I use IDE 1.8.19 under Win7, recently I was working with STM32.
Yesterday my IDE begin reporting: no COM port available, com port selection is "gray".
System have 3 COM ports: hardware and 2 adapters: CH340, CP2102, all works with other software only IDE can not see/detect them.
when I delete config files (preferences) and IDE create new clean one, all works.
any modification of my preferences file in section related to COM ports does not make any changes.
I plug Arduino Uno and add manually COM port to preferences, I can load the code to Uno but port is still not available/gray.
IDE report can not communicate with device null.
Any solution for it?
Regards
Hi @viayner . There was a bug in versions 2.8.0 and 2.8.1 of the "STM32 MCU based boards " platform (AKA "STM32duino") that caused this problem:
Great work on identifying the culprit!
It is the other way around. The board definition contains a port property association for the vid property, but not for a pid property, as is typically done:
This was actually a reasonable thing to do in this case where the board definition provides support for all models of the Blues boards (rather than one specific model as is typically the case), and where Blues owns the 0x30A4 USB vendor ID.
Unfortunately it seems that the Arduino IDE 1.x codeba…
The bug in the platform has since been fixed:
stm32duino:main ← per1234:ide-2-blues-port-property
opened 06:09PM - 14 Sep 24 UTC
### Summary
The Arduino boards platform framework allows properties of a port… to be [associated with a board definition](https://arduino.github.io/arduino-cli/dev/platform-specification/#properties-from-pluggable-discovery:~:text=upload_port.vid%20and%20upload_port.pid%20properties). The Arduino development software will identify a port having the associated properties as that board.
The "Blues boards" board definition contains an association for the `vid` port property value of `0x30A4`:
https://github.com/stm32duino/Arduino_Core_STM32/blob/89a29516cca7b50c6aef17a52e0e6e4afe78aeb7/boards.txt#L12466
Typically, in addition to the `vid` property, a companion `pid` property will also be associated so that the association is specific to devices with that VID/PID pair. However, this board definition only associates a `vid` property. Although unusual, this is reasonable in this case where the board definition provides support for all models of the **Blues** boards (rather than one specific model as is typically the case).
Unfortunately it seems that the Arduino IDE 1.x codebase is written in a way that assumes a PID association will always be provided along with a VID association. When a platform is installed that contains a board definition that associates a `vid` property without also associating a `pid` property, it breaks port discovery entirely, causing no ports to be discovered for any board.
The port discovery and port properties association system has been completely reworked since the time of Arduino IDE 1.x. The modern system, which is used by Arduino IDE 2.x and Arduino CLI, doesn't have any problem with this VID-only association. This means that it would be possible to define this association without breaking Arduino IDE 1.x if the association could be applied exclusively for the modern Arduino development software versions. Arduino IDE 1.x only uses the port property association for the convenience feature of labeling the port in the **Tools > Port** menu, so the lack of an association doesn't cause any meaningful impact.
At the time the port discovery and port properties association system was reworked, the port property association properties were renamed to support association with any arbitrary properties:
https://arduino.github.io/arduino-cli/latest/pluggable-discovery-specification/#board-identification
(while retaining support for [the old property names](https://arduino.github.io/arduino-cli/latest/platform-specification/#board-vidpid)). The new property names are only recognized by the modern Arduino development software and have no effect on Arduino IDE 1.x.
The port association properties for the "Blues boards" board definition are migrated from the old property names previously in use to the new names. This causes the port property association to no longer be recognized by Arduino IDE 1.x, fixing the breakage of its port discovery system. The association will still be recognized by the modern versions of Arduino development software just as before.
This PR fixes/implements the following **bugs/features**
* [x] https://github.com/stm32duino/Arduino_Core_STM32/issues/2469
### Validation
1. Install the version of the platform without this patch.
1. Start Arduino IDE 1.8.19
1. Connect any device to your computer that produces a serial port.
1. Open the **Tools** menu in Arduino IDE.
🐛 The **Port** menu item is grayed out, indicating no ports were discovered even though a port is present.
1. Select **File > Quit** (or **Arduino > Quit Arduino** for macOS users) from the Arduino IDE menus.
1. Apply the patch proposed here.
1. Select **Tools > Port** from the Arduino IDE menus.
🙂 All serial ports are listed in the menu.
1. Start Arduino IDE 2.3.2
1. Connect a device that produces a port with VID of `0x30A4` to your computer.
🙂 The port of the device with VID of `0x30A4` is labeled "**(Blues boards)**
### Additional context
Even though, from a technical standpoint, this change restores the platform's support for Arduino IDE 1.x, my impression is that maintainability was also a factor in the decision to drop 1.x support (which is quite understandable). For this reason, [the "only Arduino IDE 2 is supported" statement](https://github.com/stm32duino/Arduino_Core_STM32/blob/89a29516cca7b50c6aef17a52e0e6e4afe78aeb7/README.md?plain=1#L41-L42) was not removed from the readme.
### Closing issues
- Fixes https://github.com/stm32duino/Arduino_Core_STM32/issues/2469
- Fixes https://github.com/stm32duino/Arduino_Core_STM32/issues/2511
So you can solve the issue in Arduino IDE it by using the Arduino IDE Boards Manager to update that platform to the latest version (2.9.0).
Unfortunately some additional incompatibilities with Arduino IDE 1.x have been introduced into the platform (the developers now only officially support its use with Arduino IDE 2.x). There are instructions here for fixing the other incompatibilities with Arduino IDE 1.x:
That is unfortunate. I definitely advocate for using the modern Arduino IDE 2.x. However, in case you (or anyone else who encounters the same problem and finds this topic through their research) can't or won't update their IDE, I'll provide instructions you can follow to fix the incompatibility between the "STM32 MCU based boards" platform and Arduino IDE 1.x
Start Arduino IDE.
Select File > New from the Arduino IDE menus.
Select File > Preferences... (or Arduino > Settings... for macOS users…
The alternative solution would be to use Boards Manager to downgrade the platform to version 2.7.1, which the last version that has out of the box compatibility with Arduino IDE 1.x.
great, Thank you, that was the problem, downgrade to 2.7.1 bring me back COM ports.
Now I notice that recently (day before) there was some upgrade installed, I use previously 2.7.1 for long time.
By the way, I have some project with STM32F030xx and always I got a compilation error, is there any known issue of that? I mean some library incompatibility?
With F407 and F411 I did not notice any problems.
Regards
You are welcome. I'm glad it is working now!
Since it is unrelated to the original subject of this topic, please open a new forum topic for that question. This will ensure it gets the attention of the forum helpers knowledgeable about the subject of your new question.
