX);
delay(2000);
void eeprom_write_byte(byte deviceaddress, int eeaddress, byte data)
// Three lsb of Device address byte are bits 8-10 of eeaddress
byte devaddr = deviceaddress | ((eeaddress >> 8) & 0x07);
byte addr = eeaddress;
Wire.beginTransmission(devaddr);
Wire.write(int(addr));
Wire.write(int(data));
Wire.endTransmission();
delay(10);
// Pages are blocks of 16 bytes, starting at 0x000.
// That is, pages start at 0x000, 0x010, 0x020, ...
// For a device "page write", the last byte must be
// on the same page as the first byte.
// No checking is done in this routine.
// TODO: Do some checking, or, better yet (maybe)
// make length an int and do repeated device
// page writes if necessary. (Then maybe rename to
// eeprom_write_pages or some such thing.)
void eeprom_write_page(byte deviceaddress, unsigned eeaddr,
const byte * data, byte length)
byte devaddr = deviceaddress | ((eeaddr >> 8) & 0x07);
byte addr = eeaddr;
for (int i = 0; i < length; i++) {
Wire.write(data[i]);
delay(10);
// TODO: Change to integer data type and return -1 if can't
// read.
int eeprom_read_byte(byte deviceaddress, unsigned eeaddr)
byte rdata = -1;
byte addr = eeaddr;
Wire.requestFrom(int(devaddr), 1);
if (Wire.available()) {
rdata = Wire.read();
return rdata;
// Returns number of bytes read from device
// Due to buffer size in the Wire library, don't read more than 30 bytes
// at a time! No checking is done in this function.
// TODO: Change length to int and make it so that it does repeated
// EEPROM reads for length greater than 30.
int eeprom_read_buffer(byte deviceaddr, unsigned eeaddr,
byte * buffer, byte length)
byte devaddr = deviceaddr | ((eeaddr >> 8) & 0x07);
byte addr = eeaddr;
Wire.requestFrom(devaddr, length);
int i;
for (i = 0; i < length && Wire.available(); i++) {
buffer[i] = Wire.read();
return i;
// The display is like hexdump -C. It will always
// begin and end on a 16-byte boundary.
void eeprom_dump(byte devaddr, unsigned addr, unsigned length)
// Start with the beginning of 16-bit page that contains the first byte
unsigned startaddr = addr & (~0x0f);
// stopaddr is address of next page after the last byte
unsigned stopaddr = (addr + length + 0x0f) & (~0x0f);
for (unsigned i = startaddr; i < stopaddr; i += 16) {
byte buffer[16]; // Hold a page of EEPROM
char outbuf[6]; //Room for three hex digits and ':' and ' ' and '\0'
sprintf(outbuf, "%03x: ", i);
Serial.print(outbuf);
eeprom_read_buffer(devaddr, i, buffer, 16);
for (int j = 0; j < 16; j++) {
if (j == 8) {
Serial.print(" ");
sprintf(outbuf, "%02x ", buffer[j]);
Serial.print(" |");
if (isprint(buffer[j])) {
Serial.print(buffer[j]);
else {
Serial.print('.');
Serial.println("|");
Il codice l'ho preso da internet era relativo ad un 24c16 che dovrebbe essere simile (dimensione minore a parte).
I collegamenti tra arduino e la eeprom sono effettuati come scritto sul codice un dubbio mi è venuto sull'indirizzo, il codice di esempio scriveva 0x51 ma in realtà da datasheet dovrebbe essere 0x50 con quei collegamenti, ho provato comunque in entrambi i modi ma ottengo sempre lo stesso risultato.
Grazie.
