Hello,
I'm trying to create an audio pass thru with the GIGA R, using the following code. It works intermittently. I can hear the audio, but there's also a lot of TV snow like noise. Is the GIGA R1 not suited for this type of application? Also, what values should I use for bits per channel and queue depth? Code follows, any help would be appreciated, thanks!
attempting to use GIGI R1 as an audio pass thru device
based on pass thru code in the arduino advanced audio library
pin setup
Audio In (from DAW)
- from audio interface 1 - via 3.5mm stero jack to 3.5mm audio breakout board
- tip to pin A0
- rind to pin A1
- GND to GND
Audio Out
- to audio interface 2 - via 3.5mm stereo jack to 3.5mm audio breakout board
- tip to pin DAC0
- ring to pin DAC1
- GND to GND
// libs
#include <Arduino_AdvancedAnalog.h>
// vars
AdvancedADC adcL(A0); // create an adc for left channel - Pin A0
//AdvancedADC adcR(A1); // create an adc for the right channel - pin A1
AdvancedDAC dacL(A12); // create a dac for the left channel - pin dac0 aka pin 12
//AdvancedDAC dacR(A13); // create a dac for the left channel - pin dac1 aka pin 13
int SampleRate = 26040;
int NumOfSamplesPerChannel = 32;
int QueueDepth = 64;
/* notes
what is the correct # samples per channel and queue depth?
// setup
// initiliaize the ADC's and DAC's
// Resolution, sample rate, number of samples per channel, queue depth.
if (!adcL.begin(AN_RESOLUTION_12, SampleRate, NumOfSamplesPerChannel, QueueDepth)) { // goal 12bit bit depth, 26040hz sample rate
Serial.println("Failed to start adc left!");
while (1);
if (!adcR.begin(AN_RESOLUTION_12, SampleRate, NumOfSamplesPerChannel, QueueDepth)) {
Serial.println("Failed to start adc right!");
while (1);
if (!dacL.begin(AN_RESOLUTION_12, SampleRate)) {
Serial.println("Failed to start dac left!");
while (1);
if (!dacR.begin(AN_RESOLUTION_12, 26040)) {
Serial.println("Failed to start dac right!");
while (1);
// loop
if (adcL.available()) { // if adc available
dacL.write(adcL.read()); // dac read the adc
//if (adcR.available()) { // if adc available
//dacR.write(adcR.read()); // dac read the adc
