hello guys, how to fix this error? thank you.
c:\Users\Septh\Documents\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp: In member function 'virtual void FirebaseHttpClientEsp8266::begin(const string&)':
c:\Users\Septh\Documents\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp:47:50: error: no matching function for call to 'begin(const char*, const char [60])'
47 | http_.begin(url.c_str(), kFirebaseFingerprint);
In file included from c:\Users\Septh\Documents\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp:9:
C:\Users\Septh\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:166:10: note: candidate: 'bool HTTPClient::begin(String, uint16_t, String)' (near match)
166 | bool begin(String host, uint16_t port, String uri = "/") __attribute__ ((error("obsolete API, use ::begin(WiFiClient, host, port, uri)")));
C:\Users\Septh\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:166:10: note: conversion of argument 2 would be ill-formed:
c:\Users\Septh\Documents\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp:47:30: error: invalid conversion from 'const char*' to 'uint16_t' {aka 'short unsigned int'} [-fpermissive]
| const char*
C:\Users\Septh\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:167:10: note: candidate: 'bool HTTPClient::begin(String, const uint8_t*)' (near match)
167 | bool begin(String url, const uint8_t httpsFingerprint[20]) __attribute__ ((error("obsolete API, use ::begin(WiFiClientSecure, ...)")));
C:\Users\Septh\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:167:10: note: conversion of argument 2 would be ill-formed:
c:\Users\Septh\Documents\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp:47:30: error: invalid conversion from 'const char*' to 'const uint8_t*' {aka 'const unsigned char*'} [-fpermissive]
| const char*
c:\Users\Septh\Documents\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp: In member function 'virtual void FirebaseHttpClientEsp8266::begin(const string&, const string&)':
c:\Users\Septh\Documents\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp:51:60: error: invalid conversion from 'const char*' to 'const uint8_t*' {aka 'const unsigned char*'} [-fpermissive]
51 | http_.begin(host.c_str(), kFirebasePort, path.c_str(), kFirebaseFingerprint);
| const char*
C:\Users\Septh\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:168:70: note: initializing argument 4 of 'bool HTTPClient::begin(String, uint16_t, String, const uint8_t*)'
168 | bool begin(String host, uint16_t port, String uri, const uint8_t httpsFingerprint[20]) __attribute__ ((error("obsolete API, use ::begin(WiFiClientSecure, ...)")));
Compilation error: exit status 1
upload the code (using code tags)?
what do you mean by using code tags?? thank you for the response.
this the code I use.
#include <ESP8266WiFi.h>
#include <FirebaseArduino.h>
// Set these to run example.
#define FIREBASE_HOST "sernsor-readings-default-rtdb.firebaseio.com"
#define FIREBASE_AUTH "YKTFxNhhZybXeWRR3kv7CDuqcwBJSqvcS9GNBodv"
#define WIFI_SSID "asdasdasd"
#define WIFI_PASSWORD "01001010"
// connect to wifi.
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("connecting");
Serial.print(".");
Serial.print("connected: ");
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
int n = 0;
// set value
Firebase.setFloat("number", 42.0);
// handle error
if (Firebase.failed()) {
Serial.print("setting /number failed:");
Serial.println(Firebase.error());
return;
// update value
Firebase.setFloat("number", 43.0);
// handle error
return;
// get value
Serial.print("number: ");
Serial.println(Firebase.getFloat("number"));
// remove value
Firebase.remove("number");
// set string value
Firebase.setString("message", "hello world");
// handle error
Serial.print("setting /message failed:");
return;
// set bool value
Firebase.setBool("truth", false);
// handle error
Serial.print("setting /truth failed:");
return;
// append a new value to /logs
String name = Firebase.pushInt("logs", n++);
// handle error
Serial.print("pushing /logs failed:");
return;
Serial.print("pushed: /logs/");
Serial.println(name);
Click the </> symbol and put your code (and error message) in between the ''' s
Please edit your posts
code tags
// connect to wifi.
Serial.print(".");
much easier to read.
edited the post . thank you.
I just want to connect the arduino and esp-01 to firebase and I encounterd the compiling error
Ok, well it might not be such a good idea to leave your firebase credentials here for public viewing.
What you are running is the FirebaseDemo_ESP8266.ino example isn't it ?
The library doesn't seem to be maintained which could indicate a source for your problem. The core you are using is quite fresh. I will see if i can compile it with an older core.
no problem with the credensitials sir, its just a sample also. Yes , I used the FirebaseDemo_ESP8266. thank you , I'm really struggling to look for a solution to this.
I compiled your code here on my PC and there was no error.
The lib : FirebaseArduino.h I downloaded from :
My IDE version is: 1.8.9,
I also compiled the code on 1.8.9 IDE version. I still have the same errors.
I compiled the code on my PC IDE 1.8.13 and got errors
In file included from C:\Users\bb\Documents\Arduino\libraries\firebase-arduino-master\src/Firebase.h:30,
from C:\Users\bb\Documents\Arduino\libraries\firebase-arduino-master\src/FirebaseArduino.h:22,
from C:\Users\bb\Documents\Arduino\sketch_may20a\sketch_may20a.ino:3:
C:\Users\bb\Documents\Arduino\libraries\firebase-arduino-master\src/FirebaseObject.h:109:11: error: StaticJsonBuffer is a class from ArduinoJson 5. Please see https://arduinojson.org/upgrade to learn how to upgrade your program to ArduinoJson version 6
109 | std::shared_ptr<StaticJsonBuffer<FIREBASE_JSONBUFFER_SIZE>> buffer_;
In file included from C:\Users\bb\Documents\Arduino\libraries\firebase-arduino-master\src/FirebaseArduino.h:22,
C:\Users\bb\Documents\Arduino\libraries\firebase-arduino-master\src/Firebase.h:86:11: error: StaticJsonBuffer is a class from ArduinoJson 5. Please see https://arduinojson.org/upgrade to learn how to upgrade your program to ArduinoJson version 6
86 | std::shared_ptr<StaticJsonBuffer<FIREBASE_JSONBUFFER_SIZE>> buffer_;
I have ArduinoJson 6 so the code needs updating
I installed Arduinojson 5 and then got the sames errors as reported in post #1
thank you for trying. I'm still having the same errors.
could be wrong
thats really the url, I had a typo on naming it. so I just leave it as it is if that's what you meant. thank you for the response.
