Esp32 wroom DA module - need flash mode QOUT
I am using an esp32D0 module that behaves like ESP32 VROOM DA
when I try to upload arduino project i receive error
"A fatal error occurred: Failed to write to target RAM (result was 0107: Checksum error)
Failed uploading: uploading error: exit status 2"
If I make - Export Compiled Binary - and creatide files upload manuali by esptool with upload.bat
@echo off
echo Uploading bootloader...
python -m esptool --port COM17 write-flash --flash-mode dio --flash-freq 40m --flash-size 4MB 0x1000 "arduinocodetest.ino.bootloader.bin"
echo Uploading partitions...
python -m esptool --port COM17 write-flash --flash-mode dio --flash-freq 40m --flash-size 4MB 0x8000 "arduinocodetest.ino.partitions.bin"
echo Uploading application...
python -m esptool --port COM17 write-flash --flash-mode dio --flash-freq 40m --flash-size 4MB 0x10000 "arduinocodetest.ino.bin"
echo Done!
pause
it uploads normaly and it works ..
Is the problem ESP32 espessif library? (I am using the latist versison 3.3.10)
Thanks in advance
Hi @bikicviki.
I'm going to ask you to provide the full verbose output from an upload.
:red_exclamation_mark: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
    The "Preferences" dialog will open.
  2. Uncheck the box next to Show verbose output during: ☑ compile in the "Preferences" dialog.
  3. Check the box next to Show verbose output during: ☐ upload.
  4. Click the "OK" button.
    The "Preferences" dialog will close.
  5. Perform an upload, as you did before.
  6. Wait for the upload to finish successfully.
  7. Right click (Control-click for macOS users) on the black "Output" panel at the bottom of the Arduino IDE window.
    A context menu will open.
  8. Select Copy All from the menu.
  9. Open a reply here on this forum topic by clicking the "Reply" button.
  10. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
  11. Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
    This will paste the upload output into the code block.
  12. Move the cursor outside of the code block markup before you add any additional text to your reply.
  13. Click the "Reply" button to publish the post.
loading library from C:\Users\bikicviki\AppData\Local\Arduino15\libraries\package-460867620: invalid library: no header files found
FQBN: esp32:esp32:esp32da:UploadSpeed=115200,FlashFreq=40,EraseFlash=all
Using board 'esp32da' from platform in folder: C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.10
Using core 'esp32' from platform in folder: C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.10
cmd /c if exist "C:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest\\partitions.csv" COPY /y "C:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest\\partitions.csv" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\partitions.csv"
cmd /c if not exist "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\partitions.csv" if exist "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da\\partitions.csv" COPY "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da\\partitions.csv" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\partitions.csv"
cmd /c if not exist "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\partitions.csv" COPY "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\tools\\partitions\\default.csv" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\partitions.csv"
        1 file(s) copied.
cmd /c IF EXIST "C:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest\\bootloader.bin" ( COPY /y "C:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest\\bootloader.bin" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\gsmtest.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da\\bootloader.bin" ( COPY "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da\\bootloader.bin" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\gsmtest.ino.bootloader.bin" ) ELSE ( "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\5.3.0\\esptool.exe" --chip esp32 elf2image --flash-mode dio --flash-freq 40m --flash-size 4MB -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\gsmtest.ino.bootloader.bin" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10\\bin\\bootloader_qio_40m.elf" ) )
esptool v5.3.0
Creating ESP32 image...
Merged 2 ELF sections.
Successfully created ESP32 image.
cmd /c if exist "C:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest\\build_opt.h" COPY /y "C:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest\\build_opt.h" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\build_opt.h"
cmd /c if not exist "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\build_opt.h" type nul > "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\build_opt.h"
cmd /c type nul > "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts"
cmd /c COPY /y "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10\\sdkconfig" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\sdkconfig"
        1 file(s) copied.
Detecting libraries used...
C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32-elf-g++ -c @C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.10/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.10/flags/defines -IC:\Users\bikicviki\Documents\Projekti\2026\esp32_38_gsm_disp\gsmtest -iprefix C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.10/include/ @C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.10/flags/includes -IC:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.10/qio_qspi/include -IC:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.10\cores\esp32 -IC:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.10\variants\esp32da @C:\Users\bikicviki\AppData\Local\Temp\arduino\sketches\844166161292EC66792AA7D5F1763492/build_opt.h @C:\Users\bikicviki\AppData\Local\Temp\arduino\sketches\844166161292EC66792AA7D5F1763492/file_opts C:\Users\bikicviki\AppData\Local\Temp\arduino\sketches\844166161292EC66792AA7D5F1763492\sketch\gsmtest.ino.cpp -o nul
Alternatives for Wire.h: [Wire@3.3.10]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@3.3.10]
C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32-elf-g++ -c @C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.10/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.10/flags/defines -IC:\Users\bikicviki\Documents\Projekti\2026\esp32_38_gsm_disp\gsmtest -iprefix C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.10/include/ @C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.10/flags/includes -IC:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.10/qio_qspi/include -IC:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.10\cores\esp32 -IC:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.10\variants\esp32da -IC:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.10\libraries\Wire\src @C:\Users\bikicviki\AppData\Local\Temp\arduino\sketches\844166161292EC66792AA7D5F1763492/build_opt.h @C:\Users\bikicviki\AppData\Local\Temp\arduino\sketches\844166161292EC66792AA7D5F1763492/file_opts C:\Users\bikicviki\AppData\Local\Temp\arduino\sketches\844166161292EC66792AA7D5F1763492\sketch\gsmtest.ino.cpp -o nul
C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32-elf-g++ -c @C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.10/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.10/flags/defines -IC:\Users\bikicviki\Documents\Projekti\2026\esp32_38_gsm_disp\gsmtest -iprefix C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.10/include/ @C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.10/flags/includes -IC:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.10/qio_qspi/include -IC:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.10\cores\esp32 -IC:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.10\variants\esp32da -IC:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.10\libraries\Wire\src @C:\Users\bikicviki\AppData\Local\Temp\arduino\sketches\844166161292EC66792AA7D5F1763492/build_opt.h @C:\Users\bikicviki\AppData\Local\Temp\arduino\sketches\844166161292EC66792AA7D5F1763492/file_opts C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.10\libraries\Wire\src\Wire.cpp -o nul
Generating function prototypes...
C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32-elf-g++ -c @C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.10/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.10/flags/defines -IC:\Users\bikicviki\Documents\Projekti\2026\esp32_38_gsm_disp\gsmtest -iprefix C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.10/include/ @C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.10/flags/includes -IC:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\tools\esp32-libs\3.3.10/qio_qspi/include -IC:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.10\cores\esp32 -IC:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.10\variants\esp32da -IC:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.10\libraries\Wire\src @C:\Users\bikicviki\AppData\Local\Temp\arduino\sketches\844166161292EC66792AA7D5F1763492/build_opt.h @C:\Users\bikicviki\AppData\Local\Temp\arduino\sketches\844166161292EC66792AA7D5F1763492/file_opts C:\Users\bikicviki\AppData\Local\Temp\arduino\sketches\844166161292EC66792AA7D5F1763492\sketch\gsmtest.ino.cpp -o C:\Users\bikicviki\AppData\Local\Temp\1054645904\sketch_merged.cpp
C:\Users\bikicviki\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\bikicviki\AppData\Local\Temp\1054645904\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\libraries\\Wire\\src" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\sketch\\gsmtest.ino.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\sketch\\gsmtest.ino.cpp.o"
Compiling libraries...
Compiling library "Wire"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\libraries\\Wire\\src" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\libraries\\Wire\\src\\Wire.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\libraries\\Wire\\Wire.cpp.o"
Compiling core...
cmd /c echo -DARDUINO_CORE_BUILD > "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\Esp.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\Esp.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\FunctionalInterrupt.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\FunctionalInterrupt.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\ColorFormat.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\ColorFormat.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\FirmwareMSC.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\FirmwareMSC.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\HEXBuilder.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\HEXBuilder.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\HWCDC.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\HWCDC.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\HardwareSerial.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\HardwareSerial.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\HashBuilder.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\HashBuilder.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\IPAddress.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\IPAddress.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\MD5Builder.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\MD5Builder.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\MacAddress.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\MacAddress.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\Print.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\Print.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\Stream.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\Stream.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\StreamString.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\StreamString.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\StringUtils.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\StringUtils.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\Tone.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\Tone.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\USB.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\USB.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\USBCDC.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\USBCDC.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\USBMSC.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\USBMSC.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\WMath.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\WMath.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\WString.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\WString.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\base64.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\base64.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\cbuf.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\cbuf.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\chip-debug-report.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\chip-debug-report.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-adc.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-adc.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-bt.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-bt.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-cpu.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-cpu.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-dac.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-dac.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-gpio.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-gpio.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-hosted.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-hosted.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-i2c-ng.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-i2c-ng.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-i2c-slave.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-i2c-slave.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-i2c.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-i2c.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-ldo.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-ldo.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-ledc.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-ledc.c.o"
\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-log-wrapper.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-log-wrapper.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-matrix.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-matrix.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-misc.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-misc.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-periman.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-periman.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-psram.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-psram.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-rgb-led.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-rgb-led.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-rmt.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-rmt.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-sigmadelta.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-sigmadelta.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-spi.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-spi.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-time.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-time.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-timer.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-timer.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-tinyusb.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-tinyusb.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-touch-ng.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-touch-ng.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-touch.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-touch.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\esp32-hal-uart.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-uart.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\firmware_msc_fat.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\firmware_msc_fat.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\freertos_stats.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\freertos_stats.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\idf_openthread_mpool_wrapper.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\idf_openthread_mpool_wrapper.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\libb64\\cdecode.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\libb64\\cdecode.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\libb64\\cencode.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\libb64\\cencode.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\main.cpp" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\main.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\stdlib_noniso.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\stdlib_noniso.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\wiring_pulse.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\wiring_pulse.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc" -MMD -c "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/c_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_WROOM_DA\"" "-DARDUINO_VARIANT=\"esp32da\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32da:UploadSpeed=115200,CPUFreq=240,FlashFreq=40,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=all\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/defines" "-IC:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest" -iprefix "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/include/" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/includes" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi/include" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32" "-IC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\variants\\esp32da" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/build_opt.h" "@C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\cores\\esp32\\wiring_shift.c" -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\wiring_shift.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\ColorFormat.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\Esp.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\FirmwareMSC.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\FunctionalInterrupt.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\HEXBuilder.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\HWCDC.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\HardwareSerial.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\HashBuilder.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\IPAddress.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\MD5Builder.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\MacAddress.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\Print.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\Stream.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\StreamString.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\StringUtils.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\Tone.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\USB.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\USBCDC.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\USBMSC.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\WMath.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\WString.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\base64.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\cbuf.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\chip-debug-report.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-adc.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-bt.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-cpu.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-dac.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-gpio.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-hosted.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-i2c-ng.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-i2c-slave.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-i2c.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-ldo.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-ledc.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-log-wrapper.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-matrix.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-misc.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-periman.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-psram.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-rgb-led.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-rmt.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-sigmadelta.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-spi.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-time.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-timer.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-tinyusb.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-touch-ng.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-touch.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\esp32-hal-uart.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\firmware_msc_fat.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\freertos_stats.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\idf_openthread_mpool_wrapper.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\libb64\\cdecode.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\libb64\\cencode.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\main.cpp.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\stdlib_noniso.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\wiring_pulse.c.o"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-gcc-ar" cr "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\wiring_shift.c.o"
Archiving built core (caching) in: C:\Users\bikicviki\AppData\Local\Temp\arduino\cores\e088abd95ffaa8d1243db2afb9a344a3\core.a
cmd /c type nul > "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/file_opts"
Linking everything together...
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-g++" "-Wl,--Map=C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/gsmtest.ino.map" "-LC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/lib" "-LC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/ld" "-LC:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/qio_qspi" -Wl,--wrap=esp_panic_handler -Wl,--wrap=esp_bt_mem_release -Wl,--wrap=esp_bt_controller_mem_release "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/ld_flags" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/ld_scripts" -Wl,--start-group "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\sketch\\gsmtest.ino.cpp.o" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\core\\core.a" "@C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10/flags/ld_libs" -Wl,--end-group -Wl,-EL -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/gsmtest.ino.elf"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\5.3.0/esptool.exe" --chip esp32 elf2image --flash-mode dio --flash-freq 40m --flash-size 4MB --elf-sha256-offset 0xb0 -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/gsmtest.ino.bin" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/gsmtest.ino.elf"
esptool v5.3.0
Creating ESP32 image...
Merged 2 ELF sections.
Successfully created ESP32 image.
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\tools\\gen_esp32part.exe" -q "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/partitions.csv" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/gsmtest.ino.partitions.bin"
cmd /c if exist "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\libraries\\Insights" "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\tools\\gen_insights_package.exe" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492" gsmtest.ino "C:\\Users\\bikicviki\\Documents\\Projekti\\2026\\esp32_38_gsm_disp\\gsmtest"
cmd /c if exist "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\libraries\\ESP_SR" if exist "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10\\esp_sr\\srmodels.bin" COPY /y "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-libs\\3.3.10\\esp_sr\\srmodels.bin" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\srmodels.bin"
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\5.3.0/esptool.exe" --chip esp32 merge-bin -o "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/gsmtest.ino.merged.bin" --pad-to-size 4MB --flash-mode keep --flash-freq keep --flash-size keep 0x1000 "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/gsmtest.ino.bootloader.bin" 0x8000 "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/gsmtest.ino.partitions.bin" 0xe000 "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10/tools/partitions/boot_app0.bin" 0x10000 "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/gsmtest.ino.bin"
esptool v5.3.0
Wrote 0x400000 bytes to file 'C:\Users\bikicviki\AppData\Local\Temp\arduino\sketches\844166161292EC66792AA7D5F1763492/gsmtest.ino.merged.bin', ready to flash to offset 0x0.
cmd /c echo --flash-mode dio --flash-freq 40m --flash-size 4MB > "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\flash_args" && echo 0x1000 gsmtest.ino.bootloader.bin >> "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\flash_args" && echo 0x8000 gsmtest.ino.partitions.bin >> "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\flash_args" && echo 0xe000 boot_app0.bin >> "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\flash_args" && echo 0x10000 gsmtest.ino.bin >> "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\flash_args"
cmd /c copy /y "C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.10\\tools\\partitions\\boot_app0.bin" "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492\\boot_app0.bin"
        1 file(s) copied.
Using library Wire at version 3.3.10 in folder: C:\Users\bikicviki\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.10\libraries\Wire
"C:\\Users\\bikicviki\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32-elf-size" -A "C:\\Users\\bikicviki\\AppData\\Local\\Temp\\arduino\\sketches\\844166161292EC66792AA7D5F1763492/gsmtest.ino.elf"
Sketch uses 309780 bytes (23%) of program storage space. Maximum is 1310720 bytes.
Global variables use 23596 bytes (7%) of dynamic memory, leaving 304084 bytes for local variables. Maximum is 327680 bytes.
esptool v5.3.0
Serial port COM17:
Connecting.........
Connected to ESP32 on COM17:
Chip type:          ESP32-D0WD-V3 (revision v3.1)
Features:           Wi-Fi, BT, Dual Core + LP Core, 240MHz, Vref calibration in eFuse, Coding Scheme None
Crystal frequency:  40MHz
MAC:                8c:94:df:90:f6:f0
Uploading stub flasher...
A fatal error occurred: Failed to write to target RAM (result was 0107: Checksum error)
Failed uploading: uploading error: exit status 2
Another ESP32 user encountered the same "Failed to write to target RAM (result was 0107: Checksum error)" error:
They identified the cause as being a helper tool named serial-discovery, which is used by Arduino IDE. And to be more specific, the recently released version 1.5.0 of that tool. Please try this experiment to determine whether that is also the cause of the upload failure you are experiencing:
  1. If Arduino IDE is running, select File > Quit from the Arduino IDE menus.
    All Arduino IDE windows will close.
  2. Start Windows File Explorer.
  3. Use File Explorer to navigate to the folder at the following path on your computer's hard drive:
    C:\Users\bikicviki\AppData\Local\Arduino15\packages\builtin\tools\serial-discovery\1.5.0
    :red_exclamation_mark: The AppData folder is hidden by default. You can make it visible by opening the "View" menu in File Explorer, then checking the box next to "☐ Hidden items".
  4. You will see a file named serial-discovery.exe in the folder. Right click on that file.
    A context menu will open.
  5. Select "Rename" from the menu.
    The menu will close and the filename will now be an editable text field.
  6. Type serial-discovery-original in the text field.
  7. Press the Enter key.
    The filename change will be committed.
  8. Click the following link:
    https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.4.3_Windows_64bit.zip
    Your web browser will start a file download.
  9. Wait for the download to finish.
  10. Extract the downloaded serial-discovery_v1.4.3_Windows_64bit.zip file to any convenient location on your computer.
  11. Copy the serial-discovery.exe file from the extracted folder to the folder at the following path on your hard drive:
Now start Arduino IDE and try uploading again, just as you did before when you encountered the error. Hopefully it will be successful this time.
Thanks a lot!
I had the same problem and now uploading works properly!
You are welcome. I'm glad it is working now. Thanks for taking the time to post an update!
Regards, Per
I shared an update regarding possible progress towards achieving a true fix for the problem of serial-discovery 1.5.0 interfering with uploads to ESP32 boards, as well as some boring related technical details here:
