Arduino IDE 2.3.3 Appimage problems on Kubuntu 24.04
I have got the Appimage and I try to run it from the file browser as I have in the past. It doesn't start.
Of the eight Appimage programs that I use this and Etcher don't start this way.
I can start these two from the terminal if I append --no-sandbox to the command line,
but I get plenty of this error in the Arduino-IDE startup first:
gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2).
Can anybody suggest where I should look for a solution? Ideally I would like to create a menu item to start the program.
Thanks,
Create a file named "usr.local.bin.arduino" in /etc/apparmor.d whit this content:
abi <abi/4.0>,
include <tunables/global>
profile arduino /usr/local/bin/arduino-ide* flags=(unconfined) {
  userns,
  include if exists <local/arduino>
Copy the arduino-ide_2.3.3_Linux_64bit.AppImage in /usr/local/bin (you need root privileges to do that), reboot and everything should work (at least, it did for me).
Ciao, Ale.
Thank you for that. It worked for me.
It also helped that I spelled AppImage with the capital 'I' in the middle too.
Peter M.
