Hi all,
We tried to produce 1 kHz in loop for a process. We use Arduino Giga and using Arduino_AdvancedAnalog.h for DAC. But some problems, that we dont undestand, blocks DAC 1 kHz generation and while we measure it on multimeter, we get different frequency values. Sample code like this :
(Original sample : [https://docs.arduino.cc/tutorials/giga-r1-wifi/giga-audio#waveform-generation-with-the-giga-r1-dacs](https://ARDUINO GIGA DAC Sample))
// This example outputs an 8KHz square wave on A12/DAC0.
#include <Arduino_AdvancedAnalog.h>
AdvancedDAC dac1(A12);
while (!Serial) {
if (!dac1.begin(AN_RESOLUTION_12, 2000, 32, 64)) {
Serial.println("Failed to start DAC1 !");
while (1);
void dac_output_sq(AdvancedDAC &dac_out) {
if (dac_out.available()) {
// Get a free buffer for writing.
SampleBuffer buf = dac_out.dequeue();
// Write data to buffer.
for (int i=0; i<buf.size(); i++) {
buf.data()[i] = (i % 2 == 0) ? 0: 0xfff;
// Write the buffer to DAC.
dac_out.write(buf);
dac_output_sq(dac1);
//The following part causes corruption for creating and measuring 1 kHz frequency
int i = 0;
for(i=0; i<10000; i++)
Serial.println(i);
The original example and the above example that was written by us, can work perfectly as we just write dac_output_sq(dac1); in loop function. But while we add other parts of our code, the frequency value, that we want as 1 kHz, is started to be freak values in multimeters.
How can we solve this problem ? Do you have any algorithm or code advices ? Or we use something in wrong places ?
Thanks a lot for your helps
