Arduino IDE 2.3.1 crashes ESP8266
after upgrading to IDE 2.3.1, the ESP8266 code (NodeMCU 1.0) crashes. In previous version (IDE 2.2.1) it run perfectly. Any ideas? How can I roll back to previous IDE?
Welcome to the forum
What happens when the code crashes ?
What messages are printed, if any ?
Thank you!
The code start its task connects to WiFi, then:
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Exception (3):
epc1=0x40206917 epc2=0x00000000 epc3=0x00000000 excvaddr=0x4025c402 depc=0x00000000
stack>>>
ctx: cont
sp: 3ffffe40 end: 3fffffd0 offset: 0150
3fffff90: 4025d0a1 00000000 0000000c 40100684
3fffffa0: 3fffdad0 00000000 3fff13c4 3fff13f0
3fffffb0: 3fffdad0 00000000 3fff13c4 4021db48
3fffffc0: feefeffe feefeffe 3fffdab0 401011d5
<<<stack<<<
and resets the ESP8266. The same code works fine when compiled on IDE 2.2.1
Did you do a fresh install of the IDE when updating? Or did you update from within the IDE when it offered you to update?
Did you update (or had to re-install) any board packages or libraries?
  1. I did an upgrade when offered
  2. I checked and the board packages where present. I did not reinstall any
  3. The upgrade changed some of the parameters, like MMU configuration. I reset those before compiling
PS
I know that the code works on IDE 2.2.1 as I upgraded my desktop and not yet (luckyly) my laptop
Hi @Sachig. I'm going to ask you to provide the compilation output you get from compiling the same troubled sketch code using the non-working Arduino IDE 2.3.1 installation and the working Arduino IDE 2.2.1 installation.
:red_exclamation_mark: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
A. Get output from Arduino IDE 2.3.1
  1. Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
    The "Preferences" dialog will open.
  2. Check the box next to "Show verbose output during: ☐ compilation" in the "Preferences" dialog.
  3. Click the "OK" button.
  4. Select Sketch > Verify/Compile from the Arduino IDE menus.
  5. Wait for the compilation to fail.
  6. You will see a "Compilation error: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button on that notification.
  7. Open a forum reply here by clicking the "Reply" button.
  8. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
  9. Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
    This will paste the compilation output into the code block.
  10. Move the cursor outside of the code block markup before you add any additional text to your reply.
  11. Click the "Reply" button to post the output.
B. Get output from Arduino IDE 2.2.1
  5. Wait for the compilation to finish.
  6. Right click on the black "Output" panel at the bottom of the Arduino IDE window.
  7. From the context menu, click Copy All.
  8. Open a forum reply here by clicking the "Reply" button.
  9. Click the <CODE/> icon on the post composer toolbar.
  10. Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
  11. Move the cursor outside of the code block markup before you add any additional text to your reply.
  12. Click the "Reply" button to post the output.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here:
  1. Open any text editor program.
  2. Paste the copied output into the text editor.
  3. Save the file in .txt format.
  4. Open a forum reply here by clicking the "Reply" button.
  5. Click the "Upload" icon (image) on the post composer toolbar:
    The "Open" dialog will open.
  6. Select the .txt file you saved from the "Open" dialog.
  7. Click the "Open" button.
    The dialog will close.
  8. Click the "Reply" button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
There is no error on the compilation and the code is uploaded to the ESP8266. It crashes when it runs
FQBN: esp8266:esp8266:nodemcuv2:mmu=3216
Using board 'nodemcuv2' from platform in folder: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2
Using core 'esp8266' from platform in folder: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/mkbuildoptglobals.py" "C:\\Program Files\\Arduino IDE\\resources\\app\\lib\\backend\\resources" 10607 "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097/core/build.opt" "C:\\Users\\user\\OneDrive\\One-Documents\\4-Arduino\\3 - Shades\\Smart_Pinnes_Home_V9/Smart_Pinnes_Home_V9.ino.globals.h" "C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266/CommonHFile.h"
default_encoding:       cp1255
Assume aggressive 'core.a' caching enabled.
Note: optional global include file 'C:\Users\user\OneDrive\One-Documents\4-Arduino\3 - Shades\Smart_Pinnes_Home_V9\Smart_Pinnes_Home_V9.ino.globals.h' does not exist.
  Read more at https://arduino-esp8266.readthedocs.io/en/latest/faq/a06-global-build-options.html
Detecting libraries used...
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core/build.opt -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core -c @C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DARDUINO_BOARD_ID="nodemcuv2" -DLED_BUILTIN=2 -DFLASHMODE_DIO -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\nodemcu C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\sketch\Smart_Pinnes_Home_V9.ino.cpp -o nul
Alternatives for ESP8266WiFi.h: [ESP8266WiFi@1.0]
ResolveLibrary(ESP8266WiFi.h)
  -> candidates: [ESP8266WiFi@1.0]
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core/build.opt -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core -c @C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DARDUINO_BOARD_ID="nodemcuv2" -DLED_BUILTIN=2 -DFLASHMODE_DIO -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\nodemcu -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\sketch\Smart_Pinnes_Home_V9.ino.cpp -o nul
Alternatives for ESPAsyncTCP.h: [ESP AsyncTCP@1.2.2]
ResolveLibrary(ESPAsyncTCP.h)
  -> candidates: [ESP AsyncTCP@1.2.2]
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core/build.opt -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core -c @C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DARDUINO_BOARD_ID="nodemcuv2" -DLED_BUILTIN=2 -DFLASHMODE_DIO -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\nodemcu -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESPAsyncTCP-master\src C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\sketch\Smart_Pinnes_Home_V9.ino.cpp -o nul
Alternatives for ESPAsyncWebServer.h: [ESP Async WebServer@2.7.0]
ResolveLibrary(ESPAsyncWebServer.h)
  -> candidates: [ESP Async WebServer@2.7.0]
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core/build.opt -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core -c @C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DARDUINO_BOARD_ID="nodemcuv2" -DLED_BUILTIN=2 -DFLASHMODE_DIO -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\nodemcu -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESPAsyncTCP-master\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESP_Async_WebServer\src C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\sketch\Smart_Pinnes_Home_V9.ino.cpp -o nul
Alternatives for Hash.h: [Hash@1.0]
ResolveLibrary(Hash.h)
  -> candidates: [Hash@1.0]
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core/build.opt -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core -c @C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DARDUINO_BOARD_ID="nodemcuv2" -DLED_BUILTIN=2 -DFLASHMODE_DIO -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\nodemcu -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESPAsyncTCP-master\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESP_Async_WebServer\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Hash\src C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\sketch\Smart_Pinnes_Home_V9.ino.cpp -o nul
Alternatives for ElegantOTA.h: [ElegantOTA@3.1.0]
ResolveLibrary(ElegantOTA.h)
  -> candidates: [ElegantOTA@3.1.0]
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core/build.opt -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core -c @C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DARDUINO_BOARD_ID="nodemcuv2" -DLED_BUILTIN=2 -DFLASHMODE_DIO -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\nodemcu -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESPAsyncTCP-master\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESP_Async_WebServer\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Hash\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ElegantOTA\src C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\sketch\Smart_Pinnes_Home_V9.ino.cpp -o nul
Alternatives for LittleFS.h: [LittleFS@0.1.0]
ResolveLibrary(LittleFS.h)
  -> candidates: [LittleFS@0.1.0]
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core/build.opt -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core -c @C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DARDUINO_BOARD_ID="nodemcuv2" -DLED_BUILTIN=2 -DFLASHMODE_DIO -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\nodemcu -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESPAsyncTCP-master\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESP_Async_WebServer\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Hash\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ElegantOTA\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\LittleFS\src C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\sketch\Smart_Pinnes_Home_V9.ino.cpp -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core/build.opt -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core -c @C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DARDUINO_BOARD_ID="nodemcuv2" -DLED_BUILTIN=2 -DFLASHMODE_DIO -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\nodemcu -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESPAsyncTCP-master\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESP_Async_WebServer\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Hash\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ElegantOTA\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\LittleFS\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\sketch\Smart_Pinnes_Home_V9.ino.cpp -o nul
Alternatives for EEPROM.h: [EEPROM@1.0]
ResolveLibrary(EEPROM.h)
  -> candidates: [EEPROM@1.0]
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core/build.opt -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core -c @C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DARDUINO_BOARD_ID="nodemcuv2" -DLED_BUILTIN=2 -DFLASHMODE_DIO -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\nodemcu -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESPAsyncTCP-master\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESP_Async_WebServer\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Hash\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ElegantOTA\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\LittleFS\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\EEPROM C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\sketch\Smart_Pinnes_Home_V9.ino.cpp -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core/build.opt -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core -c @C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DARDUINO_BOARD_ID="nodemcuv2" -DLED_BUILTIN=2 -DFLASHMODE_DIO -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\nodemcu -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESPAsyncTCP-master\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESP_Async_WebServer\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Hash\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ElegantOTA\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\LittleFS\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\EEPROM -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\sketch\Smart_Pinnes_Home_V9.ino.cpp -o nul
Alternatives for SD.h: [SD@1.2.4 SD@2.0.0]
ResolveLibrary(SD.h)
  -> candidates: [SD@1.2.4 SD@2.0.0]
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core/build.opt -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core -c @C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DARDUINO_BOARD_ID="nodemcuv2" -DLED_BUILTIN=2 -DFLASHMODE_DIO -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\nodemcu -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESPAsyncTCP-master\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESP_Async_WebServer\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Hash\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ElegantOTA\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\LittleFS\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\EEPROM -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SD\src C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\sketch\Smart_Pinnes_Home_V9.ino.cpp -o nul
Alternatives for SDFS.h: [SDFS@0.1.0]
ResolveLibrary(SDFS.h)
  -> candidates: [SDFS@0.1.0]
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core/build.opt -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core -c @C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DARDUINO_BOARD_ID="nodemcuv2" -DLED_BUILTIN=2 -DFLASHMODE_DIO -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\nodemcu -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESPAsyncTCP-master\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESP_Async_WebServer\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Hash\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ElegantOTA\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\LittleFS\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\EEPROM -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SD\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SDFS\src C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\sketch\Smart_Pinnes_Home_V9.ino.cpp -o nul
Alternatives for SdFat.h: [ESP8266SdFat@2.1.1]
ResolveLibrary(SdFat.h)
  -> candidates: [ESP8266SdFat@2.1.1]
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core/build.opt -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core -c @C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DARDUINO_BOARD_ID="nodemcuv2" -DLED_BUILTIN=2 -DFLASHMODE_DIO -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\nodemcu -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESPAsyncTCP-master\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESP_Async_WebServer\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Hash\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ElegantOTA\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\LittleFS\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\EEPROM -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SD\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SDFS\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\sketch\Smart_Pinnes_Home_V9.ino.cpp -o nul
Alternatives for EMailSender.h: [EMailSender@3.0.13]
ResolveLibrary(EMailSender.h)
  -> candidates: [EMailSender@3.0.13]
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core/build.opt -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core -c @C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DARDUINO_BOARD_ID="nodemcuv2" -DLED_BUILTIN=2 -DFLASHMODE_DIO -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\nodemcu -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESPAsyncTCP-master\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESP_Async_WebServer\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Hash\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ElegantOTA\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\LittleFS\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\EEPROM -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SD\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SDFS\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\EMailSender-master C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\sketch\Smart_Pinnes_Home_V9.ino.cpp -o nul
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src\BearSSLHelpers.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src\CertStoreBearSSL.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src\ESP8266WiFi.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src\ESP8266WiFiAP.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src\ESP8266WiFiGratuitous.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src\ESP8266WiFiSTA-WPS.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src\ESP8266WiFiSTA.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src\ESP8266WiFiScan.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src\WiFiClient.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src\WiFiClientSecureBearSSL.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src\WiFiServer.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src\WiFiServerSecureBearSSL.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src\WiFiUdp.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src\enable_wifi_at_boot_time.cpp
Using cached library dependencies for file: c:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESPAsyncTCP-master\src\AsyncPrinter.cpp
Using cached library dependencies for file: c:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESPAsyncTCP-master\src\ESPAsyncTCP.cpp
Using cached library dependencies for file: c:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESPAsyncTCP-master\src\ESPAsyncTCPbuffer.cpp
Using cached library dependencies for file: c:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESPAsyncTCP-master\src\SyncClient.cpp
Using cached library dependencies for file: c:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESPAsyncTCP-master\src\tcp_axtls.c
Using cached library dependencies for file: c:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESP_Async_WebServer\src\AsyncEventSource.cpp
Using cached library dependencies for file: c:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESP_Async_WebServer\src\AsyncWebSocket.cpp
Using cached library dependencies for file: c:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESP_Async_WebServer\src\WebAuthentication.cpp
Using cached library dependencies for file: c:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESP_Async_WebServer\src\WebHandlers.cpp
Using cached library dependencies for file: c:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESP_Async_WebServer\src\WebRequest.cpp
Using cached library dependencies for file: c:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESP_Async_WebServer\src\WebResponses.cpp
Using cached library dependencies for file: c:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESP_Async_WebServer\src\WebServer.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Hash\src\Hash.cpp
Using cached library dependencies for file: c:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ElegantOTA\src\ElegantOTA.cpp
Using cached library dependencies for file: c:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ElegantOTA\src\elop.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\LittleFS\src\LittleFS.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\LittleFS\src\lfs.c
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\LittleFS\src\lfs_util.c
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire\Wire.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\EEPROM\EEPROM.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI\SPI.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SD\src\SD.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SDFS\src\SDFS.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\ExFatLib\ExFatDbg.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\ExFatLib\ExFatFile.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\ExFatLib\ExFatFilePrint.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\ExFatLib\ExFatFileWrite.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\ExFatLib\ExFatFormatter.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\ExFatLib\ExFatName.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\ExFatLib\ExFatPartition.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\ExFatLib\ExFatVolume.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\FatLib\FatDbg.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\FatLib\FatFile.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\FatLib\FatFileLFN.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\FatLib\FatFilePrint.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\FatLib\FatFileSFN.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\FatLib\FatFormatter.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\FatLib\FatName.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\FatLib\FatPartition.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\FatLib\FatVolume.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\FreeStack.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\FsLib\FsFile.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\FsLib\FsNew.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\FsLib\FsVolume.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\MinimumSerial.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\SdCard\SdCardInfo.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\SdCard\SdSpiCard.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\SdCard\SdioTeensy.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\SpiDriver\SdSpiArtemis.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\SpiDriver\SdSpiChipSelect.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\SpiDriver\SdSpiDue.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\SpiDriver\SdSpiESP.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\SpiDriver\SdSpiParticle.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\SpiDriver\SdSpiSTM32.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\SpiDriver\SdSpiSTM32Core.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\SpiDriver\SdSpiTeensy3.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\common\FmtNumber.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\common\FsCache.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\common\FsDateTime.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\common\FsName.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\common\FsStructs.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\common\FsUtf.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\common\upcase.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\iostream\StdioStream.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\iostream\StreamBaseClass.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\iostream\istream.cpp
Using cached library dependencies for file: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src\iostream\ostream.cpp
Using cached library dependencies for file: c:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\EMailSender-master\EMailSender.cpp
WARNING: library ESP Async WebServer claims to run on esp32 architecture(s) and may be incompatible with your current board which runs on esp8266 architecture(s).
Generating function prototypes...
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 @C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core/build.opt -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/lwip2/include -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include -IC:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/core -c @C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/tools/warnings/none-cppflags -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E" -DARDUINO_BOARD_ID="nodemcuv2" -DLED_BUILTIN=2 -DFLASHMODE_DIO -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\cores\esp8266 -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\variants\nodemcu -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESPAsyncTCP-master\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESP_Async_WebServer\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Hash\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ElegantOTA\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\LittleFS\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\EEPROM -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SD\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SDFS\src -IC:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat\src -Ic:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\EMailSender-master C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\sketch\Smart_Pinnes_Home_V9.ino.cpp -o C:\Users\user\AppData\Local\Temp\4205561808\sketch_merged.cpp
C:\Users\user\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\user\AppData\Local\Temp\4205561808\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/signing.py" --mode header --publickey "C:\\Users\\user\\OneDrive\\One-Documents\\4-Arduino\\3 - Shades\\Smart_Pinnes_Home_V9/public.key" --out "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097/core/Updater_Signing.h"
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097/core/build.opt" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097/core" -c "@C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-Ic:\\Users\\user\\OneDrive\\One-Documents\\4-Arduino\\libraries\\ESPAsyncTCP-master\\src" "-Ic:\\Users\\user\\OneDrive\\One-Documents\\4-Arduino\\libraries\\ESP_Async_WebServer\\src" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Hash\\src" "-Ic:\\Users\\user\\OneDrive\\One-Documents\\4-Arduino\\libraries\\ElegantOTA\\src" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\LittleFS\\src" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\EEPROM" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SD\\src" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SDFS\\src" "-IC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266SdFat\\src" "-Ic:\\Users\\user\\OneDrive\\One-Documents\\4-Arduino\\libraries\\EMailSender-master" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\sketch\\Smart_Pinnes_Home_V9.ino.cpp" -o "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\sketch\\Smart_Pinnes_Home_V9.ino.cpp.o"
Compiling libraries...
Compiling library "ESP8266WiFi"
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266WiFi\BearSSLHelpers.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266WiFi\CertStoreBearSSL.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266WiFi\enable_wifi_at_boot_time.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266WiFi\ESP8266WiFiGratuitous.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266WiFi\WiFiServerSecureBearSSL.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266WiFi\WiFiClientSecureBearSSL.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266WiFi\ESP8266WiFiScan.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266WiFi\ESP8266WiFiSTA.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266WiFi\ESP8266WiFi.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266WiFi\WiFiClient.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266WiFi\ESP8266WiFiMulti.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266WiFi\ESP8266WiFiSTA-WPS.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266WiFi\WiFiServer.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266WiFi\ESP8266WiFiAP.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266WiFi\WiFiUdp.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266WiFi\ESP8266WiFiGeneric.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266WiFi\ESP8266WiFi.a
Compiling library "ESP AsyncTCP"
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESPAsyncTCP-master\tcp_axtls.c.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESPAsyncTCP-master\ESPAsyncTCPbuffer.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESPAsyncTCP-master\SyncClient.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESPAsyncTCP-master\AsyncPrinter.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESPAsyncTCP-master\ESPAsyncTCP.cpp.o
Compiling library "ESP Async WebServer"
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP_Async_WebServer\WebAuthentication.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP_Async_WebServer\WebRequest.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP_Async_WebServer\WebResponses.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP_Async_WebServer\AsyncEventSource.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP_Async_WebServer\WebHandlers.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP_Async_WebServer\WebServer.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP_Async_WebServer\AsyncWebSocket.cpp.o
Compiling library "Hash"
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\Hash\Hash.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\Hash\Hash.a
Compiling library "ElegantOTA"
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ElegantOTA\elop.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ElegantOTA\ElegantOTA.cpp.o
Compiling library "LittleFS"
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\LittleFS\lfs_util.c.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\LittleFS\lfs.c.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\LittleFS\LittleFS.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\LittleFS\LittleFS.a
Compiling library "Wire"
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\Wire\Wire.cpp.o
Compiling library "EEPROM"
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\EEPROM\EEPROM.cpp.o
Compiling library "SPI"
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\SPI\SPI.cpp.o
Compiling library "SD"
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\SD\SD.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\SD\SD.a
Compiling library "SDFS"
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\SDFS\SDFS.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\SDFS\SDFS.a
Compiling library "ESP8266SdFat"
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\ExFatLib\ExFatDbg.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\FatLib\FatPartition.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\FatLib\FatFileLFN.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\ExFatLib\ExFatVolume.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\FatLib\FatFilePrint.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\ExFatLib\ExFatFile.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\ExFatLib\ExFatFilePrint.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\FsLib\FsNew.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\ExFatLib\ExFatFileWrite.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\ExFatLib\ExFatPartition.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\FatLib\FatDbg.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\FatLib\FatFile.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\FatLib\FatFormatter.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\FatLib\FatFileSFN.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\SdCard\SdioTeensy.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\FatLib\FatName.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\ExFatLib\ExFatFormatter.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\ExFatLib\ExFatName.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\FreeStack.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\FatLib\FatVolume.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\MinimumSerial.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\common\FmtNumber.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\SdCard\SdCardInfo.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\FsLib\FsFile.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\SpiDriver\SdSpiArtemis.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\common\FsStructs.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\common\FsUtf.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\FsLib\FsVolume.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\common\upcase.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\SpiDriver\SdSpiChipSelect.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\SpiDriver\SdSpiDue.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\SpiDriver\SdSpiParticle.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\SdCard\SdSpiCard.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\SpiDriver\SdSpiSTM32.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\SpiDriver\SdSpiTeensy3.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\SpiDriver\SdSpiESP.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\SpiDriver\SdSpiSTM32Core.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\common\FsDateTime.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\common\FsName.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\common\FsCache.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\iostream\StdioStream.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\iostream\StreamBaseClass.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\iostream\istream.cpp.o
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\ESP8266SdFat\iostream\ostream.cpp.o
Compiling library "EMailSender"
Using previously compiled file: C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097\libraries\EMailSender-master\EMailSender.cpp.o
Compiling core...
Using precompiled core: C:\Users\user\AppData\Local\Temp\arduino\cores\ff0b283a7ffa5eaf110787066e967fa4\core.a
Linking everything together...
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/mkdir.py" -p "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097/ld_h/"
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/cp.py" "C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/ld/eagle.flash.4m2m.ld" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097/ld_h/local.eagle.flash.ld.h"
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-gcc" -CC -E -P -DVTABLES_IN_FLASH -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097/ld_h/local.eagle.flash.ld.h" -o "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097/local.eagle.flash.ld"
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-gcc" -CC -E -P -DVTABLES_IN_FLASH -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 "C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/ld/eagle.app.v6.common.ld.h" -o "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097/local.eagle.app.v6.common.ld"
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-gcc" -fno-exceptions -Wl,-Map "-Wl,C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097/Smart_Pinnes_Home_V9.ino.map" -g "@C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cflags" -Os -nostdlib -Wl,--no-check-sections -u app_entry -u _printf_float -u _scanf_float -Wl,-static "-LC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lib" "-LC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lib/NONOSDK22x_190703" "-LC:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097" "-LC:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/lib" -Tlocal.eagle.flash.ld -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,spi_flash_read -o "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097/Smart_Pinnes_Home_V9.ino.elf" -Wl,--start-group "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\sketch\\Smart_Pinnes_Home_V9.ino.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266WiFi\\ESP8266WiFi.a" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESPAsyncTCP-master\\AsyncPrinter.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESPAsyncTCP-master\\ESPAsyncTCP.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESPAsyncTCP-master\\ESPAsyncTCPbuffer.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESPAsyncTCP-master\\SyncClient.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESPAsyncTCP-master\\tcp_axtls.c.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP_Async_WebServer\\AsyncEventSource.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP_Async_WebServer\\AsyncWebSocket.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP_Async_WebServer\\WebAuthentication.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP_Async_WebServer\\WebHandlers.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP_Async_WebServer\\WebRequest.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP_Async_WebServer\\WebResponses.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP_Async_WebServer\\WebServer.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\Hash\\Hash.a" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ElegantOTA\\ElegantOTA.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ElegantOTA\\elop.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\LittleFS\\LittleFS.a" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\EEPROM\\EEPROM.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\SD\\SD.a" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\SDFS\\SDFS.a" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\ExFatLib\\ExFatDbg.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\ExFatLib\\ExFatFile.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\ExFatLib\\ExFatFilePrint.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\ExFatLib\\ExFatFileWrite.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\ExFatLib\\ExFatFormatter.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\ExFatLib\\ExFatName.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\ExFatLib\\ExFatPartition.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\ExFatLib\\ExFatVolume.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\FatLib\\FatDbg.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\FatLib\\FatFile.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\FatLib\\FatFileLFN.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\FatLib\\FatFilePrint.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\FatLib\\FatFileSFN.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\FatLib\\FatFormatter.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\FatLib\\FatName.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\FatLib\\FatPartition.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\FatLib\\FatVolume.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\FreeStack.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\FsLib\\FsFile.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\FsLib\\FsNew.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\FsLib\\FsVolume.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\MinimumSerial.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\SdCard\\SdCardInfo.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\SdCard\\SdSpiCard.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\SdCard\\SdioTeensy.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\SpiDriver\\SdSpiArtemis.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\SpiDriver\\SdSpiChipSelect.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\SpiDriver\\SdSpiDue.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\SpiDriver\\SdSpiESP.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\SpiDriver\\SdSpiParticle.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\SpiDriver\\SdSpiSTM32.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\SpiDriver\\SdSpiSTM32Core.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\SpiDriver\\SdSpiTeensy3.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\common\\FmtNumber.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\common\\FsCache.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\common\\FsDateTime.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\common\\FsName.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\common\\FsStructs.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\common\\FsUtf.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\common\\upcase.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\iostream\\StdioStream.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\iostream\\StreamBaseClass.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\iostream\\istream.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\ESP8266SdFat\\iostream\\ostream.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097\\libraries\\EMailSender-master\\EMailSender.cpp.o" "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\cores\\ff0b283a7ffa5eaf110787066e967fa4\\core.a" -lhal -lphy -lpp -lnet80211 -llwip2-536-feat -lwpa -lcrypto -lmain -lwps -lbearssl -lespnow -lsmartconfig -lairkiss -lwpa2 -lstdc++ -lm -lc -lgcc -Wl,--end-group "-LC:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097"
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/elf2bin.py" --eboot "C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/bootloaders/eboot/eboot.elf" --app "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097/Smart_Pinnes_Home_V9.ino.elf" --flash_mode dio --flash_freq 40 --flash_size 4M --path "C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin" --out "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097/Smart_Pinnes_Home_V9.ino.bin"
Creating BIN file "C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/Smart_Pinnes_Home_V9.ino.bin" using "C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2/bootloaders/eboot/eboot.elf" and "C:\Users\user\AppData\Local\Temp\arduino\sketches\1A8A66D807C31ADBD86A6E79CF20C097/Smart_Pinnes_Home_V9.ino.elf"
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/signing.py" --mode sign --privatekey "C:\\Users\\user\\OneDrive\\One-Documents\\4-Arduino\\3 - Shades\\Smart_Pinnes_Home_V9/private.key" --bin "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097/Smart_Pinnes_Home_V9.ino.bin" --out "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097/Smart_Pinnes_Home_V9.ino.bin.signed" --legacy "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097/Smart_Pinnes_Home_V9.ino.bin.legacy_sig"
"C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -X utf8 -I "C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sizes.py" --elf "C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\1A8A66D807C31ADBD86A6E79CF20C097/Smart_Pinnes_Home_V9.ino.elf" --path "C:\\Users\\user\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin" --mmu "-DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000"
. Variables and constants in RAM (global, static), used 39964 / 80192 bytes (49%)
║   SEGMENT  BYTES    DESCRIPTION
╠══ DATA     3564     initialized variables
╠══ RODATA   3856     constants
╚══ BSS      32544    zeroed variables
. Instruction RAM (IRAM_ATTR, ICACHE_RAM_ATTR), used 61675 / 65536 bytes (94%)
╠══ ICACHE   16384    reserved space for flash instruction cache
╠══ IHEAP    16384    secondary heap space
╚══ IRAM     28907    code in IRAM
. Code in flash (default, ICACHE_FLASH_ATTR), used 412224 / 1048576 bytes (39%)
╚══ IROM     412224   code in flash
Multiple libraries were found for "SD.h"
  Used: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SD
  Not used: C:\Users\user\AppData\Local\Arduino15\libraries\oldSD
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi
Using library ESP AsyncTCP at version 1.2.2 in folder: C:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESPAsyncTCP-master
Using library ESP Async WebServer at version 2.7.0 in folder: C:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ESP_Async_WebServer
Using library Hash at version 1.0 in folder: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Hash
Using library ElegantOTA at version 3.1.0 in folder: C:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\ElegantOTA
Using library LittleFS at version 0.1.0 in folder: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\LittleFS
Using library Wire at version 1.0 in folder: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire
Using library EEPROM at version 1.0 in folder: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\EEPROM
Using library SPI at version 1.0 in folder: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI
Using library SD at version 2.0.0 in folder: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SD
Using library SDFS at version 0.1.0 in folder: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SDFS
Using library ESP8266SdFat at version 2.1.1 in folder: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266SdFat
Using library EMailSender at version 3.0.13 in folder: C:\Users\user\OneDrive\One-Documents\4-Arduino\libraries\EMailSender-master
Understood. I copied the wrong set of instructions. I apologize for any confusion.
Please tell us which IDE version this output came from.
Please also post the output from compiling with the other IDE version.
This is from the "problematic" IDE 2.3.1
Shortly I will post the output from IDE 2.2.1, different computer, takes some juggling
IDE 2.2.1 output
IDE 2-2-1 output.txt (125.8 KB)
I compared the two and found a possibly significant difference:
From the 2.2.1 output:
FQBN: esp8266:esp8266:nodemcuv2:mmu=4816H
From the 2.3.1 output:
FQBN: esp8266:esp8266:nodemcuv2:mmu=3216
It is a bit cryptic, but what this means is that you have "16KB cache + 48KB IRAM and 2nd Heap (shared)" selected from the Tools > MMU menu in Arduino IDE 2.2.1 and "16KB cache + 32KB IRAM + 16KB 2nd Heap (not shared)" selected from the menu in Arduino IDE 2.3.1.
Select Tools > MMU > 16KB cache + 48KB IRAM and 2nd Heap (shared) from the Arduino IDE 2.3.1 menus, upload the sketch to your ESP8266 board again, and then check whether the crash still occurs.
Hallelujah! This indeed is the issue.
Wow, that was quick! Thank you very much!
You are welcome. I'm glad it is working now.
Regards,
Per
