Please provide the Ethernet libraries for Arduino Ethernet Shield 2 with Wiznet w5500
Why do you think a different library is needed?
Previously i used to work with arduino ethernet with wiznet w5100,now i got new board i.e,Arduino ethernet Shield 2 that has Wiznet w 5500,if i use the old libraries wat i used on w5100,w5500 does not ping
kindly provide me the ethernet libraries that works with both w5100 and w 5500 chips
Download and import this library.
Change the include in your sketch to this:
#include <EthernetV2_0.h>
I have not checked this library personally, but another user reported this worked with the w5500.
Sorry sir,it hasn't worked in my case,Actually i got two Ethernet libraries,one works fine with w5100,and the other works fine with w5500,but i want a single library that should work in both cases
Follow the instructions for the hardware, the make and model. I don't think 'arduino' officially release a w5500 shield.
A little googling
roshancheluva:
What you want and what is available is the challenge. You can change the w5200 library by commenting out the #define W5200, but it is easier to use separate libraries.
// If you want to use the w5100
#include <Ethernet.h>
// If you want to use the w5200/w5500
I got the same problem as you had too, with my Ethernet Shield 2. After downloading the new Library, the serial Monitor said that my Server adress is 0.0.0.0 . What should I do? ![]()
