Here is the copy and paste from powershell:
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.0.3
Starting backend process. PID: 13084
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/frase/.theia'
Configuring to accept webviews on '^.+.webview..+$' hostname.
2022-12-28T22:06:02.902Z root INFO Backend Object.initialize: 4.7 ms [Finished 1.619 s after backend start]
2022-12-28T22:06:02.903Z root INFO Backend Object.configure: 3.7 ms [Finished 1.620 s after backend start]
2022-12-28T22:06:02.903Z root INFO Backend MessagingContribution.onStart: 1.5 ms [Finished 1.620 s after backend start]
2022-12-28T22:06:02.904Z root INFO Backend OSBackendApplicationContribution.configure: 0.4 ms [Finished 1.662 s after backend start]
2022-12-28T22:06:02.905Z root INFO Backend DefaultWorkspaceServer.onStart: 0.4 ms [Finished 1.662 s after backend start]
2022-12-28T22:06:02.906Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.1 ms [Finished 1.662 s after backend start]
2022-12-28T22:06:02.907Z root INFO Backend PluginLocalizationBackendContribution.initialize: 42.1 ms [Finished 1.662 s after backend start]
2022-12-28T22:06:02.907Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.2 ms [Finished 1.662 s after backend start]
2022-12-28T22:06:02.908Z root INFO Backend ElectronTokenBackendContribution.configure: 1.3 ms [Finished 1.664 s after backend start]
2022-12-28T22:06:02.909Z root INFO Backend PluginDeployerContribution.initialize: 0.5 ms [Finished 1.664 s after backend start]
2022-12-28T22:06:02.909Z root INFO Backend ConfigServiceImpl.onStart: 1.0 ms [Finished 1.665 s after backend start]
2022-12-28T22:06:02.911Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.4 ms [Finished 1.666 s after backend start]
2022-12-28T22:06:02.911Z root INFO Backend ArduinoDaemonImpl.onStart: 1.2 ms [Finished 1.667 s after backend start]
2022-12-28T22:06:02.911Z root INFO Backend NodeFileUploadService.configure: 2.4 ms [Finished 1.667 s after backend start]
2022-12-28T22:06:02.911Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2022-12-28T22:06:02.912Z discovery-log INFO start
2022-12-28T22:06:02.912Z discovery-log INFO start new deferred
2022-12-28T22:06:02.912Z root INFO Backend HostedPluginLocalizationService.initialize: 0.5 ms [Finished 1.668 s after backend start]
2022-12-28T22:06:02.912Z root INFO Backend BoardDiscovery.onStart: 1.0 ms [Finished 1.669 s after backend start]
2022-12-28T22:06:02.912Z root INFO Backend FileDownloadEndpoint.configure: 0.9 ms [Finished 1.669 s after backend start]
2022-12-28T22:06:02.913Z root INFO Backend AuthenticationServiceImpl.onStart: 0.4 ms [Finished 1.671 s after backend start]
2022-12-28T22:06:02.913Z root INFO Backend PluginApiContribution.configure: 0.7 ms [Finished 1.671 s after backend start]
2022-12-28T22:06:02.914Z root INFO Backend HostedPluginReader.configure: 0.6 ms [Finished 1.672 s after backend start]
2022-12-28T22:06:02.914Z root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 1.673 s after backend start]
2022-12-28T22:06:02.915Z root INFO Backend PlotterBackendContribution.configure: 1.1 ms [Finished 1.674 s after backend start]
2022-12-28T22:06:02.918Z root INFO Theia app listening on http://localhost:57421.
2022-12-28T22:06:02.919Z root INFO Finished starting backend application: 6.3 ms [Finished 1.678 s after backend start]
2022-12-28T22:06:02.920Z root WARN The local plugin referenced by local-dir:/c%3A/Users/frase/.arduinoIDE/plugins does not exist.
2022-12-28T22:06:02.920Z root WARN The local plugin referenced by local-dir:/c%3A/Users/frase/.arduinoIDE/extensions does not exist.
2022-12-28T22:06:02.923Z root WARN The local plugin referenced by local-dir:C:\Users\frase.arduinoProIDE\plugins does not exist.
2022-12-28T22:06:02.949Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.950Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2022-12-28T22:06:02.951Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.952Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.5" with engines:
2022-12-28T22:06:02.952Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.953Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2022-12-28T22:06:02.954Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.956Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2022-12-28T22:06:02.957Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.958Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2022-12-28T22:06:02.959Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.959Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2022-12-28T22:06:02.960Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.960Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2022-12-28T22:06:02.961Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.961Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2022-12-28T22:06:02.962Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.962Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2022-12-28T22:06:02.963Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.963Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2022-12-28T22:06:02.964Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.965Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2022-12-28T22:06:02.966Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.966Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2022-12-28T22:06:02.967Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.967Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2022-12-28T22:06:02.968Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.968Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2022-12-28T22:06:02.969Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.969Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2022-12-28T22:06:02.970Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.971Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2022-12-28T22:06:02.971Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.972Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2022-12-28T22:06:02.973Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.977Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2022-12-28T22:06:02.979Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.980Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2022-12-28T22:06:02.980Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.980Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2022-12-28T22:06:02.990Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2022-12-28T22:06:02.991Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2022-12-28T22:06:03.054Z root INFO Resolve plugins list: 144.4 ms [Finished 1.814 s after backend start]
2022-12-28T22:06:03.061Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 6.0 ms [Finished 1.820 s after backend start]
2022-12-28T22:06:03.064Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.5" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 3.5 ms [Finished 1.824 s after backend start]
2022-12-28T22:06:03.074Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 9.9 ms [Finished 1.834 s after backend start]
2022-12-28T22:06:03.077Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 2.4 ms [Finished 1.836 s after backend start]
2022-12-28T22:06:03.078Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 1.3 ms [Finished 1.838 s after backend start]
2022-12-28T22:06:03.186Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 108.3 ms [Finished 1.946 s after backend start]
2022-12-28T22:06:03.209Z daemon INFO INFO[0000] Using config file: c:\Users\frase.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.29.0
INFO[0000] Executing arduino-cli daemon
{"IP":"127.0.0.1","Port":"57422"}
2022-12-28T22:06:03.214Z daemon INFO Daemon is running.
2022-12-28T22:06:03.321Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 134.8 ms [Finished 2.081 s after backend start]
2022-12-28T22:06:03.360Z daemon INFO INFO[0000] Loading hardware from: C:\Users\frase\AppData\Local\Arduino15\packages
INFO[0000] Loading package arduino from: C:\Users\frase\AppData\Local\Arduino15\packages\arduino\hardware
2022-12-28T22:06:03.504Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 182.8 ms [Finished 2.264 s after backend start]
2022-12-28T22:06:03.505Z daemon INFO INFO[0000] Checking signature error="opening signature file: open C:\Users\frase\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\installed.json.sig: The system cannot find the file specified." index="C:\Users\frase\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\installed.json" signatureFile="C:\Users\frase\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\installed.json.sig"
INFO[0000] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0000] Loaded platform platform="arduino:avr@1.8.6"
INFO[0000] Checking existence of 'tools' path: C:\Users\frase\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loading tools from dir: C:\Users\frase\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loaded tool tool="arduino:arduinoOTA@1.3.0"
INFO[0000] Loaded tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0000] Loaded tool tool="arduino:avrdude@6.3.0-arduino17"
INFO[0000] Loading package builtin from: C:\Users\frase\AppData\Local\Arduino15\packages\builtin
INFO[0000] Checking existence of 'tools' path: C:\Users\frase\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loading tools from dir: C:\Users\frase\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loaded tool tool="builtin:ctags@5.8-arduino11"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.6"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.3.2"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.11.0"
INFO[0000] Loading hardware from: C:\Users\frase\OneDrive\Documents\Arduino\hardware
INFO[0000] Loading package anet from: C:\Users\frase\OneDrive\Documents\Arduino\hardware\anet
INFO[0000] Loaded platform platform="anet:avr@1.5.6"
INFO[0000] Checking signature index="C:\Users\frase\AppData\Local\Arduino15\package_index.json" signatureFile="C:\Users\frase\AppData\Local\Arduino15\package_index.json.sig" trusted=true
INFO[0000] Adding libraries dir dir="C:\Users\frase\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries" location=platform
INFO[0000] Loading libraries index file index="C:\Users\frase\AppData\Local\Arduino15\library_index.json"
2022-12-28T22:06:03.589Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 85.0 ms [Finished 2.349 s after backend start]
2022-12-28T22:06:03.657Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 67.7 ms [Finished 2.417 s after backend start]
2022-12-28T22:06:03.658Z daemon INFO INFO[0000] Adding libraries dir dir="C:\Users\frase\AppData\Local\Arduino15\libraries" location=ide
INFO[0000] Adding libraries dir dir="C:\Users\frase\OneDrive\Documents\Arduino\libraries" location=user
2022-12-28T22:06:03.706Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 48.8 ms [Finished 2.466 s after backend start]
2022-12-28T22:06:03.771Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 65.2 ms [Finished 2.531 s after backend start]
2022-12-28T22:06:03.833Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 61.9 ms [Finished 2.593 s after backend start]
2022-12-28T22:06:03.891Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 58.1 ms [Finished 2.651 s after backend start]
2022-12-28T22:06:03.894Z discovery-log INFO start request start watch
2022-12-28T22:06:03.894Z discovery-log INFO start requested start watch
2022-12-28T22:06:03.895Z discovery-log INFO start resolved watching
2022-12-28T22:06:03.896Z daemon INFO INFO[0000] starting discovery builtin:mdns-discovery process
INFO[0000] starting discovery builtin:serial-discovery process
2022-12-28T22:06:03.926Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 34.9 ms [Finished 2.686 s after backend start]
2022-12-28T22:06:03.927Z daemon INFO INFO[0000] started discovery builtin:mdns-discovery process
INFO[0000] sending command HELLO 1 "arduino-cli 0.29.0" to discovery builtin:mdns-discovery
INFO[0000] started discovery builtin:serial-discovery process
INFO[0000] sending command HELLO 1 "arduino-cli 0.29.0" to discovery builtin:serial-discovery
2022-12-28T22:06:03.990Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 63.9 ms [Finished 2.750 s after backend start]
2022-12-28T22:06:03.993Z daemon INFO INFO[0000] from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1
INFO[0000] sending command START_SYNC to discovery builtin:serial-discovery
INFO[0000] from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
INFO[0000] sending command START_SYNC to discovery builtin:mdns-discovery
INFO[0000] from discovery builtin:serial-discovery received message type: start_sync, message: OK
INFO[0000] from discovery builtin:mdns-discovery received message type: start_sync, message: OK
2022-12-28T22:06:04.063Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 73.0 ms [Finished 2.823 s after backend start]
2022-12-28T22:06:04.133Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 69.4 ms [Finished 2.892 s after backend start]
2022-12-28T22:06:04.191Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 57.9 ms [Finished 2.950 s after backend start]
2022-12-28T22:06:04.231Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 40.1 ms [Finished 2.991 s after backend start]
2022-12-28T22:06:04.292Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 61.1 ms [Finished 3.052 s after backend start]
2022-12-28T22:06:04.292Z root INFO Deploy plugins list: 144.4 ms [Finished 3.052 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2022-12-28T22:06:05.083Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 199.3 ms [Finished 2.034 s after frontend start]
2022-12-28T22:06:05.327Z root INFO Start frontend contributions: 540.0 ms [Finished 2.291 s after frontend start]
2022-12-28T22:06:05.352Z root INFO Changed application state from 'init' to 'started_contributions'.
2022-12-28T22:06:05.398Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2022-12-28T22:06:05.408Z root INFO >>> Restoring the layout state...
2022-12-28T22:06:05.409Z root INFO ------- SERIALIZED LAYOUT DATA -------
2022-12-28T22:06:05.413Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/Marlin.ino"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":54,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/Conditionals.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":28,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/Conditionals_LCD.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":563,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/Conditionals_post.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":1424,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/Configuration.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":177,"column":7},"position":{"lineNumber":177,"column":7}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":172,"column":1},"firstPositionDeltaTop":-1},"contributionsState":{"editor.contrib.folding":{"lineCount":1932,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":true}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/Configuration_adv.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":1714,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/G26_Mesh_Validation_Tool.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":921,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/HAL.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":338,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/I2CPositionEncoder.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":1141,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/I2CPositionEncoder.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":343,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/M100_Free_Mem_Chk.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":333,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/Marlin.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":648,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/MarlinConfig.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":49,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/MarlinSPI.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":58,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/MarlinSerial.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":741,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/MarlinSerial.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":185,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/Marlin_main.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":15559,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/Max7219_Debug_LEDs.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":594,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/Max7219_Debug_LEDs.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":155,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/SanityCheck.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":1706,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/Sd2Card.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":717,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/Sd2Card.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":205,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/SdBaseFile.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":1729,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/SdBaseFile.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":391,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/SdFatConfig.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":117,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/SdFatStructs.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":616,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/SdFatUtil.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":92,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/SdFatUtil.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":52,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/SdFile.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":101,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/SdFile.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":61,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/SdInfo.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":268,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/SdVolume.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":385,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/SdVolume.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":212,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/Version.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":95,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/bitmap_flags.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":39,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/blinkm.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":47,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/blinkm.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":36,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/boards.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":163,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/buzzer.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":147,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/cardreader.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":988,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/cardreader.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":231,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/circularqueue.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":146,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/configuration_store.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":2826,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/configuration_store.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":102,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/dac_mcp4728.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":154,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/dac_mcp4728.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":67,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/delay.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":78,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/digipot_mcp4018.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":107,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/digipot_mcp4451.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":80,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/dogm_bitmaps.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":1193,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/dogm_font_data_6x9_marlin.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":181,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/dogm_font_data_HD44780_C.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":195,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/dogm_font_data_HD44780_J.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":193,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/dogm_font_data_HD44780_W.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":227,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/dogm_font_data_ISO10646_1.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":287,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/dogm_font_data_ISO10646_1_PL.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":185,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/dogm_font_data_ISO10646_1_tr.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":198,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/dogm_font_data_ISO10646_5_Cyrillic.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":197,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/dogm_font_data_ISO10646_CN.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":294,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/dogm_font_data_ISO10646_CZ.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":193,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/dogm_font_data_ISO10646_Greek.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":206,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/dogm_font_data_ISO10646_Kana.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":193,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/dogm_font_data_ISO10646_SK.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":152,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/dogm_font_data_ISO10646_ko_KR.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":305,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/dogm_font_data_Marlin_symbols.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":46,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/drivers.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":74,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/duration_t.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":171,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/emergency_parser.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":41,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/emergency_parser.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":145,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/endstop_interrupts.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":240,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/endstops.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":783,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/endstops.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":175,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/enum.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":176,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/fastio.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":320,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/fastio_1280.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":1116,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/fastio_1281.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":720,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/fastio_168.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":362,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/fastio_644.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":557,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/fastio_AT90USB.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":702,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/fwretract.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":200,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/fwretract.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":72,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/hex_print_routines.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":58,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/hex_print_routines.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":45,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":338,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_an.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":260,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_bg.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":151,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_ca.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":266,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_cn.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":172,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_cz.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":421,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_cz_utf8.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":424,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_da.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":255,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_de.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":412,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_el-gr.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":192,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_el.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":193,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_en.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":1103,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_es.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":281,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_es_utf8.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":276,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_eu.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":389,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_fi.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":174,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_fr.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":396,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_fr_utf8.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":396,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_gl.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":256,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_hr.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":254,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_it.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":402,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_kana.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":341,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_kana_utf8.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":226,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_ko_KR.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":295,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_nl.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":284,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_pl-DOGM.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":254,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_pl-HD44780.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":277,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_pl.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":46,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_pl_utf8.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":1106,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_pt-br.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":383,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_pt-br_utf8.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":385,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_pt.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":189,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_pt_utf8.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":191,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_ru.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":403,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_sk_utf8.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":411,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_test.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":236,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_tr.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":274,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_uk.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":245,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_zh_CN.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":389,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/language_zh_TW.h"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":{"lineCount":389,"provider":"indent","foldedImports":false},"editor.contrib.wordHighlighter":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///d%3A/3D%20Printing/Marlin%20DO%20NOT%20DELETE/Marlin-1.1.9.1/Marlin-1.1.9.1/Marlin/least_squares_fit.cpp"}},"innerWidgetState":"{"cursorState":[{"inSelectionMode":false,"selectionStart":{"lineNumber":1,"column":1},"position":{"lineNumber":1,"column":1}}],"viewState":{"scrollLeft":0,"firstPosition":{"lineNumber":1,"column":1},"firstPositionDeltaTop":0},"contributionsState":{"editor.contrib.folding":
